![]() | | #1401 | ![]() |
| Not Ranked : 0 score As far as the tube breaking from vibrations, that tube is for a diesel engine, all those things do is shake. That said, my engine runs smooth as butter, it hardly vibrates at all.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | Code Monkey (09-14-2018) |
![]() | | #1402 | ![]() |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
| Not Ranked : 0 score Well look who decided to pop in for a quickey.
__________________ |
| The Following User Says Thank You to Tomas For This Useful Post: | Code Monkey (09-14-2018) |
![]() | | #1403 | ![]() |
| Not Ranked : 0 score MSF is my quicky headquarters..
| The Following 2 Users Say Thank You to 06Speed6 For This Useful Post: | Code Monkey (09-14-2018), Tomas (09-14-2018) |
![]() | | #1404 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well, I got a job offer from Atlanta I would be stupid not to accept. Making a move in a few months. Presented my shop with 2 choices: 1. Part out the car or sell as a whole with all the parts. 2. Put the fucking thing back together. We are going with option 2 for the time being so maybe I will finally start posting some real updates.
| The Following User Says Thank You to Code Monkey For This Useful Post: | phate (03-04-2019) |
![]() | | #1405 | ![]() |
| Not Ranked : 0 score Road Atlanta here you come. Maybe hit up VIR, CMP, Daytona and Sebring while you're at it. Oh hell, hit up my old home town track of Roebling Road too.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | Code Monkey (03-02-2019) |
![]() | | #1406 | ![]() |
![]() Join Date: Aug 2009 Location: Bryan/College Station, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 137
| Not Ranked : 0 score Or. You could just give t to me. I’ll take care of her.
__________________ 2009 Mazdaspeed with 134,000 miles, Corksport Turbo, AT internals, CNT Turbo Back, AP, fully mounted, 3 bar, Freaktuned E25. |
| The Following User Says Thank You to Jakeypoo For This Useful Post: | Code Monkey (03-02-2019) |
![]() | | #1407 | ![]() |
| Not Ranked : 0 score Congrats man, sounds like you are in my position, except I haven't been forced to put it back together!
| The Following User Says Thank You to 06Speed6 For This Useful Post: | Code Monkey (03-02-2019) |
![]() | | #1408 | ![]() |
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned | |
![]() | | #1409 | ![]() |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
Welcome to the south!
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // | |
![]() | | #1410 | ![]() |
(Thread Starter) | Not Ranked : 0 score I moved to Texas from Atlanta so I am going back to my old neighborhood, feels good. I am certain we will meet at some point, at this time I will be running and instructing primarily with Chin Track Days, after I settle down will try to pick up instructing with another group for a little bit of variety.
| Red Bull Racing drives world's highest road through the Himalayas | Haltech | Automotive News | 0 | 10-12-2011 12:50 PM |
| Everything youll want to know about road racing/autocross too | jroc | Auto-X / Road Racing / Time Attack | 18 | 05-21-2011 07:22 PM |
| Road Racing or HPDE Pics | chad | Auto-X / Road Racing / Time Attack | 23 | 04-17-2009 08:03 AM |
| Scion to go road racing in KONI Challenge | Haltech | Automotive News | 0 | 06-20-2008 05:50 PM |
