 Old 06-23-2008, 08:49 AM   #41
ATE BALLER's Avatar
Posts: 3,227   (View Stats)
ATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the world
I have an ms6. Should I wait until you verify the pinout or whatever, or should I jump in on this list? Do you think you should test it on a 6?
Originally Posted by StreetUnitMark View Post
I don't think I could go one day without some sort of meat in my mouth.
ATE BALLER is offline   Reply With Quote
 Old 06-23-2008, 09:08 AM   #42
94jedi's Avatar
Posts: 2,200   (View Stats)
94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world
Groaned at 7 Times in 5 Posts
Definitely throw me on the list for the WOT/2-step version. I would like to see detailed install instructions before making final payment though.
94jedi is offline   Reply With Quote
 Old 06-23-2008, 09:22 AM   #43
ultraspeed619's Avatar
Posts: 268   (View Stats)
ultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the world
+1^^^ I have a ms6 aswell and would love to purchase this! Hopefully it works with our cars too...
MAZDASPEED6
Engine: Cobb SRI/AP | CPE FMIC/DP/MM/HPFP | MagnaFlow 3in CBE | HKS TwinPower Ignition | Denso plugs |
Suspension/Wheels: SSR GT10 19x8 +37 | RPM Street Springs | AutoExe F/R braces | WhiteLine RSB | GT Spec Ladder Bar/Trailing Braces |
Exterior: SSG AE Lip Kit | HomeDepot Front Lip Mod | JDM Tailights | Black Emblems |
Interior: AutoExe ShiftKnob | TWM STG2 | ProSport BoostGauge | Dashawk |
ultraspeed619 is offline   Reply With Quote
 Old 06-23-2008, 09:29 AM   #44
phrozen's Avatar
Posts: 314   (View Stats)
phrozen is a splendid one to beholdphrozen is a splendid one to beholdphrozen is a splendid one to beholdphrozen is a splendid one to beholdphrozen is a splendid one to beholdphrozen is a splendid one to beholdphrozen is a splendid one to behold
Yes, you should probably wait. I am going to look over the service manual and ECU pinouts to see how similar they are. If you know of an easy place on this forum I can go to find them, please let me know.
I've also been in contact with a local MS6 owner and I'll probably have him come down and I'll install a WOT Box on their car and make sure it works before we start shipping them for the MS6.
phrozen is offline   Reply With Quote
 Old 06-23-2008, 09:44 AM   #45
94jedi's Avatar
Holy crap, an MS6 w/ launch control??? this would be a huge improvement for you guys.
 Old 06-23-2008, 09:53 AM   #46
ATE BALLER's Avatar
Cool. There is a pinout floating around on another forum, but not this one yet. I'll try to find it in a bit. Will there be a seperate GB for the 6?
 Old 06-23-2008, 09:55 AM   #47
ATE BALLER's Avatar
Especially with upgraded mounts. It's gonna be nasty, real nasty.
 Old 06-23-2008, 10:00 AM   #48
phrozen's Avatar
Will there be a separate GB for the 6?
Sure thing, although the code may end up being identical. We will see.
 Old 06-23-2008, 10:12 AM   #49
ATE BALLER's Avatar
Cool. I was just making sure I don't miss out on the good price.
 Old 06-23-2008, 10:22 AM   #50
phrozen's Avatar
Here you go. Here's my first cut at the instructions. I'll clean it up a bit before we start shipping, but this should give you an idea of how to do the installation.
NP Complete Performance - Mazda Speed 3 Installation Instructions
 Old 06-23-2008, 10:37 AM   #51
ATE BALLER's Avatar
Here's the 6 pinout...
http://www.mazdaspeedforum.org/forum/foru...html#post41764
 Old 06-23-2008, 10:51 AM   #52
phrozen's Avatar
Ok, it appears to be a different ECU altogether, so I'll probably want to do the first install to make sure it all works.
Is there anywhere that has the entire service manual as a PDF? Those diagrams are pretty good. The only thing I can't tell is which of the pins is the signal output for the accelerator position sensor #1. There is a different section of the manual that will have it.
 Old 06-23-2008, 10:53 AM   #53
MS6 Alan's Avatar
Posts: 453   (View Stats)
MS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the world
Would love to slap one on my MS6!
Not worried as much about the trans as I am the rear diff mount!
'06 Mazdaspeed6 GT - Titanium Gray
- ATP 3076r - CP-e XCel Intake - CP-e FMIC - CP-e 4" TIP - COBB AccessPORT - Medieval EWG Manifold - Tial 44mm EWG - ATP Downpipe - Custom 3" Dual Magnaflow CBE - JBR EGR Block Off - HKS SSQV BPV - mrlilguyCDFP (KMDv1) - Denso ITV-22 Plugs - F2 BSD & Baffle - CP-e Upper Rear Diff Mount - TurbineTech Forward Rear Diff Mount - TurbineTech Front Motor Mount - AWR Rear Motor Mount - Tanabe Strut Tower Brace - Technafit SS Clutch Line - RPM Sport Springs .75/1.1 - TWM Stage 2 SS w/bushings - COBB Shift Weight - Défi-Link BF Boost Gauge - Innovate LC-1 Wideband - Hardwired Passport 8500 X50 - AuxMod Basic for CarPC -
MS6 Alan is offline   Reply With Quote
 Old 06-23-2008, 10:57 AM   #54
phrozen's Avatar
The main question I need to answer about the MS6 is if it has the same crank wheel as the MS3. That will determine if we need new code for the MS6 or not. We will find out soon...
 Old 06-23-2008, 11:04 AM   #55
ATE BALLER's Avatar
All the hardware should be the same. The motors are identicle, they just have different ecus for whatever reason. Not really sure why.
I'm still trying to find a pdf version. I have the manual at home, but I won't be back there until ~5 tonight.
 Old 06-23-2008, 11:06 AM   #56
jcgemt2003
Lurkers
jcgemt2003's Avatar
Posts: n/a
You can put me on the list for the speed6 and pm me when you need payment. I want the two step.
 Old 06-23-2008, 11:09 AM   #57
phrozen's Avatar
Ok, no problem. I can't do much with it until tonight anyway.
 Old 06-23-2008, 11:16 AM   #58
peruspeed3's Avatar
Posts: 326   (View Stats)
peruspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud of
hey dude i would like to be on that list too i wana get the wot box and the shift so bouth of them is all for 189 rite?? plus shipping just let me know when i have to pay and how. thanks
peruspeed3 is offline   Reply With Quote
 Old 06-23-2008, 11:18 AM   #59
phrozen's Avatar
Just click on the flag in the first post and it will take you to a paypal page where you can check out. You do not need to use a paypal account. You can checkout with just a credit card if you follow the instructions on the page.
Thanks!
 Old 06-23-2008, 11:27 AM   #60
silversurfer3's Avatar
Posts: 618   (View Stats)
silversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond repute
Groaned at 26 Times in 11 Posts
please put me on the list for WOT/2-step version i will be paying tonight
silversurfer3 is offline   Reply With Quote
 Old 06-23-2008, 01:23 PM   #61
Grim's Avatar
Posts: 2,395   (View Stats)
Groans: 70
There is no list!!!just click on the flag and it will take you to the paypal page!!!
Grim is offline   Reply With Quote
 Old 06-23-2008, 02:44 PM   #62
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
i'm in, 2 step ONLY...PAID
i like my WOT shifting just the way it is !!
TRU-BOOST is offline   Reply With Quote
 Old 06-23-2008, 02:47 PM   #63
phrozen's Avatar
Cool. No problem. Once you've got it hooked up I can send you a trial software load that will let you switch from 2-step only to wot shift only and you can see if you like it. If you do, we can upgrade you. If not, you can go back to 2-step only.
So many options... :-)
 Old 06-23-2008, 02:52 PM   #64
94jedi's Avatar
how long is the introductory pricing going to last?
 Old 06-23-2008, 02:54 PM   #65
phrozen's Avatar
First 20 MS3's and the first 20 MS6's... Once I get the MS6 installed and approved...
 Old 06-23-2008, 02:59 PM   #66
94jedi's Avatar
damn...any idea how many ms3's are paid so far lol? And yes, I'm a cheap son of a beotch!
 Old 06-23-2008, 03:02 PM   #67
phrozen's Avatar
8 so far... List is updated now...
The Following User Says Thank You to phrozen For This Useful Post:
94jedi (06-23-2008)
 Old 06-23-2008, 03:13 PM   #68
TRU-BOOST's Avatar
ok now that i bought one i have a question !!
i got the 2 step only, does it only work with the car in first gear or will it happen in all gears ??
i gues the better question is after i launch and i am flat shifting my way down the track, since i keep my foot to the floor is it going to try to drop my rpm's down to the 2 step set rpm or will it let it stay up at 6500 or whatever ??
 Old 06-23-2008, 03:17 PM   #69
ATE BALLER's Avatar
So, can you switch it back and forth at will like that? Just curious.
 Old 06-23-2008, 03:36 PM   #70
MadOzodi's Avatar
Posts: 686   (View Stats)
MadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the world
Heh, everytime I see the title of this thread, I keep thinking it's called the W00T!!! box.
07 COSMIC BLUE MS3 GT
00 OBSIDIAN BLACK TRIUMPH LEGEND TT 900 - gone, but not forgotten
09 PACIFIC BLUE TRIUMPH SPRINT ST 1050 - SOLD
11 BLACK SUZUKI GSX-R750 - totaled
11 BLACK SUZUKI GSX-R750 - totaled...again
*OFFICIALLY RETIRED FROM TWO WHEELS*
MadOzodi is offline   Reply With Quote
 Old 06-23-2008, 03:40 PM   #71
phrozen's Avatar
The 2-step will engage only when the clutch is pressed and THEN the throttle goes to WOT.
If the throttle goes to WOT and THEN the clutch is pressed, it will WOT Shift. If you don't have that feature, it will not activate.
The order in which the pedals are pressed determines which function is executed.
So, everything is automatic and active all the time (well as long as you have paid for it!). It determines which feature to engage based on the order the pedals are pressed.
 Old 06-23-2008, 03:48 PM   #72
phrozen's Avatar
I've been thinking of offering a special software upgrade to allow that.
However, at this time there is no way to upgrade a single feature box to a dual feature box in the field. It is just too difficult to make that happen securely without having to keep track of serial numbers, secret keys, etc... So, if you want to upgrade in the future there will be two options:
1. Pay the extra fee to upgrade (it will be slightly more than if you bought both features at the start) and mail your box in. We will flash it and mail it back to you.
2. Pay the extra fee plus a core charge and we will advance ship you an extra WOT Box so that you don't have any down time. Once you have returned the single feature WOT Box we will refund the core charge.
Lastly, I haven't really gone into this much, but if you notice there is a serial port on the side of the WOT Box. That serial port allows you to upgrade your software as new features are released and the software is improved. In fact, I'm going to make use of that soon and send Darksun280 a software upgrade that should fix his 2-step RPM. It was just a tad high and I think I figured out why...
So, we'll have software upgrades posted on our site as they come out so that you can keep your WOT Box up to date with the current software.
The serial port will also be where the shift light will plug into. And lastly, there is a rumor that someday I will write some windows software that will allow you to retrieve logs from the WOT Box and adjust parameters with fine precision. We will probably log things like your shift times, so you can see how fast you shift.
 Old 06-23-2008, 03:51 PM   #73
jcgemt2003
Lurkers
jcgemt2003's Avatar
Posts: n/a
How many Ms6s do you have?
 Old 06-23-2008, 03:53 PM   #74
phrozen's Avatar
None. We're not going to take orders for the MS6 until I have verified that it works on that car. It should happen this weekend. I'll post up a new GB when we do....
 Old 06-23-2008, 04:00 PM   #75
ok paid
 Old 06-23-2008, 04:02 PM   #76
TRU-BOOST's Avatar
so the user get control of the 2 step rpm right ??
 Old 06-23-2008, 04:05 PM   #77
phrozen's Avatar
Check out the users guide here... It explains how the programming of the 2-step RPM and optional manual shift time control...
NP Complete Performance - WOT Box Users Guide
 Old 06-23-2008, 04:13 PM   #78
phrozen's Avatar
It really should be called that! It is a lot of fun... Check out this video from one of the first runs we did with the WOT Box installed on the MS3....
http://youtube.com/watch?v=khC-vTkmxJI
 Old 06-23-2008, 04:48 PM   #79
ATE BALLER's Avatar
Out of curiosity, what happens if you're not fully wot, like say, a 1/4" up on the pedal? Some people find that the car is a bit faster just shy of wot. Would this cause some problems? Could that perhaps be adjustable?
 Old 06-23-2008, 04:53 PM   #80
jcgemt2003
Lurkers
jcgemt2003's Avatar
Posts: n/a
Please just add my name to the list and you will receive payment as soon as I see the GB.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/new-product-announcement-wot-box-7252/
YouTube - WOT Box 2-Step MAZDASPEED3 This thread Refback 12-19-2008 08:04 AM
ScionLife View topic - New Product Announcement: The WOT Box - Discounted Group Buy This thread Refback 11-03-2008 04:05 PM
ScionLife View topic - New Product Announcement: The WOT Box - Discounted Group Buy This thread Refback 10-31-2008 03:27 PM
ScionLife View topic - New Product Announcement: The WOT Box - Discounted Group Buy This thread Refback 10-31-2008 03:04 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 4000 RPM This thread Refback 10-22-2008 04:39 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 3000 RPM This thread Refback 09-02-2008 08:13 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 4000 RPM This thread Refback 08-22-2008 11:07 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 5000 RPM This thread Refback 08-06-2008 02:35 PM
NP Complete Performance - Current Sales and Promotions This thread Refback 07-22-2008 12:07 AM
YouTube - WOT Box 2-Step MAZDASPEED3 This thread Refback 07-21-2008 10:38 PM
YouTube - WOT Box 2-Step MAZDASPEED3 This thread Refback 07-17-2008 12:42 PM
YouTube - Mrcho SRT4 big turbo run This thread Refback 07-15-2008 01:02 AM
YouTube - Mrcho SRT4 2 step rev limiter This thread Refback 07-15-2008 12:59 AM
2-step and WOT box teaser vids - Page 4 - Cobalt SS Network This thread Refback 07-14-2008 06:33 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 3000 RPM This thread Refback 07-08-2008 09:35 AM
Any interest in no-lift shift and 2-step launch control? - BMW 1 Series Coupe Forum / 1 Series Convertible Forum (M1 / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i) This thread Refback 07-07-2008 07:50 PM
YouTube - Mazdaspeed 3 WOT BOX/2step controller This thread Refback 07-02-2008 07:53 AM
YouTube - WOT Box 2-Step MAZDASPEED3 - 5000 RPM This thread Refback 06-29-2008 02:30 PM
N2MB WOT Box 40 roll - Video This thread Refback 06-28-2008 02:03 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 3000 RPM This thread Refback 06-26-2008 02:13 AM
YouTube - WOT Box 2-Step MAZDASPEED3 This thread Refback 06-25-2008 06:24 PM
YouTube - WOT Box 2-Step MAZDASPEED3 This thread Refback 06-25-2008 04:24 AM
YouTube - WOT Box 2-Step MAZDASPEED3 - 4000 RPM This thread Refback 06-24-2008 11:12 PM
WOT Box and Cobb Launch Control - TorontoMazda3 This thread Refback 06-24-2008 02:29 PM
YouTube - WOT Box 2-Step MAZDASPEED3 This thread Refback 06-23-2008 07:54 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 5000 RPM This thread Refback 06-23-2008 04:47 PM
WOT Box and Cobb Launch Control - TorontoMazda3 This thread Refback 06-23-2008 02:01 PM
NP Complete Performance - NP Complete Performance This thread Refback 06-23-2008 12:45 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 5000 RPM This thread Refback 06-23-2008 11:12 AM
NP Complete Performance - NP Complete Performance This thread Refback 06-23-2008 10:55 AM
WOT Box - OzMazdaClub.com - Australia's Best Mazda Car Club and Forum This thread Pingback 06-23-2008 08:38 AM
YouTube - WOT Box 2-Step MAZDASPEED3 - 5000 RPM This thread Refback 06-23-2008 06:35 AM
COBB Product Updates Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 525 03-27-2009 10:41 AM
Kia debuting all-new product at British Motor Show Haltech Automotive News 0 05-20-2008 08:00 AM
CPE pcm flash official announcement phailerider MazdaSpeed 3/6 - ECU Computer Tuning 139 05-12-2008 08:20 PM
Chrysler product developer quits after 2 months on the job Haltech Automotive News 0 03-31-2008 03:20 AM
Page generated in 0.57300 seconds with 29 queries
