![]() Join Date: Mar 2016
Rep Power: 0 ![]() ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score 16144566_10154756337816136_18017297_n.jpg So, upon starting my car for the first time after the rebuild, the brand new Fidanza flywheel + brand new Luk OEM clutch disk have somehow managed to fuse together. It engaged and disengaged at first, then I backed it out of the garage, when I went to put it into 1st, the clutch no longer disengaged. (even installed a brand new clutch master cylinder) SUGGESTIONS PLEASE =D |
| Which Clutch / Flywheel? | BuddySpeed3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 27 | 05-29-2016 03:33 PM |
| Oem clutch/Fidanza Flywheel, Causing sticky clutch pedal? | Douggievee | MazdaSpeed 6 - Engine, Transmission & Driveline | 14 | 05-14-2015 10:44 AM |
| New OEM Clutch with Fidanza Flywheel Soft Clutch Feel | zer010gic | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 03-15-2014 11:12 PM |
| clutch/flywheel bad??? | stonecold0469 | MazdaSpeed 6 - Engine, Transmission & Driveline | 0 | 03-17-2013 10:01 PM |
