 Old 06-23-2008, 04:55 PM   #81
94jedi's Avatar
Posts: 2,200   (View Stats)
94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world
Groaned at 7 Times in 5 Posts
Someone posted this on another forum. Personally, I don't see the problem of having some unburnt fuel other than maybe damaging sensors but even that is questionable. Is this even a valid gripe? I just don't know enough about the DISI nuances yet...
Raw fuel being dumped into the engine with no ignition? No thank you.
I like my engine and for that reason you couldn't pay me to install one of these hack boxes.
94jedi is offline   Reply With Quote
 Old 06-23-2008, 05:00 PM   #82
ATE BALLER's Avatar
Posts: 3,227   (View Stats)
ATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the world
It's bad for catalitic converters, but that's it. This is something that's going to give most benefits to drag racers. Most drag racers get rid of the cats.
Originally Posted by StreetUnitMark View Post
I don't think I could go one day without some sort of meat in my mouth.
ATE BALLER is offline   Reply With Quote
 Old 06-23-2008, 05:02 PM   #83
jcgemt2003
Lurkers
jcgemt2003's Avatar
Posts: n/a
I wouldnt worry.
 Old 06-23-2008, 05:13 PM   #84
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
Add me to, WOT Box with WOT Shift AND 2-Step Combo Please!
bioevolve is offline   Reply With Quote
 Old 06-23-2008, 05:23 PM   #85
kingpin748's Avatar
Posts: 2,611   (View Stats)
Groans: 78
That's why I hate those other forums. Everybody is an expert at everything.
In reality I love lenny
kingpin748 is offline   Reply With Quote
 Old 06-23-2008, 06:04 PM   #86
You know it!
 Old 06-23-2008, 06:07 PM   #87
matt8679's Avatar
Posts: 58   (View Stats)
matt8679 is a glorious beacon of lightmatt8679 is a glorious beacon of lightmatt8679 is a glorious beacon of lightmatt8679 is a glorious beacon of lightmatt8679 is a glorious beacon of lightmatt8679 is a glorious beacon of light
matt8679 is offline   Reply With Quote
 Old 06-23-2008, 06:36 PM   #88
Joshj84's Avatar
Posts: 454   (View Stats)
Joshj84 is a splendid one to beholdJoshj84 is a splendid one to beholdJoshj84 is a splendid one to beholdJoshj84 is a splendid one to beholdJoshj84 is a splendid one to beholdJoshj84 is a splendid one to beholdJoshj84 is a splendid one to behold
Add me to the list for Both and paid!
Heavy duty adjustable dog leashes
www.TitanTuff.com
Joshj84 is offline   Reply With Quote
 Old 06-23-2008, 06:50 PM   #89
Buildabong's Avatar
Posts: 3,034   (View Stats)
Buildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the world
Groans: 213
Groaned at 274 Times in 187 Posts
n2mb racing is the best!!! I was waiting for something like this!!! to bad i cant afford it right now..
Buildabong is offline   Reply With Quote
 Old 06-23-2008, 07:03 PM   #90
JumpingJackson's Avatar
Posts: 967   (View Stats)
Would this work on Mazdaspeed 6 assuming hooked to the right wires on the ECU?
 Old 06-23-2008, 07:09 PM   #91
94jedi's Avatar
they're working on the MS6 pinout right now.
 Old 06-23-2008, 07:22 PM   #92
winniep's Avatar
Posts: 333   (View Stats)
winniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the world
No problems WOT shifting here, though I DO see the benefits of cutting power instead of increasing......make shifts easier on your car if you miss a gear. As far as the Launch control though, say I set it at about 2300rpm (best for the track IMHO) and pin the throttle. Then, as I feather the clutch to roll off the line, will the power come on AS SOON as I even move the clutch off of the floor, or when it is fully disengauged? Also, will it work if I use only about 3/4 throttle instead of pinning it? It takes quite a bit of finesse to get a FWD car off of the line without blowing the tires off in first and second. Basically, can I still "roll" into the throttle for an optimum launch just like normal, but just have the nice little RPM cut off so I can go 3/4 throttle without having to watch and adjust my rpm so much while awaiting the light. I can hit a 2.0 on street tires and I bet if this thing works like I hope it does, I can see a 1.9 in my future Just let me know ASAP so I still have time to jump in on this GB.
OH! I almost forgot! WELCOME N2MB!!!!!!!!!! You guys rock! I got my Boomba MM from you guys! Now if you could just talk some other SRT-4 loving companies (like boomba or AGP....) to jump onto the MS3 bandwagon, we'll be set!
The fastest MS3 in the whole garage...
winniep is offline   Reply With Quote
 Old 06-23-2008, 07:38 PM   #93
phrozen's Avatar
Posts: 314   (View Stats)
phrozen is a splendid one to beholdphrozen is a splendid one to beholdphrozen is a splendid one to beholdphrozen is a splendid one to beholdphrozen is a splendid one to beholdphrozen is a splendid one to beholdphrozen is a splendid one to behold
We always get these comments, so I will add this to the FAQ.
Here is the thing. Every after market part comes with some extra risk of damage or some additional wear and tear on your car. It has to be that way. If there was a way to get free extra performance out of your car, the engineers would have done it already. They are pretty smart.
However, the techniques in our WOT Box are well known and well utilized, on many vehicles safely. For example, nearly all modern after market ECUs come with some form of WOT shifting, or as is sometimes called, "no lift to shift".
An even better example of the relative safety of this mod is that some cars are even shipping now with it as a stock feature! For example, the EVO9 has a 2-step launch control and the Chevy HHR has a 2-step launch control and no lift to shift! So, if Chevy is willing to send their cars out of the factory with it stock, they must be convinced it is a reasonable thing to do.
This is not to be confused with anti-lag, which is a system that actually forces fresh air into the exhaust to cause ignition before the turbo to keep the turbo spooled. While this does an excellent job of keeping the turbo spooled (better than no lift to shift), it causes much more wear and tear on the turbo. Here is more reading on anti-lag:
Anti-Lag System - Wikipedia, the free encyclopedia
To play devil's advocate, let's break down the risks involved in using the WOT Box. To start, the WOT Shift feature. I believe it causes very little additional wear and tear on the car, mainly because the amount of time that the ignition is cut is very short. It may be as low as 100 ms, which is only a few rotations of the engine at the RPMs we are shifting at. Plus, the ignition comes back on quickly and evacuates the unburnt fuel from the exhaust. Sometimes there may be a small audible pop as the unburnt fuel ignites in the exhaust. If done enough times back to back, this potentially could heat up a stock cat and cause it to fail, but it would be hard to imagine a situation where you could WOT shift that many times.
On the other hand, the 2-step carries a slightly higher risk of damage to your engine, mainly to the catalytic converter. This time you are forcing less unburnt fuel into the exhaust (because the engine is still firing some of the cylinders), but you are typically doing it for a longer time. The key here is not to use the 2-step for too long and not too often. It is not a toy to make noise in the parking lot. It is meant to be used briefly before a launch at the track and then given the appropriate time after your run to allow the cat to cool. If you were to get on the 2-step and hold it for several minutes, you would probably overheat your cat and destroy it. During the development of the 2-step, we did actually destroy Jay's catalytic converter. However, that was after HOURS of repeated back-to-back 2-step testing.
In conclusion, when used judiciously, these features should increase performance with minimal additional wear and tear on your engine and catalytic converter. Used inappropriately, they can cause damage. However, this is the case with all mods and drag racing in general.
So, be educated about your decisions and the level of risk you are willing to take with your car.
Ideally, you would use this product without a catalytic converter on the drag strip only. That being said, my personal car has a catalytic converter and has gone through tons of repeated testing of the 2-step and come out OK. Your mileage may vary.
phrozen is offline   Reply With Quote
 Old 06-23-2008, 07:45 PM   #94
phrozen's Avatar
I think to really get the benefits of the 2-step launch, you'll need to launch on slicks. Jay's shop car used it to launch at 21 psi.... But, most people won't be able to do that.
The 2-step disables as soon as the clutch is almost completely up or if you let off the throttle. When I felt it out it was a bit less than 1" of travel on the clutch from top. This is because we use the clutch up switch instead of the clutch interlock switch. You'll be able to try it for yourself by following our troubleshooting procedure with the car off. By watching the LED on the box you'll get an idea where it engages.
Right now the throttle trigger is set somewhere above 85%, I would guess. If you needed it, I could send you a custom software load that would lower that threshold. We have toyed with the idea of doing something to make part throttle shifts a little easier as well, but I don't know exactly how that would work. That is something we can try out, since I can just make firmware loads and post them on our website for everyone to try.
 Old 06-23-2008, 07:46 PM   #95
phrozen's Avatar
I almost forgot too... Thanks the welcome. If you have ideas for new electronic products for the MS3 and MS6, just shoot us an email or PM. We're a little busy right now, but come this fall things should slow down and we'll go back into the lab to develop new products for next season...
 Old 06-23-2008, 07:46 PM   #96
phrozen's Avatar
Yes, it should, I just need to verify that the MS6 has the same crank trigger wheel. We should be able to do that this weekend.
 Old 06-23-2008, 07:48 PM   #97
ATE BALLER's Avatar
No cats here. Does that mean I can sit on it for several minutes in the parking lot?
 Old 06-23-2008, 07:48 PM   #98
phrozen's Avatar
No.
hehe.
 Old 06-23-2008, 07:49 PM   #99
Launch control will work badass on the MS6. Lucky fookers.
 Old 06-23-2008, 07:51 PM   #100
ATE BALLER's Avatar
And on the japanese 3s w/awd.
 Old 06-23-2008, 08:40 PM   #101
mdogg's Avatar
Posts: 841   (View Stats)
mdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the world
Groans: 86
Groaned at 36 Times in 25 Posts
Originally Posted by phrozen View Post
Cool. No problem. Once you've got it hooked up I can send you a trial software load that will let you switch from 2-step only to wot shift only and you can see if you like it. If you do, we can upgrade you. If not, you can go back to 2-step only.
So many options... :-)
hmmm... sounds like an interesting option indeed! I'll be in for the MS6 version once available - most likely just for the 2-step, but it would be interesting to try out the flat-shifting feature and make up my mind at that point.
L76-powered
mdogg is offline   Reply With Quote
 Old 06-23-2008, 08:40 PM   #102
Sokool's Avatar
Posts: 11   (View Stats)
Sokool is an unknown quantity at this point
Do you know for a fact that if wired correctly this will work on a Non-Speed 3 with the L3 engine? I'm willing to take the chance and if it doesn't work I'm sure I can sell it for what I paid.
Sokool is offline   Reply With Quote
 Old 06-23-2008, 08:55 PM   #103
4thStroke's Avatar
Posts: 481   (View Stats)
4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute
Paid in full! WOT shift and 2 step.
How are you keeping track of who has paid? As in... how are you linking email addresses to screen names? Did I miss that box when I was paying? I was a bit anxious... I think I wet myself a little.
4thStroke is offline   Reply With Quote
 Old 06-23-2008, 09:34 PM   #104
redspeed's Avatar
Posts: 230   (View Stats)
redspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant futureredspeed has a brilliant future
Freaking awesome!
Paid, WOT/2step.
redspeed is offline   Reply With Quote
 Old 06-23-2008, 09:42 PM   #105
MazdaMan13's Avatar
Posts: 532   (View Stats)
MazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to behold
how will this work with pre-loading and i hope there will be an open spot on friday
MAZDAMAN13 - 2.221, 9.378 @ 78.89, 14.309 @ 99.72 (CBE) no power-shifting
DON'T SLEEP ON THE MAZDA...:phillyb:
JDM PARKING LOL
MazdaMan13 is offline   Reply With Quote
 Old 06-23-2008, 09:49 PM   #106
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
ok another question i thought of.............
with the 2 step, will it mess up my ability to do hard downshifts ?? ou said the 2 step activates if the clutch goes down first, thats why i ask.
if i am cruising in 6nd gear and some stroke in a chevy wants to toy with me on the highway, my natural reaction it to .....clutch in, DROP 2 GEARS, go WOT and quickly release the clutch. if what you said is true and the 2 step was set to say 3000rpm i would not be able to downshift well. to do a good high performance downshift you need to press the clutch and bring the revs up before releasing the clutch in the lower gear. would the 2 step interfere ??
TRU-BOOST is offline   Reply With Quote
The Following User Says Thank You to TRU-BOOST For This Useful Post:
kingpin748 (06-23-2008)
 Old 06-23-2008, 09:50 PM   #107
phrozen's Avatar
I do have the wiring for the L3 engine, so I think I could come up with a wiring diagram for you. The WOT Shift feature is very likely to work. It has worked on nearly everything we have put it on without modification.
However, the 2-step might not work if the crank trigger wheel is different. We could try it and find out. If it doesn't work, you can just send it back and I will refund your money.
 Old 06-23-2008, 09:51 PM   #108
phrozen's Avatar
Hmm. There was supposed to be a box, but it isn't obvious. I should put a page at the end that asks you again for it....
Everyone who isn't on the list yet, please PM me your name so I can match up your transaction with your SN.
 Old 06-23-2008, 09:53 PM   #109
MazdaMan13's Avatar
how many spots are left?
JDM PARKING LOL
 Old 06-23-2008, 09:53 PM   #110
phrozen's Avatar
What is pre-loading?
 Old 06-23-2008, 09:58 PM   #111
ATE BALLER's Avatar
Not that I have to worry about it w/awd, but are the ms3 guys still going to be able to do a burnout w/ the 2 step?
 Old 06-23-2008, 10:03 PM   #112
MazdaMan13's Avatar
when you pull up the e-brake and let off the clutch a little until you feel it kinda grip then you hold until you launch then drop the e-brake and go
edit....yea what about us doing burnouts?
JDM PARKING LOL
 Old 06-23-2008, 10:15 PM   #113
phrozen's Avatar
The sounds kind of bad on the clutch, no?
I'd have to ask the SRT guys, but I think they can do burnouts without the 2-step activating. I haven't heard of anyone having a problem with it activating at the wrong time yet, but I imagine it is possible.
For the burnout, you could also just tap the button on the WOT Box. If you push the button, the LED will go out and the WOT Box will be disabled. Then you can do whatever you like and it will not interfere. If you tap the button again, it will turn on. It will also start up turned on again when you restart the car.
I haven't finalized it yet, but there will be a way to wire up a remote LED and button to the serial port, if you don't want to have to open up your glove box to control the WOT Box.
 Old 06-23-2008, 10:15 PM   #114
708
Erich's Avatar
Posts: 4,274   (View Stats)
He said it was order dependent, so maybe 50% throttle, then clutch, shift and 100% throttle.
Edit: Or what he said :/
 Old 06-23-2008, 10:20 PM   #115
ATE BALLER's Avatar
How about a toggle?
 Old 06-23-2008, 10:20 PM   #116
phrozen's Avatar
Ok, I updated the list. For the people who I didn't have their SN, I chopped the first two characters off the first part of their email address and posted that. I also removed the domain name so there should be 0 chance you'll get spam. If you PM me what slot you are in on the list, I'll replace it with your SN.
 Old 06-23-2008, 10:22 PM   #117
phrozen's Avatar
How about a toggle?
You can wire in a button that will toggle the WOT Box on and off. If you hold it down for more than 2 seconds it triggers the programming mode.
 Old 06-23-2008, 10:27 PM   #118
ATE BALLER's Avatar
Cool, I already have a toggle and a push button installed from my intercooler sprayer that I took out. I left the switches there.
 Old 06-23-2008, 10:31 PM   #119
MazdaMan13's Avatar
so any word on how much it will cost to upgrade from the 2-step to the full 2-step + wot shift later on(like end of july)?
JDM PARKING LOL
 Old 06-23-2008, 10:35 PM   #120
phrozen's Avatar
The upgrade will be the regular price, $149. That includes shipping both ways.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/new-product-announcement-wot-box-7252/
YouTube - WOT Box 2-Step MAZDASPEED3 This thread Refback 12-19-2008 08:04 AM
ScionLife View topic - New Product Announcement: The WOT Box - Discounted Group Buy This thread Refback 11-03-2008 04:05 PM
ScionLife View topic - New Product Announcement: The WOT Box - Discounted Group Buy This thread Refback 10-31-2008 03:27 PM
ScionLife View topic - New Product Announcement: The WOT Box - Discounted Group Buy This thread Refback 10-31-2008 03:04 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 4000 RPM This thread Refback 10-22-2008 04:39 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 3000 RPM This thread Refback 09-02-2008 08:13 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 4000 RPM This thread Refback 08-22-2008 11:07 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 5000 RPM This thread Refback 08-06-2008 02:35 PM
NP Complete Performance - Current Sales and Promotions This thread Refback 07-22-2008 12:07 AM
YouTube - WOT Box 2-Step MAZDASPEED3 This thread Refback 07-21-2008 10:38 PM
YouTube - WOT Box 2-Step MAZDASPEED3 This thread Refback 07-17-2008 12:42 PM
YouTube - Mrcho SRT4 big turbo run This thread Refback 07-15-2008 01:02 AM
YouTube - Mrcho SRT4 2 step rev limiter This thread Refback 07-15-2008 12:59 AM
2-step and WOT box teaser vids - Page 4 - Cobalt SS Network This thread Refback 07-14-2008 06:33 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 3000 RPM This thread Refback 07-08-2008 09:35 AM
Any interest in no-lift shift and 2-step launch control? - BMW 1 Series Coupe Forum / 1 Series Convertible Forum (M1 / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i) This thread Refback 07-07-2008 07:50 PM
YouTube - Mazdaspeed 3 WOT BOX/2step controller This thread Refback 07-02-2008 07:53 AM
YouTube - WOT Box 2-Step MAZDASPEED3 - 5000 RPM This thread Refback 06-29-2008 02:30 PM
N2MB WOT Box 40 roll - Video This thread Refback 06-28-2008 02:03 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 3000 RPM This thread Refback 06-26-2008 02:13 AM
YouTube - WOT Box 2-Step MAZDASPEED3 This thread Refback 06-25-2008 06:24 PM
YouTube - WOT Box 2-Step MAZDASPEED3 This thread Refback 06-25-2008 04:24 AM
YouTube - WOT Box 2-Step MAZDASPEED3 - 4000 RPM This thread Refback 06-24-2008 11:12 PM
WOT Box and Cobb Launch Control - TorontoMazda3 This thread Refback 06-24-2008 02:29 PM
YouTube - WOT Box 2-Step MAZDASPEED3 This thread Refback 06-23-2008 07:54 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 5000 RPM This thread Refback 06-23-2008 04:47 PM
WOT Box and Cobb Launch Control - TorontoMazda3 This thread Refback 06-23-2008 02:01 PM
NP Complete Performance - NP Complete Performance This thread Refback 06-23-2008 12:45 PM
YouTube - WOT Box 2-Step MAZDASPEED3 - 5000 RPM This thread Refback 06-23-2008 11:12 AM
NP Complete Performance - NP Complete Performance This thread Refback 06-23-2008 10:55 AM
WOT Box - OzMazdaClub.com - Australia's Best Mazda Car Club and Forum This thread Pingback 06-23-2008 08:38 AM
YouTube - WOT Box 2-Step MAZDASPEED3 - 5000 RPM This thread Refback 06-23-2008 06:35 AM
COBB Product Updates Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 525 03-27-2009 10:41 AM
Kia debuting all-new product at British Motor Show Haltech Automotive News 0 05-20-2008 08:00 AM
CPE pcm flash official announcement phailerider MazdaSpeed 3/6 - ECU Computer Tuning 139 05-12-2008 08:20 PM
Chrysler product developer quits after 2 months on the job Haltech Automotive News 0 03-31-2008 03:20 AM
Page generated in 0.58167 seconds with 37 queries
