 Old 05-27-2009, 10:20 AM   #41
silversurfer3's Avatar
Posts: 618   (View Stats)
silversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond reputesilversurfer3 has a reputation beyond repute
Groaned at 26 Times in 11 Posts
Originally Posted by QuickSpool View Post
The 8mph in 4th would be worth it for the 1/4 mi racers. You can also buy gears by themselves from Mazda. 4th gear is only $85.63. I am not sure if there are other parts needed.
where did you find this any links you can post
silversurfer3 is offline   Reply With Quote
 Old 05-27-2009, 01:04 PM   #42
Byron's Avatar
Posts: 44   (View Stats)
Byron has a reputation beyond reputeByron has a reputation beyond reputeByron has a reputation beyond reputeByron has a reputation beyond reputeByron has a reputation beyond reputeByron has a reputation beyond reputeByron has a reputation beyond reputeByron has a reputation beyond reputeByron has a reputation beyond reputeByron has a reputation beyond reputeByron has a reputation beyond repute
You need the Gear PAIR and you need to know if the parts are interchangable between the two different gearboxes. They may have changed the spline pattern on the shafts, shaft centerlines or gear widths and still used the same cases. I would not assume that any parts from the current 6 speed MS3 gearbox will interchange with parts from the 2010 MS3 box.
Byron is offline   Reply With Quote
 Old 05-27-2009, 08:56 PM   #43
wassup61's Avatar
Posts: 1,232   (View Stats)
wassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the world
It is likely that they just changed the grind while keeping the same spline pattern. Retooling for this type of manufacture is expensive. In the end, its not really worth it, but to each his/her own.
All wagon, No traction
wassup61 is offline   Reply With Quote
GB thread, get your name on it! Trans mount. ptperformance Mazdaspeed3/6 General Discussion 43 12-12-2008 05:43 PM
Keep your trans mount from breaking..... ptperformance MazdaSpeed 3 - Engine, Transmission & Driveline 2 10-22-2008 10:06 PM
Page generated in 0.25431 seconds with 22 queries
