| Not Ranked : 0 score Congrats man, sounds like you are in my position, except I haven't been forced to put it back together!
| The Following User Says Thank You to 06Speed6 For This Useful Post: | Code Monkey (03-02-2019) |
(Thread Starter) | Not Ranked : 0 score I moved to Texas from Atlanta so I am going back to my old neighborhood, feels good. I am certain we will meet at some point, at this time I will be running and instructing primarily with Chin Track Days, after I settle down will try to pick up instructing with another group for a little bit of variety.
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
| Not Ranked : 0 score On the 3, Installed oil cooler first then Koyo rad. Oil cooler lowered oil temps. Koyo rad did not. Oil cooler not big enough to run less than 260F after 30 mins. Like Ziggo said stock brakes are just as good as BBK for track use. I have a Stoptech BBK and braking distance is not reduced compared to stock. They just weigh less and better wear pattern on the pads that's about it. Modulation worse than stock. They area bit more touchey. IMO too touchey. On the 6. Oil cooler installed. Even bigger than the one on the 3. No results yet. Bigger stock rad than the MS3 so upgrade may not be needed till you go up there in power. I have a Ron Davis rad on order anyway but may not be needed. Brake ducts not easily routed as in the 3. Bigger power steering cooler definetly needed no matter what power level you have. Stock is not even close to sufficient.
__________________ |
| The Following 5 Users Say Thank You to Tomas For This Useful Post: | Code Monkey (06-19-2014), Easter Bunny (06-20-2014), ItsNox (06-19-2014), phate (06-19-2014), Ziggo (06-19-2014) |
| Not Ranked : 0 score since *when was there such a thing as too touchy? Edit *when oh we arent talking about dicks, carry on.
__________________ I hugged rfinkle2 Last edited by Easter Bunny; 06-20-2014 at 08:11 PM. |
| The Following User Says Thank You to Easter Bunny For This Useful Post: | Code Monkey (06-20-2014) |
![]() Join Date: Sep 2013 Location: Heflin, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 803
| V2 Pre-amp | | |
| Red Bull Racing drives world's highest road through the Himalayas | Haltech | Automotive News | 0 | 10-12-2011 12:50 PM |
| Everything youll want to know about road racing/autocross too | jroc | Auto-X / Road Racing / Time Attack | 18 | 05-21-2011 07:22 PM |
| Road Racing or HPDE Pics | chad | Auto-X / Road Racing / Time Attack | 23 | 04-17-2009 08:03 AM |
| Scion to go road racing in KONI Challenge | Haltech | Automotive News | 0 | 06-20-2008 05:50 PM |
