| Banned ![]() Join Date: Aug 2009 Location: San Diego, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 158
Groaned at 69 Times in 65 Posts
(Thread Starter) | Not Ranked : 0 score We will keep everyone apprised as to the outcome. |
| The Following 6 Users Say Thank You to E4Performance For This Useful Post: | bioevolve (03-04-2010), BolvangaR (03-05-2010), JBR (03-09-2010), MPSdriver (05-04-2010), Sacrilicious (03-04-2010), Silver Ecstasy (03-05-2010) |
![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 61
| Not Ranked : 0 score Looking forward to this! Hey man how far in do your knobs thread? Is it like the TWM where you can screw it pretty much all the way down?
__________________ Smoking Car FTL =( |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score I'de interested if it's the same price and the coating is durable.
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
![]() Join Date: Jan 2009 Location: San Antonio, TX.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 212
Groans: 90
Groaned at 69 Times in 21 Posts
| Not Ranked : 0 score ^ +1 I wouldn't mind a nice shift knob that didn't double as a lighter in the heat |
![]() Join Date: Dec 2009 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29,434
Groans: 40
| Not Ranked : 0 score I'd be game as well. I hated my TWM this past winter in freezing my hand so bad it felt like it was burning, not a big fan at all. Not really looking forward to this summer either when its hotter than the depths of hell and really does burn my hand.
__________________ | Steedspeed Top Mount Mani | Precision BB 5857 | Perm Tuning 3.5" Intake | Perm Tuning 2 Piece DP | Perm Tuning PCV Plate and Vented Catch Can | Mishimoto Catch Can | Weisco Pistons | Pauter Rods | AWR Tranny Mount | CP-e RMM | Turbinetech FMM | Turbinetech FDM | CP-e RDM | CX Racing FMIC | TWR Short Shifter | JBR SSP | AP w/ Base Map | BLOWN MOTOR | | 1974 Nova | SBC 350 | TH350 | Weiand Team G | Edelbrock 1406 | Aluminum 4 Core Radiator | Pro Comp HEI Distributor | |
It will be the same price. We're testing durability now. Last edited by E4Performance; 03-04-2010 at 09:21 AM. Reason: MSF Database - Automerged Doublepost | |
Groans: 40
| Not Ranked : 0 score woohoo! Are you still gunna do different designed knobs as well? Or did that just kinda die off?
(Thread Starter) | Not Ranked : 0 score We're looking at different designs. First, I want to get the current design squared away in terms of engraving depth and width. Then, I want to get the coatings squared away. Then, finally, I can look at another model. |
Groans: 40
| Not Ranked : 0 score Sounds like a good progression to me! Props tho for something new as far as heat and cold.
| Not Ranked : 0 score +1 for looking into insulating knobs, mine is starting to look like ass but I dont want to replace it with one that looks good but burns me.
![]() Join Date: Aug 2008 Location: Pittsburgh, PA
Rep Power: 637 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,048
| Not Ranked : 0 score i'm interested in this as well. the hot shift knob doesnt bother me so much as the freezing cold one. but either way, one that was even just a little less temperature sensitive would be worth the cost. so good luck with this. a weighted shift knob helps a lot imho, and i'm already interested in trying your product. this would just be icing on the cake. if it works! so i'm subbin. |
(Thread Starter) | Not Ranked : 0 score Well, I can say that it definitely cuts down on the temp swings. I am more interested in durability. That's what I am testing for. |
| Not Ranked : 0 score If the coating doesn't work out would leather wrapping be an option?
(Thread Starter) | Not Ranked : 0 score Well, it appears that it's not holding up as intended. If your knob with rubberized coating is peeling, please contact us for a replacement. Thanks Scott |
![]() Join Date: Jun 2009 Location: NoVa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 410
Groans: 38
| Not Ranked : 0 score hey scott, i'm still looking for a stainless steel version. Any plans to make one? |
Shift Knob and Shifter Weight - E4 Performance | |
(Thread Starter) | Not Ranked : 0 score I want to bump this back up. We're going to begin shipping the new ones on Friday with the revised coating. If your knob is peeling please email me to get return instructions so I can ship out your new one asap. Thanks Scott (email in sig) |
![]() | | #19 | ![]() |
| Not Ranked : 0 score so, the new coating is holding up? |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score yes. That was part of the delay was making sure it was going to be good to go. It's 100% ready for a long life of service. |
![]() | | #21 | ![]() |
| Not Ranked : 0 score glad to hear the coating is holding up. now the question is, does it help. how well does it reduce temp transfer. |
![]() | | #22 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score how do i get a rubberized knob, what do they look like?
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
![]() | | #23 | ![]() |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3168 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score yeah can we get a pic. I'll definitely buy one if one or two more guys can say its holding up and cuts the heat down
__________________ '08 CWP MS3 w/ T3 3071r |
![]() | | #24 | ![]() |
![]() Join Date: Mar 2010 Location: Colorado Springs, CO, USA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,160
Groans: 201
| Not Ranked : 0 score I have the new, black rubberized one and it's GREAT. Been on the car a week or so, and it's holding up perfectly. The knob is heavy, but I prefer that with the JBARONE SSP, as it provides just the right weight for slipping into gear. I don't usually photograph my knob for strangers on the internet, but here it is: ![]() ![]() Sorry the pics kind of suck. My 7MP camera isn't as good as it claims to be. The pics in this thread are better: look at pics of my knob
__________________ Stealth01 2006 Mazdaspeed6 GT Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG Read my stories: https://www.smashwords.com/books/view/55318 Last edited by Stealth01; 05-03-2010 at 09:50 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to Stealth01 For This Useful Post: | 802MS3 (05-04-2010) |
![]() | | #25 | ![]() |
Groans: 78
| Not Ranked : 0 score I want some input on how it cuts down on heat. I wantz shift knob but they're unbearable here in az during the summer. |
![]() | | #26 | ![]() |
Groans: 201
| Not Ranked : 0 score Still snowing here, so I can't tell you how hot it gets. Supposed to be 80 Wednesday...I'll post at the end of the day. But it is still a black knob...the black leather got REALLY hot, so I suspect black rubber will too.
__________________ Stealth01 2006 Mazdaspeed6 GT Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG Read my stories: https://www.smashwords.com/books/view/55318 |
![]() | | #27 | ![]() |
Groans: 78
| Not Ranked : 0 score Lawl, 80, I hate you. |
| The Following 4 Users Say Thank You to madvillain For This Useful Post: |
![]() | | #28 | ![]() |
| Not Ranked : 0 score ^^^^^^^^^^^ WAAA, where you at? on the sun? |
![]() | | #29 | ![]() |
Groans: 201
| Not Ranked : 0 score We had a SCORCHING 70 degrees today, and sitting in the sun, the knob got....hot. Not unbearable, but hot. However, durability-wise, it is holding up WELL.
| shift knobs | barcainho | MazdaSpeed 3 - Engine, Transmission & Driveline | 23 | 04-16-2009 08:44 PM |
