 Old 09-11-2012, 05:47 PM   #1
Speed6's Avatar
Posts: 21   (View Stats)
Speed6 has a spectacular aura aboutSpeed6 has a spectacular aura about
Default MS6 Power Steering Cooler
I'm getting a leak where the rubber hose meets the PS cooler - it seems that the tubing is corroded - anyone else have had this problem and if so what did you do?? I don't feel like shelling out $300+ for an OEM unit.
Speed6 is offline   Reply With Quote
 Old 09-11-2012, 06:18 PM   #2
CosmicArkie's Avatar
Posts: 1,332   (View Stats)
I've got a cooler similar to this one:
Dyno-Cool Power Steering Cooler 12213 | eBay
I was going to use it with a FMIC, but decided to stick with my TMIC, so its just
sitting on my bench. If you want it for $25, I'll eat the shipping.
 Old 09-11-2012, 06:28 PM   #3
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
There is a write up somewhere on doing a aftermarket PS coller swap, its pretty easy and alot cheaper. Do some searches and find it.
2006 Mazdaspeed 6
 Old 09-11-2012, 06:32 PM   #4
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I'd take that deal.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 09-11-2012, 06:49 PM   #5
Speed6's Avatar
I might take you up on that offer. Is it brand new?? Would this mount in the stock location or in front of the radiator??
 Old 09-11-2012, 07:07 PM   #6
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
MAAATT DAAMMOONNNDDD
did a write up a few years ago for a cooler upgrade. It is here somewhere.
 Old 09-11-2012, 07:21 PM   #7
Speed6's Avatar
I just tried doing a search and came up with nothing. I'll try again later.
 Old 09-11-2012, 07:27 PM   #8
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
I'm actually working on making power steering cooler kits.
I've got everything in stock, and I should have a MS6 to fit the kit in about a week.
Current Fail:
The Following 2 Users Say Thank You to MATT DAMOND For This Useful Post:
I<3Groceries (09-11-2012), Tokay444 (09-11-2012)
 Old 09-11-2012, 07:45 PM   #9
Speed6's Avatar
Awesome!!! I would definitely be interested. Let me know when you'll have them available.
 Old 09-12-2012, 04:58 PM   #10
Yes, its brand new, wrapped in plastic. I haven't opened it to look at the actual
cooler, you can see the hardware and hose, but the cooler is sandwiched between
cardboard.
I don't want to step on Matt's program, so I'll let you see what he comes up with
if you'd like.
I've been thinking a real cooler instead of the stupid tube in the way of everything
OEM cooler might be a better way to go myself.
The Following User Says Thank You to CosmicArkie For This Useful Post:
MATT DAMOND (09-12-2012)
 Old 09-12-2012, 08:23 PM   #11
Groans: 70
cardboard.
if you'd like.
Thanks man. But don't let me hold you back from selling what you got sitting around.
The coolers I'm using are a stacked plate design. I have already ran this cooler on my MS6, way back in the day, and it held up to a couple track days, with no issues. The cooler lowered the temps 20-30%, and I'll be offering a 50% larger cooler.
I had a tube cooler on before this one, and it sprung a leak, after a couple months. I just remembered I had sent it in for warranty, like 2yrs ago, and I never got it back.
Oh well.
The OEM cooler blows for any type of hard driving.
Will do. I should have a car on Monday or Tuesday, to install one.
Current Fail:
The Following User Says Thank You to MATT DAMOND For This Useful Post:
Speed_j23 (09-12-2012)
 Old 09-13-2012, 03:47 PM   #12
Soooo, are you making a kit for the 3's, too? If so, I just might be in the market for one.
 Old 09-13-2012, 07:22 PM   #13
Speed6's Avatar
I'm also looking for the small piece of rubber hose that goes between the line and cooler. Can't find anything from mazda - is this something i can buy at NAPA or Advance?? I refuse to buy anything from AutoZone. They are useless. At least the ones near me are lol
 Old 09-13-2012, 07:32 PM   #14
greg08's Avatar
Posts: 480   (View Stats)
if the OEM PS Cooler is ok, you could add another to help cool it
 Old 09-14-2012, 09:23 PM   #15
Groans: 70
Yes, for the gen1's. It'll be great for ppl with FMICs, since it replaces the old bulky lines.
If you're talking about that little like 3-4" section of hose, it'll be tricky to find a replacement, since it goes from 3/8" to 1/2" inner dia
Current Fail:
06Speed6 (09-14-2012), Tomas (09-14-2012)
 Old 09-15-2012, 04:51 PM   #16
Speed6's Avatar
After changing my tranny fluid today, I took a closer look and noticed its leaking from both ends of that small piece of hose. Not sure if it is the hose or the clamps... wondering if Mazda sells that short hose.
 Old 09-15-2012, 05:01 PM   #17
greg08's Avatar
Cant u buy a 3/8 to 1/2 plastic reducer for cheap ?
 Old 09-15-2012, 06:00 PM   #18
Speed6's Avatar
I'll have to check. Possibly at a hardware store??
 Old 09-15-2012, 06:05 PM   #19
Speed6's Avatar
Would something like this be able to withstand the pressures of a ps system??
Black Nylon 3/8 ID to 1/2 ID Reduction Fitting
 Old 09-15-2012, 07:51 PM   #20
greg08's Avatar
Yea that will work beautifully. Just use some hose clamps on each end to secure it
part number for power steering cooler? Lytheum Mazdaspeed3/6 General Discussion 6 04-03-2012 05:20 PM
COOLER MASTER Real Power Pro 750W Power Supply $59.99AR at ZipZoomfly Haltech Hot Deals Section 0 04-14-2008 05:00 PM
Page generated in 0.42960 seconds with 26 queries
