![]() Join Date: Feb 2015
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Hello this is my first post and just bought a Mazdaspeed6 about 2 months ago Before the "use search" people come in, I'm just looking for basic mods and keep a nice cheap modded mazdaspeed6 and all the searching I've done hasn't answers the specific I'm looking for. I used to own a 2003 mach1 mustang but totaled it due to black ice, had $8000 in mods, RIP, so I'm not looking to go hard core on this car, in basically looking for mods were I don't have to do anything major like the HPFP. I bought 2007 mazdaspeed6 completely stock, and so far I'm loving it l. I have done one mod and that's the JBR stage 2 ram air and turbo inlet. I'm trying to see were I max out. My next mod I was thinking was a Cobb AP canned tune, and maybe some kind of exhaust mod like a test pipe or weld in straight pipe (I own a welder). Again, just looking for the basic bag for your buck mods. Any mod that exceeds the HPFP or anything like that is to much. Just a slightly modded DD is what I'm looking for. |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| The HPFP is a wise thing to get, even if you're not planning on going full retard building this car. Even with an intake and tune you can overtax the OEM HPFP. Furthermore, I wouldn't call it "major," as once you know what you're doing, the swap takes about 1/2 hour or so, and you don't have to pull much of anything off to get at it. Also, instead of "use search," I would highly recommend using Google with "site:www.mazdaspeedforum.org/forum" and then enter your search terms. (i.e. "site:www.mazdaspeedforum.org/forum HPFP how to") The search function here on MSF is terrible.
| The Following User Says Thank You to Vansquish For This Useful Post: | Easter Bunny (02-22-2015) |
(Thread Starter) | Not Ranked : 0 score It was wishful thinking that i didn't need a HPFP so if I need to I will, what's a a good brand? |
![]() Join Date: Nov 2014 Location: Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
| Not Ranked : 0 score Autotech internals are very popular. But there are other brand there as well.
__________________ 2008 Metro Gray Mica Speed 3-SOLD Corksport SRI Corksport TIP JBR 80 duro RMM Cobb AP v3 Autotech internals CX Racing FMIC SPC rear camber arms Hawk HPS pads front and rear FREEKTUNE OTS+ 1998 Civic - SOLD2011 Speed3 200k+ miles Stock -Daily |
| I would recommend Autotechs over all others, simply because there are more people running them than any other brands, and they seem to have had the lowest percentage of failures. That said, once you upgrade the HPFP internals, you're likely to eventually destroy the Fuel Rail Relief Valve (HPRV) because its crack pressure is lower than what the upgraded HPFP internals can provide, and it will be opening more frequently than it is intended to have to.
(Thread Starter) | Not Ranked : 0 score Just to make sure everyone knows again, I'm not looking for major mods. If possible I might not even mod the exhaust. A tune is a hopeful mod I really want to get but if things are to expensive then I'm not going to do them, so fuel rail valve of needed to be replaced after the HPFP then I'm not interested in modding anymore. if I all I have is RAI and TUrbo inlet then so be it. Is there any cheap exhaust mods (cat remove or mufflers) that won't cause extra fuel load. Just looking for an aggressive sound but not really loud, almost stock sounding while cruising but aggressive when getting on it. But still without major upgrades. Again forgive me for being noobish with these cars. Had no idea of HPFP or rails when I bought this car. Was looking for a nice DD and it was this or a subaru legacy with a few less miles. Didn't have much time to look at anything more. Free Insurence rental was coming to an end. |
![]() Join Date: Nov 2012 Location: Leominster Mass
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,003
| Not Ranked : 0 score The fuel rail valve isn't something you need to upgrade. It's one of those things that it might shit out on you but doesn't seem to happen all that often. At least in my area im pretty sure I'm the only one that had to change it out of the 30 or so people. If you go VIP you can gain access to the for sale section. From there you can get a used cobb accessport v2 for around $300 or buy one new from edgeautosport or RPM and an e-tune from one of the tuners on the forum are $200 i believe. The speed6's are usually ok for the stock fuel pump with an intake and test pipe, as long as you dont change out the down pipe. You could also just delete a resonator and leave the cats if you're just after sound. That being said, the fuel pumps are kind of on their own. There's not a certain point where you need to change it or not, it goes when it goes which is why people recommend it be one of the first few mods. Also, check out the rear motor mount as well. |
| The Following User Says Thank You to brandonnicholson For This Useful Post: | memin (02-22-2015) |
| Not Ranked : 0 score Welcome! Always nice to have another Speed6 around! There are two things to be aware of re: HPFP- First, they weren't especially capable when new, and yours is now ~7 years old and correspondingly even less able to handle stress. Second, the HPFP needs to keep up with air flow. As you're considering both intake and exhaust mods, and those both result in more air flow through the engine, then you'll be putting more stress on that old & worn HPFP to deliver more fuel. Consider it like a tax- it's a mod you should do. Additionally, the stock K04 turbo relies on back pressure to maintain seal integrity. By opening up the exhaust it's possible that you may start seeing smoke out the exhaust while at idle. Removing the secondary cat is often safe as the primary cat typically creates enough back pressure, but the overall theory is one you should be aware of in case the symptom rears it's head. Picking up an AccessPort (AP) is very very highly encouraged not only for the ability to change maps but for it's ability to log, allowing you to learn about your engine health and, if needed, to share those logs here where others can review data and provide insights. Aside from these you may want to consider some basic old age maintenance items- new fluids front to back, brakes, suspension, mounts & bushings etc. It's encouraged to get the car stable and solid, and invest some money into basic maintenance first. Once you know you're stable & safe then chase mods.
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq Last edited by TiGraySpeed6; 02-22-2015 at 12:49 PM. |
![]() Join Date: Jan 2014 Location: Marysville, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score You don't want to upgrade internals? Then just an intake. and maybe remove the mufflers for sound and slight performance, but without a moderate tune those upgrades don't do much.
__________________ 2007 Black Mica Mazdaspeed6 AutoTech HPFP Internals COBB AP w/ stage 2 ~ Shifter Weight CorkSport Front Mount Kit CP-e CBE Single Exit Exhaust Koni Yellows |
![]() Join Date: Feb 2014 Location: TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,527
Groans: 64
| Not Ranked : 0 score Most of the vendors here offer great deals when you purchase the AP and Autotech Internals together. Best sub 1000 dollars you will spend on the car IMO. These two mods offer safety, the ability to monitor/tune, and WHEN you change your mind and get the itch for more power these will be beneficial. Fuel pump isn't as difficult to get to as it may seem. I think most would agree not to mess with the exhaust without these mods. If you just want sound hack off the resonators in the exhaust and weld straight pipe there.
__________________ ~2013 BLACK MS3~ COBB: (APV3//Exhaust Hangers) CS: (TMIC//RP//Leather Knob//Battery Box//Interior LEDs) JBR: (3" SRI//80 Threesome//SSP//SSB//TB TIG//Coolant Bypass//Rice Flaps, EGR delete, OCC) Magnaflow CBE//GFB BOV//FREEKY DEEKY OTS+ 》》》SUPPORT YOUR MSF VENDORS《《《 |
![]() Join Date: Sep 2012 Location: Elizabeth, NJ
Rep Power: 3180 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,265
Groans: 665
| Not Ranked : 0 score Just keep your car stock bro. You want to play, but you don't want to pay. Modding is not for you. |
| The Following 8 Users Say Thank You to Agent_Orange For This Useful Post: | Code Monkey (02-22-2015), CWP_MS3 (02-24-2015), Easter Bunny (02-22-2015), Gitcherex (12-11-2015), mride23 (02-24-2015), ms6mil (02-24-2015), Scare Dem (02-22-2015), Vansquish (02-24-2015) |
I guess if I have to do a HPFP just to get my fix then I guess I have to | |
![]() Join Date: Aug 2013 Location: Jax, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 85
| Not Ranked : 0 score Is there a such thing as slightly modding this platform, one thing always leads to another! Good luck
__________________ 2007 Black Mica Speed3 speedperf6rmanc3 built short block >> Manley H-beam rods >> Wiseco pistons >> BNR stage 1 >> Cobb sf intake >> Corksport TIP >> ISC coilovers >> Autotech hpfp >> Forge V1 BPV >> jbr stage 2 occ >> jbr 88d RMM >> UR tp >> CNT cat back exhaust >> Cobb AP >> Richtuned by Anthony |
| Not Ranked : 0 score Just stick to rims and tint then.
![]() Join Date: May 2010 Location: Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 848
| Not Ranked : 0 score I don't see what the big deal is, especially since you already expressed an interest in purchasing a Cobb AP. Most of the vendors here sell the AP and Autotech HPFP internals as a package deal. -- Buy those together and save some cash (you could also go VIP and try to buy them used) -- Gut your 2nd cat if you're trying to be cheap. ...you already have the JBR Power Path Stage 2 intake, right? FREE Stratifed OTS map: Stratified MazdaSpeed / Mazda MPS Off The Shelf (S-OTS) Maps [Stratified Mazda S-OTS Maps] - It's Free! : Stratified Automotive Controls Done. |
| The Following User Says Thank You to frothy For This Useful Post: | Easter Bunny (02-23-2015) |
![]() Join Date: Jul 2011 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
| Not Ranked : 0 score You're looking at it from the wrong angle. It's not that these simple mods do so much that they blow away a stock fuel pump, it's that in the case of the speeds/MZR's the stock fuel pump kind of sucks donkey dick from the factory. If you bought your Mach 1 with 6" rear tires would you change them, or leave them because you didn't "have to" change them? There's been a few sets of used autech internals on here going for $300 or less. The only difficult thing about changing the pump is finding the wierd little torx socket you need. Aside from that, replacing the inlet tube on your intake is more of a PITA than internals.
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." |
![]() | | #19 | ![]() |
![]() Join Date: Mar 2014 Location: Barre, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 344
| Not Ranked : 0 score If you plan on doing internals RPM is doing a tax season sale that will get you new internals at the price of most used.
__________________ 2015 Mazda 3-slow 99 Brilliant Black Miata- slow too |
![]() | | #20 | ![]() |
| Not Ranked : 0 score As previously stated: google.com site:www.mazdaspeedforum.org/forum do I need internals site:www.mazdaspeedforum.org/forum first mods site:www.mazdaspeedforum.org/forum test pipe site:www.mazdaspeedforum.org/forum MS6 exhaust read, everything you are asking has been asked 10,000 times by 10,000 n00bs before you. Your car is no different than any of the 10,000 cars prior.
| The Following 4 Users Say Thank You to dale_gribble For This Useful Post: |
![]() | | #21 | ![]() |
![]() Join Date: Mar 2014 Location: NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 77
| Not Ranked : 0 score Like everyone else has been saying... HPFP internals, get them. First mods I did to my car were SRI/TIP. Wasn't able to monitor my fuel pressure till a few months later when I got my AP. Luckily when I was able to monitor it the pressures were fine but then out of nowhere the pump started to not be able to keep up. You may be "ok" for now but you really should get them. Never know when they'll just give out. A tune can definitely help open your car a bit. There's tons of great e-tuners on the site, search for them one choose one you like. Also, you may want to look into getting a RMM. The stocker is garbage. You'll no longer feel the 1-2 shift thump of the engine
__________________ 2006 TGM MS6 HTP 3" | Corksport TBE | CP-E TMIC | JBR Boost Tubes | Autotech Internals | Freektuned | CP-E Rear Diff Mount | SURE Juggernaught | JBR RMM | CS TMM Insert | Damond SSP | JBR Shifter Bushings | Damond OCC | Damond Banjo Bolt | Block8head Vent Pod with Defi Red Racer Boost Gauge[/I] |
![]() | | #22 | ![]() |
![]() Join Date: Jun 2014 Location: Westminster, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43
| Not Ranked : 0 score Fast. Cheap. Reliable. Pick two.
__________________ 06 MS6 Sport,ZZB and warranty motor replacement 8/9/14 SU SRI w/ COBB MAF:::JBR TIP:::JBR 80aTRILOGY:::Strat+ Base Map:::MATT DAMOND FULL EGR DELETE:::VTCS Delete:::CP-E SafeSeals [SIGPIC][/SIGPIC] |
| The Following 2 Users Say Thank You to phecker410 For This Useful Post: | CWP_MS3 (02-24-2015), dale_gribble (02-24-2015) |
![]() | | #23 | ![]() |
| Well...I've spent an average of about $550/year on repairs/modifications in the 6 years that I've owned my car. That's not SUPER cheap, but given the fact that the transmission has been out of the car, and the transfer case has been out of the car, and that I've had blown struts replaced, and that the rotors were replaced and the pads have been done twice, and that I've replaced the turbo with a bigger one, I'm not convinced that this is "truly" an expensive car to have fast, cheap, and reliable. Most of the major maintenance shit had to get done around 60k miles. The rest of it has been all on me. I've also saved a shit-ton of gas money by having an AP. I get ~18.5% better highway fuel economy than I did stock, and ~16% better in the city. Over the last ~78k miles, that's saved me around $1600. If you're mindful of what you're doing, there's no reason that this can't be a (relatively) cheap, fast, and reliable vehicle, especially if you buy parts used.
| The Following 3 Users Say Thank You to Vansquish For This Useful Post: |
![]() | | #24 | ![]() |
| hidin in yo bushes ![]() Join Date: Mar 2012 Location: Soviet Maryland
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| Guy basically stated he was going to be too lazy to search, and not to tell him to search. You guys were awful nice. lol
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| The Following 4 Users Say Thank You to CWP_MS3 For This Useful Post: |
| Getting a Key for 06 Mazdaspeed6 | 06MazdaspeedNYC | Mazdaspeed3/6 General Discussion | 5 | 01-06-2013 05:50 PM |
| mazdaspeed6 MBC | boosted_speed6 | MazdaSpeed 3/6 - Turbo Induction | 6 | 03-24-2011 06:07 PM |
| BBK for Mazdaspeed6 | Magier | MazdaSpeed 3/6 - Suspension & Brakes | 7 | 03-01-2011 12:54 AM |
