 Old 01-16-2017, 05:44 PM   #1
mazduhz's Avatar
Posts: 9   (View Stats)
mazduhz will become famous soon enoughmazduhz will become famous soon enough
Default My clutch is fused to the FLYWHEEL!
So, upon starting my car for the first time after the rebuild, the brand new Fidanza flywheel + brand new Luk OEM clutch disk have somehow managed to fuse together. It engaged and disengaged at first, then I backed it out of the garage, when I went to put it into 1st, the clutch no longer disengaged.
(even installed a brand new clutch master cylinder)
SUGGESTIONS PLEASE =D
mazduhz is offline   Reply With Quote
 Old 01-16-2017, 06:02 PM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Check that the slave is actually moving the clutch fork. You may have air in the system.
mazduhz (01-16-2017)
 Old 01-16-2017, 06:04 PM   #3
mazduhz's Avatar
I can't check that, the transmission isn't even on the car =P
and, as seen in the pic, I can't get the clutch disk off the flywheel, its like its welded on there, and I don't want to put too much force on it, I can feel it coming apart when I pull on it by hand
 Old 01-16-2017, 06:46 PM   #4
sheston's Avatar
Is that damage on the clutch disk? The only thing I can think of, but can't see in the picture is, are you sure it's not on backwards. Should say something like this side facing flywheel....
Are you sure they gave you the correct, matched parts? looks like the clutch disc could be wedged in the relief of the flywheel.
 Old 01-16-2017, 06:54 PM   #5
mazduhz's Avatar
There is no damage to the clutch disk, if you're referring to the mark on the top left of it, those are stamped white letters from the factory, I'd suppose some sort of manufacturing lettering. But, it is installed in the correct orientation (GETRIEBESEITE = Gearbox Side), so it's not jammed "inside" the flywheel at all. Even if it were installed backwards, the Fidanza flywheel allows it to be installed either way, because there is a large empty area in its center, unlike the stock flywheel, so that isn't the issue.
I will take a better pic of it tomorrow (daylight) to show it's installed correctly =)
thank you guys
 Old 01-16-2017, 07:23 PM   #6
mazduhz's Avatar
I will attempt to take the clutch disk off the flywheel tomorrow and report back.
 Old 01-17-2017, 06:23 AM   #7
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Some discs literally have a stamp to identify which side is suppose to go on the flywheel. Not all will specifically say it, like this one, but they generally have some sort of reference.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 01-17-2017, 03:55 PM   #8
mazduhz's Avatar
like I said, it doesn't matter which way you install it with a Fidanza flywheel, it's center cavity is deep and wide enough to clear the clutch either way you install it, though I DID install it facing the correct way, as seen in the pic
 Old 01-17-2017, 09:32 AM   #9
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Well I hate to state the obvious here, but you're going to have to find a way to brute force the disc off of there to figure out what went wrong. It could be a defect with the flywheel or clutch disc. We don't know.
2007 Mazdaspeed3 GT
 Old 01-17-2017, 04:51 PM   #10
mazduhz's Avatar
been cleaning....
some kind of weird gunk mixed with the green film...
 Old 01-17-2017, 05:50 PM   #11
tek_88's Avatar
Posts: 93   (View Stats)
tek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to behold
Groaned at 13 Times in 2 Posts
Seems like you forgot to clean the flywheel before installing. I know some companies but on some grease/light film of oil to prevent rusting. Or you may be having the same problem this guy ran into on his thread:
HOW-TO: MAZDASPEED3 REPLACE CLUTCH
2006 Titanium Grey MS6
Power
BNR S3 // Stock downpipe (hollowed) // Test pipe // Magnaflow CBE // Cp-e Tmic // 3" HTP // JBR Boost Tubes // JBR Thermal Gaskets // 3Bar Map // Corksport BPV // Egr Block-off // VTCS Disabled // AEM 100% meth (1000cc nozzle) // Cobb Ap V3 // Autotechs // GS 3-port // NGK 6510 // CA 91 oct
PurpleDrank Tuned by Will
Hardware
Cp-e Rear Diff Mount // SURE Juggernaut Front Diff Mount // AWR PMM // Cp-e RMM // Corksport TMM Inserts // DSS Axles // ACT 6-puck w/ Streetlite FW
Cosmetics
TRS Retrofit Bi-Xenon Projectors // 18x8.5 +35 XXR 557 // H&R Lowering Springs // S204 Lip
tek_88 is offline   Reply With Quote
 Old 01-18-2017, 05:13 AM   #12
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Yeah, did you wipe down the flywheel with brakeclean before installing?
Rich Tuned
330WHP and 363TQ
The Following 2 Users Say Thank You to CWP_MS3 For This Useful Post:
MD1032 (01-18-2017), meicalnissyen (01-18-2017)
 Old 01-18-2017, 12:34 PM   #13
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
I can't post at work, but I cam PM (VA firewall)
I sent this to our young padawan yesterday
I cant post at work, but PM works.
I would push and pull on the disc hub, while feeling for ANY movement of the hub on the spline.
if you can feel slight motion there, then you have some super odd adhesive effect between the friction matl, and the surface of the flywheel. I would try a liberal brakleen shot, etc
If there is no movement, and you can gently slide a thin blade knife between the disc and flywheel, then you have stuck the splines on the input shaft.
try to rig a puller onto the hub someway, and pull it off that way.
grab the hub as clos to the center as possible, and resign yourself to getting a new disc anyway, proly has a mismachined spline."
Looks like "A" was the issue
The Following User Says Thank You to meicalnissyen For This Useful Post:
CWP_MS3 (01-18-2017)
 Old 02-01-2017, 08:37 AM   #14
bigspender's Avatar
Posts: 854   (View Stats)
bigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the worldbigspender is the leader of the world
Groaned at 46 Times in 21 Posts
Originally Posted by mazduhz View Post
Attachment 230343
My mechanic had the same issue. He cleaned off the green stuff and is about to put everything back together. Did that solve your issue?
Thanks.
bigspender is offline   Reply With Quote
 Old 02-01-2017, 08:44 AM   #15
mazduhz's Avatar
Yes, I cleaned all the green off mine, and thoroughly scrubbed both surfaces with a scratchpad and brakeclean, works normally now =)
The Following 2 Users Say Thank You to mazduhz For This Useful Post:
bigspender (02-01-2017), CWP_MS3 (02-01-2017)
 Old 02-01-2017, 08:45 AM   #16
bigspender's Avatar
Thanks!
The Following User Says Thank You to bigspender For This Useful Post:
mazduhz (02-01-2017)
 Old 02-04-2020, 10:33 AM   #17
cavin774's Avatar
Posts: 1   (View Stats)
cavin774 will become famous soon enough
I'm not on here often but for people who have their clutch fuzed (like me) and everything in together, wrangle some buddies to push start your rig in 1st (on concrete) get going 15 miles per and throw your clutch in and slam the brakes. Do it a couple times and the engine should pop that bitch loose. Low key sketch but it does work. !break in your clutch right after so it doesn't re stick!!!!!
cavin774 is offline   Reply With Quote
The Following User Says Thank You to cavin774 For This Useful Post:
Db09ms3 (02-04-2020)
Which Clutch / Flywheel? BuddySpeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 27 05-29-2016 03:33 PM
Oem clutch/Fidanza Flywheel, Causing sticky clutch pedal? Douggievee MazdaSpeed 6 - Engine, Transmission & Driveline 14 05-14-2015 10:44 AM
New OEM Clutch with Fidanza Flywheel Soft Clutch Feel zer010gic MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-15-2014 11:12 PM
clutch/flywheel bad??? stonecold0469 MazdaSpeed 6 - Engine, Transmission & Driveline 0 03-17-2013 10:01 PM
Page generated in 0.36108 seconds with 29 queries
