 Old 03-06-2012, 03:55 PM   #1
Giantsrb45's Avatar
Posts: 43   (View Stats)
Giantsrb45 is on a distinguished road
Groaned at 22 Times in 10 Posts
Default Muffler
I have a 2008 mazdaspeed 3 with castles downpipe intake bov and stock exhaust. Since I have a cat less downpipe it spits out a lot of black stuff and staind my muffler... I can't find any websites that sell mufflers for a speed 3 does any one no if those exist
Giantsrb45 is offline   Reply With Quote
 Old 03-06-2012, 04:06 PM   #2
Speeden6's Avatar
Posts: 598   (View Stats)
Speeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the world
if you have a catless DP you need a new CBE in my opinion. dont waste your money replacing mufflers, get the right set up from the start. should have gotten one before the DP.
CORKSPORT 'Power Series' Mazdaspeed 3 Exhaust System
Speeden6 is offline   Reply With Quote
The Following 2 Users Say Thank You to Speeden6 For This Useful Post:
86AmishMs3 (03-10-2012), karl-hungus (03-07-2012)
The Following 7 Users Say NO Thank You to Speeden6 For This Un-useful Post:
abiezerf (03-08-2012), anavrinIV (03-13-2012), breakfstincluded (03-13-2012), btstarcher (03-13-2012), SWAY (03-13-2012), xfeejayx (03-08-2012), zpele (03-08-2012)
 Old 03-06-2012, 04:21 PM   #3
AZSPEED3's Avatar
Posts: 3,148   (View Stats)
Groans: 65
You need a tune if you do not have one. When I was stock I would get all that smoot shit on the back of the car too. Now with a tune, do not get it that much. Stock tune runs very rich.
 Old 03-06-2012, 04:27 PM   #4
MSMS3's Avatar
Posts: 2,830   (View Stats)
To actually answer OP's question, I am having some problem understanding how his muffler is getting black.
I have a catless dp/rp combo as in sig. I am running the stock CBE, because it has been shown time and time again to flow extremely well on the gen 1 Speed 3, so well so that aftermarket CBE's only change sound. The stock CBE's flow rate, even when behind a big 3 inch catless dp and rp, still outflows the maximum flow rate of the stock K04 turbo.
Now, having said that, I have 64,000 miles on my gen 1 MS3. All but about the first 15,000 has been with the catless dp/rp. My resos, my entire CBE, my muffler are all spotless. There is no black on my muffler.
Now, I do get some build up on the exhaust tip, and I do get some buildup of black stuff on the rear bumper and valance. But not on the muffler.
There must be something else going on.
And to replace the stock muffler, unless it's got a hole in it or has corroded through the shell (maybe salt on the road or something like that), seems an extreme remedy just because it has changed color. It's under the car and not visible.
The Following 2 Users Say Thank You to MSMS3 For This Useful Post:
abiezerf (03-08-2012), btstarcher (03-13-2012)
 Old 03-06-2012, 04:59 PM   #5
Squid's Avatar
Posts: 79   (View Stats)
Squid has a brilliant futureSquid has a brilliant futureSquid has a brilliant futureSquid has a brilliant futureSquid has a brilliant futureSquid has a brilliant futureSquid has a brilliant futureSquid has a brilliant futureSquid has a brilliant futureSquid has a brilliant futureSquid has a brilliant future
If not troll - search! Plenty of info on the forum. A better description would also help..
New one...
Crystal White Pearl Mazda 3 MPS ´09:
| Stock ATM |
Old one...
True Red Mazda 3 MPS ´07:
HKS SRI | JBR SSP Stage II + Heavy knob | 3" Corksport TBE | US-spec Tails | US-spec Spoiler | Turbosmart Dual-Port BPV | JBR RMM | CP-e Gaugepod | ProSport Premium/Peak Boostgauge | RallyArmour Mudflaps | CP-e Towplate | Autotech FP-internals | JBR RSB | NGK Iridium IX-plugs
Squid is offline   Reply With Quote
 Old 03-06-2012, 05:51 PM   #6
Speeden6's Avatar
my thought with the CBE is that with the new DP you are getting stronger compression and the old system has crap all in it and that is why it may be blackening.
I know that CBE is more sound that performance, just trying to help with what little knowledge i have. had this issue on a 240 and when i switched out the CBE it cleared it up.
 Old 03-06-2012, 10:11 PM   #7
Giantsrb45's Avatar
Sorry I meant to say my exhaust tip not muffler I thought they were the same thing... My car seems to run fine on this tune with the downpipe other than the blackness on the tip.... Does anyone sell new exhausttips
 Old 03-07-2012, 05:15 AM   #8
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
how about you clean your current exhaust tip more frequently.
The Following 2 Users Say Thank You to karl-hungus For This Useful Post:
Ms3_Miami (03-07-2012), Travis (03-07-2012)
 Old 03-07-2012, 12:29 PM   #9
MSMS3's Avatar
Very fine steel wool . . . furniture grade . . . 0000 is the number. Use that and a petroleum based solvent like kerosene, diesel fuel or even WD-40. Ought to get the job done. It's available anywhere, even Walmart, in the paint, stain, furniture refinishing department.
I actually replaced my stock tip with a single wall Magnaflow tip at the time I installed the downpipe. It's stainless and a little smaller than stock - 3.5 inches rather than 4.0 inches. It's a high polish finish and that's how I keep it clean and polished. You can get a mirror finish with that really fine steel wool.
 Old 03-07-2012, 01:01 PM   #10
Travis's Avatar
Posts: 2,296   (View Stats)
Travis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the worldTravis is the leader of the world
Groaned at 29 Times in 12 Posts
So much fail, clean your damn car. /thread.
1993 Mazda RX7 RHD Time Attack Build 2012 - On-going
2005 Mazdaspeed Miata - #1,116 - 15x8 949 racing 6UL, Bridgestone RE-11, Flyin Miata Intake kit, Ebay FMIC, Ebay DP, Flyin miata cat-back, flyin miata 02 modifier - 2014 - On-going
2011 Mazdaspeed 3 Feb 2011 - June 2014
Travis is offline   Reply With Quote
 Old 03-08-2012, 07:24 AM   #11
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Wenol metal polish will get the soot off the exhaust tip. It's not stained. If it's chrome or stainless steel, that shit can be cleaned off with a little elbow grease and a good metal polish.
noob.
07 MS3
The original Genpoo Hater
 Old 03-08-2012, 07:29 AM   #12
zpele's Avatar
Posts: 1,654   (View Stats)
zpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the world
Groans: 354
Groaned at 213 Times in 109 Posts
The stock exhaust should prolly flow fine to 400hp.
All op has to do is clean his damn car and get a tune.
2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now)
2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy
zpele is offline   Reply With Quote
 Old 03-10-2012, 03:37 AM   #13
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
This is not necessarily true, I gained data proven maf flow just from a catback.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 03-13-2012, 04:02 PM   #14
Giantsrb45's Avatar
S how much hp is gained from CAtback maybe with downpipe or maybe throttle response gets better? Idk this cars still fast without it i guess
08 speed 3, mazdaspeed intake, cs castless dp, stock exhaust, hks recirc bov, white on white on white
The Following User Says NO Thank You to Giantsrb45 For This Un-useful Post:
zpele (03-14-2012)
 Old 03-13-2012, 04:10 PM   #15
btstarcher's Avatar
Posts: 4,852   (View Stats)
Maybe 0 hp, or 1 or 2; nothing significant. HP gains come from the DP (cat removal).
SnailTune in progress
 Old 03-13-2012, 10:34 PM   #16
86AmishMs3's Avatar
Groans: 338
I gained a repeatable 3-4g/s after catback, no downpipe or racepipe. This is probably in the range of 4-6hp. Thank you very much bernouilli.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
btstarcher (03-16-2012)
 Old 03-13-2012, 11:53 PM   #17
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
New muffler on warranty eh?
Muffler delete IPuOnU 2010 MS3 - Engine, Transmission & Driveline 14 06-11-2015 07:57 PM
muffler help kevencola MazdaSpeed 3 - Engine, Transmission & Driveline 6 09-20-2011 11:09 PM
Muffler only mrmonk7663 Gen2 MS3 General Discussion 18 07-27-2011 09:30 AM
HKS Muffler phantomspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 5 04-19-2009 09:41 PM
Page generated in 0.39309 seconds with 31 queries
