 Old 03-09-2019, 12:40 PM   #1
stars.eg6's Avatar
Posts: 133   (View Stats)
stars.eg6 has much to be proud ofstars.eg6 has much to be proud ofstars.eg6 has much to be proud ofstars.eg6 has much to be proud ofstars.eg6 has much to be proud ofstars.eg6 has much to be proud ofstars.eg6 has much to be proud ofstars.eg6 has much to be proud of
Default MS6, is it worth it?
Hi everyone, it’s been a long time., I have the opportunity to pick up an 07 MS6 GT with 152k miles on it for $2,000. It was never abused and the two previous owners were female adults. It’s overall condition is great except the tear on the rear bench seat. The other downfall is that it throws a lean bank one light at WOT but when you’re driving normal, it’s just fine. I remember throwing that same code when I owned my MS3 and it was just a vacuum/boost leak.
The question is, should I pick it up? I’ve seen a few with high mileage running just fine and have seen some with low mileage having a lot of issues. I was hoping a few MS6 guys would chime in with their opinions. If I pick it up, I already planned on changing the fuel pump internals, rear diff mount, engine/trans mounts. I just daily driving to be fun again yet reliable.
i <3 understeer...
boost makes for fast cars, understeer makes for fast drivers...
stars.eg6 is offline   Reply With Quote
 Old 03-09-2019, 04:37 PM   #2
jfspeed6's Avatar
Posts: 1,508   (View Stats)
jfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the world
I loved mine and had it for 9 1/2 years before selling it.
The major reason behind me selling it was the rust issues mine had but it went through salty New England winters.
Sent from my iPhone using Tapatalk Pro
2006 Titanium Gray Mazdaspeed6 GT
2002 Mercedes Benz CLK 430 Cabriolet
jfspeed6 is offline   Reply With Quote
 Old 03-10-2019, 05:22 PM   #3
stars.eg6's Avatar
Nice man, did you have any major problems with it prior to selling it other than dusting?
If the compression is good, I'd buy it.
I’m really thinking about it. Compression checked out, no play in the turbo shaft, just worried I won’t be able to track down the cause of the CEL right away. I guess I would be okay driving fighting the urge of going WOT until I fix it.
i <3 understeer...
Last edited by stars.eg6; 03-10-2019 at 05:22 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-10-2019, 07:39 PM   #4
jfspeed6's Avatar
I never really had any issues with mine. More general maintenance than anything. I did the upgraded VVT gear and timing chain before anything major happened.
I didn’t push it to its limits either. I was on an OTS Cobb tune.
 Old 03-09-2019, 08:22 PM   #5
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
 Old 03-11-2019, 10:08 AM   #6
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
If engine is solid, just consider doing the timing chain + VVT unless you confirm it was done.
I personally wouldn't rely on a 12 years old turbo car without a B plan to reach work if you need to drive there.....I have one and i also have a 2013 mz3 to carry the parts...
Having some spare money ready to throw at it isn't a bad thing either because you will need to repair/replace some 1 day or another...
If you don't thrust your right foot on the way back to stay out of boost, just disconnect the EBCS wire connector, it won't rise above 10psi....
Femelle title doesn't always mean grandma driven.......Or taken care of...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 03-12-2019, 01:29 AM   #7
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
it's gonna cost you a lot more than $2,000 to call it "reliable"
94 M
MS6
IS350
 Old 03-12-2019, 10:17 PM   #8
Jayzon's Avatar
Posts: 103   (View Stats)
Jayzon has disabled reputation
I say do it!
Back to Stock
Jayzon is offline   Reply With Quote
 Old 03-13-2019, 05:24 PM   #9
eroler1's Avatar
eroler1 is just really niceeroler1 is just really niceeroler1 is just really niceeroler1 is just really nice
what are the advantage of having a 6 vs 3?
AWD and no torque steer, any other else? performance wise....
eroler1 is offline   Reply With Quote
 Old 03-14-2019, 05:46 PM   #10
GohanX's Avatar
Posts: 62   (View Stats)
GohanX is a splendid one to beholdGohanX is a splendid one to beholdGohanX is a splendid one to beholdGohanX is a splendid one to beholdGohanX is a splendid one to beholdGohanX is a splendid one to beholdGohanX is a splendid one to behold
The cars handle completely completely differently, which one is better is up to the individual. I can't stand taking a high hp fwd car through a corner, but the 6 loves it want wants more.
GohanX is offline   Reply With Quote
 Old 03-14-2019, 07:14 AM   #11
Pu Manchu's Avatar
Groans: 546
performance wise a usable 2nd and 3rd gear is pretty much it, past that you're losing out from 10-15% more weight.
94 M
MS6
IS350
 Old 03-14-2019, 09:23 AM   #12
Jeff23spl's Avatar
¨^^^^This
I had a BT speed3 and before 80km/h(45-50mh) traction was the power limitation with 245 40 street sticky compound on a dry and sunny day...In the snow, the speed3 wasn't any faster than my 3gs with same tires...And the 6 was really fun to drive and..drift...
I got a ms6 to get rid of this lack of traction but i was used to a short and responsive car in traffic and the 6 is the opposite, (heavy and need more space and angle to turn and park.)
That weight come with benefits, traction but also ride confort and noise isolation is a lot better too.
You will definitely lose from a roll against a 3 with the same power or even with a 50hp difference...(unless 1 driver suck)
I don't know yet how would a BT 6 react to better compare but i hope to be able this summer with a new heart, lungs and clutch in it....
Wife drive 2010 CX7
 Old 03-14-2019, 02:02 PM   #13
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Most of my driving is below 50mph in suburb/city traffic. So the 6 is good for me. I occasionally let it flex on the highway though. The only time I'm ever annoyed about the extra weight is taking off from a stop.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 03-14-2019, 04:20 PM   #14
stars.eg6's Avatar
Thanks for the input guys. I’m not really concerned too much about being crazy fast. Just want to have some enjoyment on my daily commute and have a backseat that can fit normal sized humans. If I sell my Cressida this weekend, I’ll pick up the MS6.
i <3 understeer...
 Old 03-14-2019, 05:31 PM   #15
RazerX's Avatar
Posts: 9   (View Stats)
RazerX has a little shameless behaviour in the past
I think the 6vs 3 difference is not worth the money. Although, if money is not a prob for you, then why not?
RazerX is offline   Reply With Quote
 Old 03-15-2019, 07:39 PM   #16
eroler1's Avatar
i actually own both lol but never driven the 6 "yet" got a decent deal on a rolling shell (bolwn headgasket) and my ms3 used to have built block sleeved, etc but now I actually moved the build to ms6 so just wondering if i did the right thing, my ms3 is currently running with cx7 spare motor
rest is getting transplanted to six when tappets gets here.
all i know is when hitting 400 tq on speed 3 with 18x10 NT05 with all the mounts and traction bar, torque steer isnt fun.....
 Old 03-18-2019, 06:50 AM   #17
Jeff23spl's Avatar
Torque steer could be impressive but being safe to hold the steering and your coffee with the same hand while shifting under boost with the other is priceless...
Wife drive 2010 CX7
Is VIP worth it? bbay Mazdaspeed3/6 General Discussion 26 02-02-2015 01:25 PM
What's the OEM DP worth? TiGraySpeed6 MazdaSpeed 6 - Engine, Transmission & Driveline 19 01-01-2012 02:16 PM
tip really worth it? bohica17 2010 MS3 - Turbo Induction 20 07-08-2010 08:37 AM
is this worth it? yang_jackson MazdaSpeed 3 - Engine, Transmission & Driveline 18 05-27-2009 12:40 PM
Page generated in 0.37145 seconds with 29 queries
