![]() Join Date: Jun 2012 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 96
(Thread Starter) | Not Ranked : 0 score Inspired by the way the Dashhawk can be mounted, I decided to make my own! I went to home depot and picked up a metal bracket, cut it to size, plasti-dipped it for the color and to cover the sharp edges, cut out a piece of the plasti-dip so I could add velcro and... done! The bracket is just pressed in and stays pretty well. It's still within normal driving view but also doesn't block anything. Overall, a cheap but seemingly effective mounted method!
__________________ 06 LPM MS6 GT ~ COBB AP (OTS Stage 1) ~ SURE SRI ~ Corksport TIP ~ CPE TMIC ~ Autotech Fuel Pump Internals ~ SU Test Pipe ~ SURE RMM ~ SURE SSP ~ SURE Counterweight ~ NGK Plugs 07 Kawasaki Ninja 650R ~ Yoshimura Exhaust **Sold** 04 Mazda 6s |
| The Following 7 Users Say Thank You to CU_Slik For This Useful Post: | Awal (04-30-2015), darkcherry (08-25-2012), greenespeed (08-25-2012), jfspeed6 (08-25-2012), JLuth (08-27-2012), jrlms6 (08-25-2012), mxlplx71 (08-25-2012) |
![]() Join Date: Jul 2011 Location: Chattanooga, Tn
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score Nice idea. I have been wondering how hard it would be for someone like @Block8head to take a cp-e or lotek 3 gauge center pod and form one of the holes to work for an ap instead.
__________________ [SIGPIC][/SIGPIC] 2006 Mazdaspeed6 BCM GT MODS : Cobb AP // Cobb SF // Sure TIP // JBR RMM // JBR SSB // JBR SSP // Magnaflow CBE // MSR 045 18 X 8 +35 // ACT ZX5-HDG6 // M2 3" catless DP // AT HPFP Internals // NGK's -- FREEKTUNE in progress Having a 12 second Honda is just like coming out of the closet; You're going to surprise a bunch of people, but in the end you're still gay. |
| The Following 2 Users Say Thank You to greenespeed For This Useful Post: | CU_Slik (08-25-2012), darkcherry (08-25-2012) |
(Thread Starter) | Not Ranked : 0 score Yeah that would be nice. It would look a lot cleaner too.
![]() Join Date: Nov 2010 Location: Dartmouth, Massachusetts
Rep Power: 325 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 613
| Not Ranked : 0 score I like it. How does this mount exactly? What kind of bracket is it?
__________________ 2006 Mazdaspeed6 GT - SOLD ![]() Titanium Gray Metallic SURE Aeros | SURE Sidewinder Forge V1 | CPE TMIC Magnaflow CBE | Corksport DP | TXS RP COBB AP | Autotech Internals JBR SSP | JBR Shift Weight | JBR Knob Denso ITV22 2012 MS3 w/Tech - Hit and traded Velocity Red Mica COBB SRI | COBB TIP 2006 Mazdaspeed6 GT - Totaled Liquid Platinum Metallic CS Stage 2 | COBB AP | CPE HPFP 2006 Mazdaspeed6 GT Black Mica CS Stage 2 | CS BPV | CS TBE COBB AP | CPE HPFP | CPE TMIC DM RMM |
![]() Join Date: Feb 2009 Location: Atlanta Ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,123
| Not Ranked : 0 score Yea I don't understand how this works. |
![]() Join Date: Jun 2011 Location: Olympia, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 133
Groans: 58
Groaned at 134 Times in 68 Posts
| Not Ranked : 0 score Wish my car had that mileage.
__________________ US ARMY 07 True Red MS3 //Fully Bolted-Dizzy Tuned Wife drives the Speed now, I caught the gay, miata for me. 96 Red Miata // Not stock** Missing home... Florida ![]() |
(Thread Starter) | Not Ranked : 0 score I just press the bracket into the little slot next to the center display area (no idea what it's called). The pic is some random interior, but the arrow is pointing to what I'm talking about. The bracket is just a thin, metal L-bracket. I found it among various shapes of brackets for woodworking, I'm guessing. I plasti-dipped it (particularly the part that is pressed into the slot) so it wouldn't scratch anything.
![]() Join Date: Aug 2013 Location: Eugene, OR
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score What dash kit are you using for your head unit installation? |
![]() Join Date: Nov 2013 Location: Miami
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 108
| Not Ranked : 0 score Looks good
__________________ Injen CAI |
| Revised VC OCC Mounting Bracket | MSP6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 0 | 06-22-2012 09:45 AM |
| DO 3 quart bracket design and mounting location. | WillyH | 2010 MS3 - Fuel, Nitrous & Water Injection | 33 | 08-21-2011 02:12 PM |
| AP mounting bracket | seanmiller09 | MazdaSpeed 3 - How-To's | 0 | 05-30-2010 09:58 PM |
