 Old 02-04-2020, 10:33 AM   #1
cavin774's Avatar
Posts: 1   (View Stats)
cavin774 will become famous soon enough
I'm not on here often but for people who have their clutch fuzed (like me) and everything in together, wrangle some buddies to push start your rig in 1st (on concrete) get going 15 miles per and throw your clutch in and slam the brakes. Do it a couple times and the engine should pop that bitch loose. Low key sketch but it does work. !break in your clutch right after so it doesn't re stick!!!!!
cavin774 is offline   Reply With Quote
The Following User Says Thank You to cavin774 For This Useful Post:
Db09ms3 (02-04-2020)
Which Clutch / Flywheel? BuddySpeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 27 05-29-2016 03:33 PM
Oem clutch/Fidanza Flywheel, Causing sticky clutch pedal? Douggievee MazdaSpeed 6 - Engine, Transmission & Driveline 14 05-14-2015 10:44 AM
New OEM Clutch with Fidanza Flywheel Soft Clutch Feel zer010gic MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-15-2014 11:12 PM
clutch/flywheel bad??? stonecold0469 MazdaSpeed 6 - Engine, Transmission & Driveline 0 03-17-2013 10:01 PM
Page generated in 0.23069 seconds with 22 queries
