 Old 04-02-2018, 07:04 PM   #1
Itzkwayzz's Avatar
Posts: 2   (View Stats)
Itzkwayzz is an unknown quantity at this point
Default Need help with front passenger axle
Hello fellow mazdaspeed owners
I am new and hope someone can help me
I haven’t been able to find anything to help my situation. But anyways, my passenger front cv shaft needs to be replace. I ordered a Heri cv shaft from rockauto.
Does the passenger size suppose to have a retainer clip?
If it does, the new axle and broken axle doesn’t have a slit for the clip to sit in. Unless it sit all the way at the end when the spindle ends on the axle.
I tried to see if I can the clip to catch the way to get end axle, but that didn’t work because the tranny spindle it’s the end of the axle before the clip in which I can’t push anymore.
Thanks for the help!
Itzkwayzz is offline   Reply With Quote
 Old 04-02-2018, 08:29 PM   #2
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
No clip on passenger side.
 Old 04-02-2018, 09:21 PM   #3
Itzkwayzz's Avatar
So the slit on the spindle coming from the tranny is just there ?
Passenger front axle makes noise only when cold HELP! TinyVoices MazdaSpeed 6 - Engine, Transmission & Driveline 2 12-19-2015 05:07 PM
Front Passenger Axle leak question GTK7 MazdaSpeed 6 - Engine, Transmission & Driveline 0 06-11-2013 08:06 AM
Replacing the front passenger axle, control arm and tierod. Peterspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 0 07-02-2012 10:03 AM
klunking in driver front stealership told me front axle carrier never heard of such a part gotgrip MazdaSpeed 3/6 - Suspension & Brakes 6 02-25-2011 11:34 AM
Page generated in 0.22876 seconds with 21 queries
