 Old 12-03-2017, 11:41 AM   #1
mrQQ's Avatar
Posts: 1,164   (View Stats)
mrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the world
Default MS6 started horning after lock
Hi,
suddenly my MS6 started horning after locking it with keyfob. Means I have to manually lock it with turning key in door. I checked all doors and trunk and lid and everything seems shut.
Anything other I'm missing?
mrQQ is offline   Reply With Quote
 Old 12-03-2017, 12:09 PM   #2
mrQQ's Avatar
One thing I did is I had battery unplugged to charge it for the weekend. Could be related?
 Old 12-03-2017, 12:31 PM   #3
mrQQ's Avatar
solved, please ignore
 Old 05-10-2018, 07:27 AM   #4
mikey27's Avatar
Posts: 87   (View Stats)
mikey27 is a name known to allmikey27 is a name known to allmikey27 is a name known to allmikey27 is a name known to allmikey27 is a name known to allmikey27 is a name known to all
Was it the ground block on the drivers side frame rail?
Sent from my SM-G955W using Tapatalk
Shit, just looked at the date.... That's what I get for cruising threads for too long...
2007 ms6, BNR S3, JBR 3" silcone intake, streetunit tmic, ATP 3" dp, WW 3" dp back, Autotech hpfp, denso itv22 plugs, synapse synchronic bpv, Cobb ebcs, egr block off, cobb ap v3, Damond pmm, AWR tmm, jbr rmm, cpe rear diff mount, AEM trunk mount meth, 3bar map, cpe safeseals, SP63 4032 88mm pistons, Manley H beam rods, bsd w/baffle, mild head and im porting, vtcs delete, balanced bottom end, cm850 w/ steel fw, Innovate failsafe, guardian angel v3
Last edited by mikey27; 05-10-2018 at 07:27 AM. Reason: MSF Database - Automerged Doublepost
mikey27 is offline   Reply With Quote
 Old 05-14-2018, 08:34 AM   #5
greg08's Avatar
Posts: 480   (View Stats)
Rekt yourself. It's ok. We all do it sometimes <3
 Old 11-06-2018, 09:47 AM   #6
mrQQ's Avatar
Sorry guys for not posting the fix. Yes, it was exactly that!
 Old 05-14-2018, 01:19 PM   #7
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Technically, OP did some injustice by not posting "the fix" to his problem.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 05-14-2018, 04:55 PM   #8
greg08's Avatar
Very true. Not cool, but it was probably something very stupid
New to VT, need help getting started Andi_RC36 VersaTune 15 02-16-2017 05:44 PM
Getting Started Swagerwagon03 Auto-X / Road Racing / Time Attack 13 12-13-2011 06:31 AM
Car started with no oil Meder MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 05-04-2009 12:44 AM
Page generated in 0.28520 seconds with 23 queries
