Mazdaspeed Forums
-   Mazdaspeed3/6 General Discussion (http://www.mazdaspeedforum.org/forum/forum/f505/)
-   -   Mazdaspeed 6 General Build/Parts Thread (http://www.mazdaspeedforum.org/forum/forum/f505/mazdaspeed-6-general-build-parts-thread-115234/)
smokeys36shop 06-01-2012 10:56 AM
A few months back i made a Mazdaspeed 6 General Build/Parts Thread on another forum and since i am liking this thread more and more and have used it for some installs i figure i would share it here to help this Mazda Community.
It starts out with 3 stages to help guide you on your want to making a solid car.
The second section is a listing by stage with a link to almost every part for the speed 6.
If the stages don't help the community i will delete it but i figure new people can use this to build their cars and to find parts easier instead of asking. Hope it helps
Additional Info is Welcome!
General Build Thread
To start out I want to say that this thread will favor the Cobb AP over any tuning device since I feel it is the best on the market. Other tuning devices are CP-E, Hypertech, Unichip & Versatuner
So here are the stages. Note: there is no particular order to get these products and this is just a general guide
Stage 1 -
-I recommend start out with buying the Cobb AP. it can be used on a stock car/also allows for monitoring the car.
-short ram intake or cold air intake with supporting turbo inlet pipe
-Upgraded bypass valve or blow off valve
-Upgraded spark plugs
-Rear engine motor mount
-3 inch test pipe
Stage 2 -
-3 inch exhaust
-Upgraded downpipe
-Top mount intercooler/front mount intercooler ( preferably fmic over tmic for better cooling )
-Upgraded fuel pump for higher than stock boost levels and power
-Upgraded rear differential brace and mount.
-Upgraded Passanger Side Engine Mount, Transmission Mount & Front Engine Mount
(note: all of the above mods will work well with the stage 2 tunes on the Cobb AP or may need a slight tweek in the tune.)
after stage 2 is where the power mods come in. you can go as far as you want with it. both stage 1 & 2 will give you everything you need to support these power mods.
(note: all mods after will require some sort of protune/etune. it is recommended to speak to a professional or someone who is very knowledgeable in tuning the speeds. there is someone over on mazdaspeed forums named djuosnteisn who seems to be e/tuning alot of peoples cars and many of them seem to be very happy with it. http://www.mazdaspeedforum.org/forum/foru...ne-list-89893/ )
Stage 3-
-Meth kit
-Intercooler Sprayer
-Turbo Upgrade
-Depending on turbo upgrade a new turbo inlet and 3"intake
-Turbo Manifold
-Upgraded Wastegate Actuator
-Engine Upgrade like pistons and rods or new motor
-Upgraded Radiator
-Ported Intake Manifold
-Ported Throttle Body
-Upgraded Clutch
-Upgraded Flywheel
-Upgraded Ignition System
Additional Supporting Mods-
Additional monitoring system
Turbo Timer
Boost Gauge
Upgraded short shifter & bushings
Shifter Cable Relocation
Front & Rear Sway Bar
Lowering Springs and Coilovers
Balance Shaft Delete
Thermal Insulating Gasket
Boost Controller
Oil Catch Can
Front & Rear Strut Bar
EGR Block Off Plate
Injector Seals
Map Sensors & Harness
Overboost Protection
This is all i can think of right now. Of course people are welcome to add more if i am missing any.
First off here is a list of the main sites to buy parts from for Mazdaspeeds in general:Second, here is a list of e-tuners from www.mazdaspeedforum.org/forum (http://www.mazdaspeedforum.org/forum/forum/f601/):THAT'S ONLY A FEW!! HELP ME OUT AND NAME SOME MORE! Along with their respective company if possible please.
There are many different brands for each category. Below is a list for each, by stages in no particular order
Stage 1
Tuning Solution
Cobb Ap is a one of a kind product. Here is a link to Cobb with detailed information on it - COBB Tuning - MAZDASPEED AccessPORT . this link is only for the 2006-2007 mazdaspeed 6. There is a seperate link for the speed 3's
Other Tuning Solutions
VersaTuner - VersaTuner - tuning software for Mazdaspeed, Mazda MPS and Mazda CX-7
CPE- ??????? I don't see it on their site anymore CPE Standback
(note: again please note this thread was set up using the cobb ap in mind due to the preset maps available for it.)
Intake Systems
Short Ram Intake-
cobb - COBB Tuning - MAZDASPEED6 SF Intake Kit
cp-e - MazdaSPEED6 XcelNANO
corksport with inlet - Mazdaspeed 6 Short Ram Intake CorkSport Power Series
Cold Air Intakes
CP-E - MazdaSPEED6 Xcel
Injen - Injen Cold Air Intake for Mazdaspeed 6 #SP6071 - Revolution Performance Motorsports!
Inlet Pipes
Cobb - COBB Tuning - MAZDASPEED Turbo Inlet Hose
Corksport - CORKSPORT Power Series Turbo Inlet Pipe
HTP - http://www.hitunedperformance.com/msproducts.html
CP-E - MZR 2.3 DISI Nviscid
Upgraded bypass valve or blow off valves
HKS- MazdaSPEED6 HKS Blowoff Valve Kit | Custom Performance Engineering
Cobb - MAZDASPEED XLE Bypass Valve
Turboxs Hybrid BOV - Mazdaspeed 3 & 6 Hybrid Blow Off Valve - TurboXS
GFB BOV - http://www.gfb.com.au/products?page=...ategory_id=179
Rear Engine Motor Mount
JBarone - Rear Motor Mount 80a Durometer [MS6MollyRMM] - $90.00 : James Barone Racing, Custom Fabrication
CP-E - MazdaSPEED6 Engine Mount | Custom Performance Engineering
AWR - AWR Rear Motor Mount for MAZDASPEED 6
Test Pipe
Corksport Race Pipe - CORKSPORT 'Power Series' Racepipe For Mazdaspeed 6
SLS - Protege Garage - SLS Test Pipe - Mazdaspeed6
Stage 2-
Catback Exhaust
Cpe Single 3" Exhaust- http://www.cp-e.com/products/mazdasp...exhaust-system
Cpe Dual 3" Exhaust - http://www.cp-e.com/products/mazdasp...exhaust-system
Corksport 80mm 3.1" Exhaust - http://www.corksport.com/corksport-p...st-system.html
Magnaflow 2.5"/2.25" Exhaust - http://www.magnaflow.com/02product/s...ne=all&id=7597
GHL Duel 3" Exhaust - http://www.therpmstore.com/store/p/5...daspeed-6.html
Custom Exhaust from a local exhaust shop
Downpipe
Corksport - http://www.corksport.com/corksport-p...-downpipe.html
CP-E - http://www.cp-e.com/products/mazdasp...-3-ss-downpipe
Ebay - http://www.ebay.com/itm/06-07-Mazda-...item1e6a5fe6f5
Top Mount Intercooler
Corksport - http://www.corksport.com/corksport-m...tercooler.html
CPE - http://www.cp-e.com/products/mazdasp...nt-intercooler
PTP - http://www.pt-performance.com/showPr...4&cID=7&pID=52
Front Mount Intercooler
Corksport - http://www.corksport.com/corksport-p...-fmic-kit.html
Corksport Version 2 - http://www.corksport.com/corksport-m...am-intake.html
CPE - http://www.cp-e.com/products/icy2011...nt-intercooler
CX-Racing - http://www.cxracing.com/mm5/merchant..._Code=JDMZDSPD
Altered Custom - http://www.alteredcustoms.net/Altere...it-MS6-p5.html
Custom / Make Your Own
Upgraded Fuel Pump
KMD Fuel Pump Internals - http://www.kmdtuning.com/index.php?_...productId=1153
PTP Fuel Pump Internals - http://www.protegegarage.com/1663-hi...azdaspeed.html
Autotech Fuel Pump Internals - http://edgeautosport.com/autotech-hi...p-upgrade-kit/
CPE Upgraded Fuel Pump - http://www.cp-e.com/products/hpfpump...fpump%E2%84%A2
Upgraded Rear Differential Brace and Mount.
CPE - http://www.cp-e.com/products/mazdasp...erential-mount
Turbine Tech Mount - http://www.streetunit.com/Turbine_Te.../ttms6rdfm.htm
Passanger, Transmission Mounts & Front Engine Mounts
AWR Kit - http://store.awrracing.com/products/...%252d2007.html
Stage 3-
Meth Kit
Labante - http://superpowercharger.com/watermeth.htm
Devils Own - http://www.alcohol-injection.com/en/172-speed-6
AEM - http://www.aemelectronics.com/water-...hnr91626repqu7
Turbo Upgrade
BNR Stage 1-3 - http://bnrsupercars.com/
ATP General List - http://www.atpturbo.com/mm5/merchant...egory_Code=MS6
3" intake/inlet For UpGraded ATP Turbo
ATP Inlet - http://www.atpturbo.com/mm5/merchant...egory_Code=MS6
ATP Intake - http://www.atpturbo.com/mm5/merchant...egory_Code=MS6
CPE Intake - http://www.cp-e.com/products/mazdasp...%A2-air-intake
CPE Inlet - http://www.cp-e.com/products/mazdasp...%E2%84%A2-pipe
HTP Inlet - HTP - http://www.hitunedperformance.com/ht...nlet-polished/
Jbarone Full 3" Intake System - Coming Soon
Turbo Manifold
Steedspeed - http://www.steedspeed.com/mazdaspeed...urbo_manifolds
DNP - http://edgeautosport.com/dn-performa...ifold-ms3-ms6/
OBX - http://www.ebay.com/itm/OBX-MAZDASPE...item335689b238
Creative Performance - http://www.streetunit.com/Creative_P...e_p/cp1234.htm
Full Race - http://www.full-race.com/store/turbo...-disi-mzr.html
CP-E - http://www.cp-e.com/products/feature...turbo-manifold
Engine Upgrade
Pistons
CPE Pistons - http://www.cp-e.com/products/mazdasp...3-disi-pistons
CPE Magnum Stage 2 Pistons - http://www.cp-e.com/products/mazdasp...stage2-pistons
Arias - http://www.protegegarage.com/948-product-948.html
Rods
CPE - http://www.cp-e.com/products/mazdasp...r-23-disi-rods
New Motor
CPE Stage 1 - http://www.cp-e.com/products/feature...-i-short-block
CPE Stage 2 - http://www.cp-e.com/products/feature...ii-short-block
CPE Stage 3 - http://www.cp-e.com/products/feature...ii-short-block
MAPerformance - http://www.maperformance.com/maperfo...3-ms3rev3.html
Grimmspeed - http://www.grimmspeed.com/catalog/pr...roducts_id=233
Grimmspeed - http://www.grimmspeed.com/catalog/pr...roducts_id=234
HKS - http://www.therpmstore.com/store/p/3...MX-5-CX-7.html
E85 Gas - http://www.e85fuel.com/find-an-e85-station/
Additional Monitoring System
Dashhawk - http://www.dashhawk.com/
Aeroforce Scan Guage - http://www.aeroforcetech.com/products_interceptor.html
Auterra - http://www.therpmstore.com/store/p/5...hDyno-SPD.html
ScanGauge II - http://www.therpmstore.com/store/p/3...-Computer.html
Boost Gauge (note: there are a ton of aftermarket companies & sizes so i am only listing a few)
52mm Prosport - http://prosportgauges.com/52mm-boost-gauge.aspx
52mm Prosport Digital - http://prosportgauges.com/Digital-boost-1.aspx
TWM Stage 1 & 2 - http://www.twmperformance.com/shorts...rtshifters.htm
Shifter Bushings
Twm - http://www.twmperformance.com/bushin...ushing-kit.php
Jbarone - http://www.jamesbaroneracing.com/sto...roducts_id=107
Shifter Cable Plate
Jbarone Kits include Plate/weight/bushings - http://www.jamesbaroneracing.com/sto...ex&cPath=40_98
J Speed - http://www.jspeedinc.com/apps/webstore/
Shifter Plate Weight
Jbarone - http://www.jamesbaroneracing.com/sto...ex&cPath=48_92
Front Sway Bar
Racing Beat - http://www.racingbeat.com/Mazda-6/Sway-Bars/70100.html
Rear Sway Bar
Corksport - http://www.corksport.com/corksport-m...bar.html?sl=EN
Coilovers
KSport - http://edgeautosport.com/ksport-kont...coilovers-ms6/
GP-Werks - https://www.gp-werks.com/products/Du...aSpeed-6).html
PTP - http://www.protegegarage.com/1768-ba...elete-kit.html
Jbarone - http://www.jamesbaroneracing.com/sto...&cPath=198_201
Jbarone Intake Mani Gasket - http://www.jamesbaroneracing.com/sto...roducts_id=237
Jbarone Throttle Body Gasket - http://www.jamesbaroneracing.com/sto...roducts_id=243
PTP Intake Mani Gasket - http://www.pt-performance.com/showPr...cID=11&pID=248
Oil Catch Can (note: there are a ton of aftermarket companies so i am only listing a few)
Corksport - http://www.corksport.com/corksport-oil-catch-can.html
Jbarone - http://www.jamesbaroneracing.com/sto...&cPath=147_151
Protege Garage - http://www.protegegarage.com/1530-product-1530.html
Protege Garage - http://www.protegegarage.com/1523-product-1523.html
Front Strut Bar
Corksport - http://www.corksport.com/corksport-f...daspeed-6.html
Speedline Front Lower Strut Bar - http://www.thespeedline.us/servlet/t...06-pls-/Detail
Rear Brace Bar
Corksport - http://www.corksport.com/corksport-r...daspeed-6.html
The Speedline - http://www.thespeedline.us/servlet/t...06-pls-/Detail
EGR Block Off Plate
Jbarone - http://www.jamesbaroneracing.com/sto...products_id=92
High Pressure Rail Valve
PTP - http://www.pt-performance.com/showPr...&cID=3&pID=330
Injector Seals
Cpe - http://www.cp-e.com/products/mazdasp...injector-seals
PTP - http://www.pt-performance.com/showPr...&cID=3&pID=290
Harness - http://www.bitwise-motorsports.com/
Bosch Sensor - 3 Bar - http://www.bmotorsports.com/shop/pro...oducts_id/1721
Bosch Sensor 3.5 Bar -http://www.bmotorsports.com/shop/product_info.php/products_id/1772
Stratified Guardian Angel - http://www.stratifiedauto.com/index....roducts_id=217
Alpha 06-01-2012 11:08 AM
Just to add to your list, Full Race makes a killer 2pc downpipe for these cars and RPS as well as Southbend both have clutches near production. :)
Code Monkey 06-01-2012 11:11 AM
I would add SPC ball joints to stage 1 (really any stage) - combined with a proper alignment it makes the car a different animal handling-wise.
TiGraySpeed6 06-01-2012 12:18 PM
Shame you're not VIP, I suspect @Raider would reward this effort
Raider 06-01-2012 12:25 PM
Damn. this is def $$ MSF Bucks worthy of a reward. but no VIP.
I stuck it. FWIW. CPE Standback is doorstop material now.
Raider 06-01-2012 12:33 PM
If @barone takes time and posts up the links to his stuff, I can add it too.
TiGraySpeed6 06-01-2012 12:42 PM
List is in need of the MD SM OCC link - OCC KITS MAZDASPEED6 - Performance Automotive Development LLC
smokeys36shop 06-01-2012 12:48 PM
ti you know im still new with this site lol...i will donate tonight when i get home from work
Raider 06-01-2012 12:49 PM
pm me when you do, I'll make you rich...
smokeys36shop 06-01-2012 12:49 PM
Its true Cpe is no longer selling the standback but i was told they still work with it for people who still own it or buy it used. thats why its up on the list
smokeys36shop 06-01-2012 12:58 PM
Quote:
will do...expect my pm some time tonight then. no idea what you do with the msf money lol but i am sure in time i will find out
I do hope this turns into a good thread for people to turn to for helpful info. i have always said that people need a helpful structured guide/list for modding for this car.
This thread in total took well over 20 hours of research so far on different companies sites. Raider if you know of a way to make it more appealing to the community here let me know and i will try to correct it the best i can.
Raider 06-01-2012 12:58 PM
Wow. Well, at least the 5 remaining users are in luck, lol.
TiGraySpeed6 06-01-2012 01:05 PM
lolz- Smokey you're all good!
I'm 800+ posts in and have never pointed out a post to Raider before
It's an MSF way of saying Damn Nice Job!
smokeys36shop 06-01-2012 01:15 PM
I am no longer BROWN
Raider 06-01-2012 01:22 PM
$ sent
Amped 07-07-2012 12:10 AM
smokeys36shop, I want to thank you for this info, I just picked up my used Speed6 since I totaled my 3 and have been looking for a post like this since I'm sure as hell not making a noob "what should I do first" thread. You've make my life 20x easier. Well deserved sticky, nice work.
darkcherry 07-07-2012 01:54 AM
This should be a sticky for noobs! Awesome job on the research and time that went into making this thread. Also would like to add a side note. Corksport has a new front sway bar coming out the middle/ end of July for the mazdaspeed 6 and it is 28.5mm. Reasonably priced. Just a FYI for this thread and to add to that they are in the development to a few more items they have not made public yet for the mazdaspeed 6's.
smokeys36shop 07-09-2012 07:41 AM
Quote:
No problem. Its something i always felt the speed 6 community needed.
Quote:
thanks. yes i get corksports emailed news letter and saw the front sway bar was coming soon so i will be adding it when it hits. Still waiting for Jbarone to come out with his 3.5 inch intake for our cars as well. Other than those 2 companies i don't think i need to add anything new to that list yet.
Added Street Units Exhaust Manifold - StreetUnit Exhaust Manifold
smokeys36shop 07-25-2012 02:22 PM
added Injector Seals, Map Sensors / Harness & Overboost Protection to the bottom of the list
Coaststarlight 08-08-2012 02:42 AM
Add Go-Fast-Bits "Respons" BOV to BOV list, Works quite well on the Speed
Options include being able to go from Full recirc and Full VTA and Anywear in between with a twist of a built-in knob and Fully adjustable/tunable spring load
Link:
Respons
joshuafouseMS6 08-17-2012 11:00 AM
MS6
I used this thred all the time for my car. Thank You
Jh8909 08-22-2012 05:16 PM
please add the JBR balance shaft delete to this list now. Thank you
Blackcherry06 09-18-2012 06:52 AM
great Thread, Thank you
LilGator 09-18-2012 07:48 AM
Quote:
Originally Posted by smokeys36shop (Post 1441818)
Stage 1 -
-3 inch test pipe
Why is BPV/BOV an assumed upgrade? What necessitates this?
smokeys36shop 09-18-2012 08:35 AM
Quote:
The stock bpv for me was a piece of crap. Not saying all of them are but mine was leaking. I personally don't like the stock plastic bpv and an upgraded metal one is something worth investing into if you ever plan on turning up the boost or for just holding proper boost levels. My factory boost levels were around 12-13 lbs of boost when I was stock. As soon as I upgraded to a aftermarket bpv I noticed I was where I was supposed to be from the start. That's my experience with it and is a reason why I added it where I did.
Again this is a general guide. No need to follow it 100%. I have met people in the past who just love the stock bpv but many who hated it and experienced the same issues I did with holding proper boost levels.
jbmazda6 12-12-2012 09:18 PM
Quite a few links were broken in the OG post so I fixed them and added a couple things along with a section for e-tunes as that's getting more popular. Just need Gary to copy/paste this into the original post.
Tried to quote it in this post but it's giving me a database error...
smokeys36shop 01-09-2013 08:16 AM
added sites to buy parts from for Mazdaspeeds & list of e-tuners from www.mazdaspeedforum.org/forum. If i missed anything let me know JB. Thanks for the info.
devindusza12 09-19-2019 02:16 PM
Pistons
Recently took the engine apart on my ms6 and found what I already figured was wrong (cracked piston). I am looking for forged pistons to buy any suggestions on a specific brand?
Page generated in 0.26041 seconds with 11 queries
