Like Tree5Likes
  • 3 Post By Enki
  • 1 Post By rfinkle2
  • 1 Post By WetzMS3
 Old 01-24-2016, 01:33 PM   #1
Xxblinddzxx's Avatar
Posts: 126   (View Stats)
Xxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud of
Groaned at 26 Times in 11 Posts
Default Mazdaspeed 3 fmic core 600hp + first gen
Hi guys
I'm getting a new turbo soon and now looking for a intercooler that will be able to support the turbo (gtx35). I saw a nice tread in here about some intercooler for speed 1 and 2 gen.. Thing is that they seems to be 500hp restrictive .. I know that ATP does a 600hp ready intercooler but if possible I'm trying to avoid to rebuy a whole new intercooler kit I'd prefer only the core. Anyone saw something interesting ? Otherwise any intercooler full kit that you guys would recommend ? (Btw I'm currently running a cxracing kit)
Thanks
Xxblinddzxx is offline   Reply With Quote
 Old 01-24-2016, 01:35 PM   #2
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Treadstone tr8L.
tapatalk, it sucks
 Old 01-24-2016, 01:36 PM   #3
Yup I saw that one yesterday , 500hp efficient
 Old 01-24-2016, 01:37 PM   #4
Missed the L, tr8L is 575 capable.
tapatalk, it sucks
 Old 01-24-2016, 01:52 PM   #5
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
here ya go, find what you like.
https://www.treadstoneperformance.co...e+Intercoolers
 Old 01-24-2016, 01:53 PM   #6
Originally Posted by Hargarbl View Post
Yup was currently looking but what's the max size I can put there ? Max dimension ?
 Old 01-24-2016, 01:54 PM   #7
Hargarbl's Avatar
Groans: 51
with a sawzall you could get any of them to fit, you're most likely going to need to do some cutting even with the smaller cores.
 Old 01-24-2016, 01:56 PM   #8
No need to touch crash bar? Correct me if I'm wrong but there's some parts that if you cut/modify it'll become invalid to insurance ?
The Following User Says NO Thank You to Xxblinddzxx For This Un-useful Post:
SofaKingAwesome (01-25-2016)
 Old 01-24-2016, 02:02 PM   #9
Hargarbl's Avatar
Groans: 51
if you have the room you can tuck it behind the crashbar, I know on the ms6 the room is there to do so, not too sure on the ms3. most likely would need some cutting or possibly an aftermarket crashbar
The Following User Says Thank You to Hargarbl For This Useful Post:
Xxblinddzxx (01-24-2016)
 Old 01-24-2016, 02:09 PM   #10
That's not something insurance allow in here (montreal,quebec)
 Old 01-24-2016, 02:11 PM   #11
Hargarbl's Avatar
Groans: 51
could always fab up a air to water intercooler setup.
 Old 01-24-2016, 02:15 PM   #12
I guess that could be an option , any recommendations on this one ?
 Old 01-24-2016, 02:16 PM   #13
Hargarbl's Avatar
Groans: 51
no idea from me, I believe someone else has done it but for the most part you might be on your own for the research and fab work.
 Old 01-24-2016, 02:18 PM   #14
You got it , thx. I was maybe planing to get an I/c custom made as well
 Old 01-24-2016, 02:39 PM   #15
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Why is this thread in custom hardparts forum? This section is for people who have already done their custom parts and want to share.
monkey.bones.007 (01-24-2016), WetzMS3 (01-25-2016), Xxblinddzxx (01-24-2016)
 Old 01-24-2016, 02:42 PM   #16
My bad , not really used to the mobile app
 Old 01-24-2016, 02:50 PM   #17
Just use meth to chill your intake charge. Then you also have the benefits of extra fueling.
tapatalk, it sucks
Enki (01-24-2016), neganox (01-25-2016)
 Old 01-24-2016, 04:00 PM   #18
Already have meth kit
 Old 01-25-2016, 10:39 AM   #19
http://www.mazdaspeedforum.org/forum/foru...de-htp-195923/
monkey.bones.007 likes this.
HawkeyeGeoff (01-25-2016), maisonvi (01-25-2016), WetzMS3 (01-25-2016)
 Old 01-25-2016, 01:11 PM   #20
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
If you want a core big enough to cover 600hp, you are going to have to cut the crash bar some. I have a tr1035 and i had to notch and weld back together my crash bar. There is just no way to make something much bigger than a TR8L fit.
rfinkle2 (01-25-2016)
 Old 01-25-2016, 01:26 PM   #21
Police - Grammarhead
Vansquish's Avatar
If you swap in a larger turbo without notifying your insurer, that will also invalidate your insurance.
 Old 01-25-2016, 01:33 PM   #22
Make your smaller intercooler more efficient by spraying MORE meth.
 Old 01-25-2016, 01:35 PM   #23
how about CX racing double core intercooler
http://www.cxracing.com/mm5/merchant...&Category_Code
Anyone has yet review? Looks bigger than the old core that i currently own.
 Old 01-25-2016, 01:45 PM   #24
No.
CX Racing cores are garbage. I imagine a much smaller, but efficient core is better than that.
You're going to be hard pressed to find a core that will flow enough for 600hp and fit without cutting or removing the crashbar.
maisonvi (01-25-2016), rfinkle2 (01-25-2016)
 Old 01-25-2016, 02:51 PM   #25
No.
Yeah cutting removing crashbar is a bit of a problem -.-
 Old 01-25-2016, 03:00 PM   #26
Welp, it looks like "The Man" is limiting your choices. it's either a small uber efficient FMIC or an excellent TMIC and meth injection.
sent from my Nexus 6P
 Old 01-25-2016, 03:03 PM   #27
What is a "small uber efficient fmic" to you? 500hp rated (TR8)? Or you know some others?
 Old 01-25-2016, 03:08 PM   #28
You might have to change your Horsepower goals to stay legal. Since a FMIC that can support that power will require modification.
Corksport does make small FMIC that does not require a Crash bar modification. But that probably not going to fit with your goals.
 Old 01-25-2016, 03:11 PM   #29
Gotcha ... might need to do it then... Is it significant when you cut the crash bar?
 Old 01-25-2016, 03:13 PM   #30
OP, is it legal or approved by your insurance to run methanol injection? I highly doubt they would be accepting of a system that specifically states it is for off-road use only, like every meth kit I have seen.
As @MS3Shadow; said, I think you may need to re-think your goals. Or at least your intent to stay 100% compliant with your insurance.
 Old 01-25-2016, 03:15 PM   #31
well they didn't saw it so far .. guess im lucky then? anyway ... i guess i'll just do it if it's not too significant
 Old 01-25-2016, 03:15 PM   #32
It depends on the Core.
Look that people build threads and also Corksport pictures and manual to get a general idea.
 Old 01-25-2016, 03:18 PM   #33
I would bet money that insurance would not approve of a meth kit, whether it explicitly says anything about methanol injection or not.
In all reality, many of us run the risk of being denied claims due to modifications. Its a choice/risk you've got to make if you want that kind of power easily.
I imagine that you could have a custom IC core made, that would fit the space you have, and flow enough for 600hp. However, that will get very costly. Way more costly than any CX Racing parts.
FMIC core Matx MazdaSpeed 6 - Engine, Transmission & Driveline 6 05-15-2010 05:33 PM
Page generated in 0.50839 seconds with 30 queries
