 Old 01-16-2018, 05:53 PM   #1
Marcus's Avatar
Posts: 777   (View Stats)
Marcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the world
Default mini refurb ideas - input needed and welcome
With the amount of small ongoing issues the car has, it seems like I or the car can't wait for the built block.
I'm thinking of the following:
1: occ ,egr and pcv plate installed. Injectors and valves serviced.
2: cs turbo and im, maybe the down pipe and a stock like tune.
I doubt I'll do the down pipe as I don't want to add extra problems.
Idea is to cut down on oil leaks and smooth out the air flow. I'd like to do that all at once but I still need a new clutch. Dealership report after the purge valve replacement today mentioned multiple oil leaks so I need to clean those up and hopefully even limit them.
One question is should I bother with adding the new intake if/when the turbo goes on? Current one is fine and I won't be having a crazy tune sooo (probably not)?
As the title says, any input is appreciated.
2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km
Leakdown results was 50% or more across all four. slow rebuild in progress
Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses.
Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB.
SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate.
Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs.
To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters
Marcus is offline   Reply With Quote
 Old 01-23-2018, 04:45 PM   #2
KamloopsDan's Avatar
Posts: 64   (View Stats)
KamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to all
Greetings fellow BC'er!
I have a 2007 MSP6 that was completely stock until I bought it in 2015 with 49,000kms on it. The car was great stock, but just to make it even better I have added the following mods to it. Some mods for power, some for reliability.
I feel as though the only thing left that could go wrong on the car now (besides regular things that could go wrong on any car, suspension, brakes etc) is the turbo. For now the stock turbo does me OK.
Corksport Turbo Inlet & SRI
Fuel pump internals
ETS top mount intercooler
CP-E catless downpipe
Accessport & stratified tune
Oil catch can
EGR delete
intake valves walnut blasted
Corksport injector seals
step colder plugs
If you need the name of the guy who walnut blasted my valves, let me know. He lives in Tswassen.
KamloopsDan is offline   Reply With Quote
 Old 01-26-2018, 08:54 PM   #3
Marcus's Avatar
Fuel pump internals
Oil catch can
EGR delete
step colder plugs
Hello my interior friend!
I have most of the parts you listed (check the sig) on the car or almost on. Other than the plugs and tune but I was mainly curious what route I should go to basically baby this thing in its old age until I get shit sorted like a built motor. Currently, need to replace the front o2 sensor as its doing all sorts of different shit (bucking, loses power then jolts to life, combo of the two and worst of all, it makes look like a new manual driver - not my clutch either).
As for the guy in Tsaw, what was the cost if I may inquire?
One place to input your ideas regardless of how ghetto 08MS3-19.6PSI Appearance - SILVER 3 04-22-2012 11:21 PM
input needed glndrums MazdaSpeed 3/6 - Suspension & Brakes 0 04-10-2011 06:01 PM
EGR delete input needed madvillain MazdaSpeed 3 - Engine, Transmission & Driveline 55 05-26-2010 08:57 AM
Page generated in 0.23978 seconds with 21 queries
