![]() Join Date: Apr 2019
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Sorry I didnt mean to make a duplicate post Last edited by Themajinmazda; 01-30-2020 at 04:16 PM. Reason: MSF Database - Automerged Doublepost |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 550
| Not Ranked : 0 score tascaparts.com or the dealer
__________________ Stockish |
Groans: 60
| Not Ranked : 0 score The sensor can only be purchased with the rail if you go OEM. But the 3, 6, and cx-7 use the same rail and sensor.
| Not Ranked : 0 score I have some for sale here.
| Ms3 Fuel rail pressure sensor | Themajinmazda | Mazdaspeed3/6 General Discussion | 1 | 01-30-2020 04:08 PM |
| Fuel Rail pressure Sensor | SpecialK | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 21 | 01-09-2018 01:41 PM |
| fuel rail pressure sensor | Skup1993 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 3 | 02-05-2011 09:14 PM |
