Like Tree4Likes
 Old 02-02-2014, 04:59 PM   #1
Zmcg1995's Avatar
Posts: 258   (View Stats)
Zmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond repute
Default New turbo
So i was just driving and there was a little ridge that went across the road. Nothing major but for about a foot the road dropped like 2 maybe 3 inches. I drove over it going about 40 mph and i heard a sound that sounded like me just bottoming out. I stopped at the stop light that was just ahead. I then started forward again and i realized that the turbo wasnnt kicking in. For the rest of the drive home (5 min) the turbo did not work at all. I arrived home and turned my car off and let it sit for about 10 min. Hoping to god that maybe nothing happened i came back out and took it around the block and still, no turbo at all. Then when i got to my driveway i realized some white smoke coming out of my exhaust. As i revved it, more smoke would come out. I saw that this is a sign of a blown turbo which would make sense since my turbo isnt working. My car is stock and the only codes on it are p0012 and p0016 which have to do with the cam shaft. So is it deff a blown turbo or could it just be maybe bad seals? Also if i do have to replace my turbo, what turbo should i buy? I heard the stock ones arent very reliable so i would rather not buy the same one. Thanks
Zmcg1995 is offline   Reply With Quote
 Old 02-02-2014, 05:05 PM   #2
spdtrux's Avatar
Posts: 481   (View Stats)
spdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the world
Groaned at 9 Times in 6 Posts
99 JEEP WRANGLER SPORT
4 liter- 5 speed- RCD BILTEIN 4" lift -32X12.5" tires-Xtreme 15"x12" wheels-JET Stage 2 ECU- K&N Intake-TB Spacer -Banks Power Monster Header back exhaust-Hurst short throw shifter-Fender Flares w/ clear corners -brush guard -Fog kit-8500lbs winch -tail light guards-Sound bar
2007 Sunlight GT Crash Smash Boom
ZOOM ZOOM = HTP Full Metal 3" // CS SRI FMIC // Cobb AP // Autotechs // CS TP & CBE // Stock Block // Stock Turbo //
Ralco RZ Shifter // JBR 88 RMM + 80 PMM + Spherical Knob + SSP + WEIGHT + Bushings // Saiko Michi OCC // Cobb Springs // KYB FRONT & BACK // Tri-point rear links // Redline hood shocks // Gen2 VC //
RICE = Rally Armor // 20% Tint All Around // Weather Tech // JDM Goodie Visors // CF Eyelids // Red/Black CF Dash Kit // Bumper Covers // Extra Sub Mod //Stuby Antenna//Red&Blue Interior L.E.D. // 50w 10 L.E.D. Cree Reverse lights
spdtrux is offline   Reply With Quote
The Following 2 Users Say Thank You to spdtrux For This Useful Post:
bstover17 (02-02-2014), Zmcg1995 (02-02-2014)
 Old 02-02-2014, 05:14 PM   #3
Zmcg1995's Avatar
Thanks for the flowers i guess...
 Old 02-02-2014, 05:30 PM   #4
Gr33ntumb's Avatar
Posts: 348   (View Stats)
Gr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond repute
How the fuck would going over a bump fuck up your turbo.
Check your damn couplers
Sent from my SGH-I317M using Tapatalk 2
CS 3inch intake, CS FP internals, CS Test pipe, Forge V2, AP v3, JBR 88a RMM and mud flops
Gr33ntumb is offline   Reply With Quote
The Following 3 Users Say Thank You to Gr33ntumb For This Useful Post:
bstover17 (02-02-2014), Easter Bunny (02-18-2014), Vansquish (02-02-2014)
 Old 02-02-2014, 05:35 PM   #5
Zmcg1995's Avatar
Im not saying going over the bump messed my turbo up. I was just saying when and what happened before it went.
 Old 02-02-2014, 05:47 PM   #6
Dmurray06's Avatar
Posts: 3,279   (View Stats)
If the turbo "went" it would take a lot more than the turbo with it.
 Old 02-02-2014, 05:50 PM   #7
Zmcg1995's Avatar
Lol the turbo didnt fall out of my car.... It just isnt producing any boost..
 Old 02-02-2014, 06:10 PM   #8
sleeperstang1994's Avatar
Posts: 569   (View Stats)
sleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the world
Groaned at 7 Times in 5 Posts
i think step one here should be to see if you can figure out why its not making boost. I don't want this to sound mean. however it doesn't sound like you know a lot about your car. it might be better in the long run to have a shop professionally diagnose your problem. again i do not mean disrespect. Check codes also. If your producing absolutely NO boost there should be a check engine light
sleeperstang1994 is offline   Reply With Quote
The Following 2 Users Say Thank You to sleeperstang1994 For This Useful Post:
Easter Bunny (02-18-2014), Zmcg1995 (02-02-2014)
 Old 02-02-2014, 06:16 PM   #9
Zmcg1995's Avatar
The cel is on for the other codes and i checked the codes again to see if anything else came up but the only codes are the 2 i mentioned.. p0012 and p0016 which have to do with the cam shaft timing. None that have to do with the turbo.
 Old 02-02-2014, 06:17 PM   #10
Do you have any type of boost gauge to actually check PSI? or are you just going off of your butt dyno?
 Old 02-02-2014, 06:20 PM   #11
Zmcg1995's Avatar
No i dont have a boost gauge. I mean i drove the car with normal boost so i know how it should pull thats all im going off of.
The Following User Says Thank You to Zmcg1995 For This Useful Post:
kevin2.3 (02-02-2014)
 Old 02-02-2014, 06:22 PM   #12
spdtrux's Avatar
1. Donate
2. Put mods in signature
3.Use google search option in search tab
4.Even when my seals went on my SAABs gt25 I made boost and Powa just smoked out the arse.
 Old 02-02-2014, 06:25 PM   #13
Do you have an AP to monitor PSI? If none of these options are available, your best bet will be to have a shop look at the car for you.
 Old 02-02-2014, 06:37 PM   #14
Zmcg1995's Avatar
Can you monitor boost through the codes reader? I have an actron autoscanner plus.
The Following User Says NO Thank You to Zmcg1995 For This Un-useful Post:
spdtrux (02-03-2014)
 Old 02-02-2014, 06:38 PM   #15
no sorry that is most likely just a code reader. Id love to help you out more but we are just lacking alot of necessary information. sorry
The Following User Says Thank You to sleeperstang1994 For This Useful Post:
 Old 02-02-2014, 06:43 PM   #16
Zmcg1995's Avatar
Yeah i wish i could monitor boost.. that would really help.
 Old 02-04-2014, 11:27 AM   #17
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
At this point, your best bet is probably to have your car serviced by a mecanical shop.
Buying and installing the needed tool to diagnose it, and learn how to figure it out may be a long journey for you while a quick garage inspection can make it...
Stock Turbo seals on the speed are often leaking but this isn't the answer of you issue, usually a turbo wouldn't stop working when leaking oil. the efficiency will be slowly reduced till it die but won't stop working suddenly...
It is more looking for a coupling issue/WG etc...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Zmcg1995 (02-04-2014)
 Old 02-04-2014, 11:53 AM   #18
Zmcg1995's Avatar
Thats what i was thinking.. possibly one of them came loose or something happened when i hit the ridge. Thanks for your help
Would that still cause the white smoke out the exhaust though?
Last edited by Zmcg1995; 02-04-2014 at 11:53 AM. Reason: MSF Database - Automerged Doublepost
 Old 02-04-2014, 12:31 PM   #19
Sounds like something came loose or broke during the impact. I would suggest poking your head under the car but if you don't know what to look for it's best to have someone else diagnose the issue.
 Old 02-04-2014, 12:38 PM   #20
Zmcg1995's Avatar
Thanks. im taking my car into a shop tomorrow. Hopefully its nothing major. Thanks for all the replies
 Old 02-05-2014, 11:02 PM   #21
Gr33ntumb's Avatar
Don't forget to let us know what Whas up
The Following User Says Thank You to Gr33ntumb For This Useful Post:
Zmcg1995 (02-06-2014)
 Old 02-06-2014, 12:15 AM   #22
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Probably won't be major. If the quote comes back with major work required, you may want to share their diagnosis with us to see if they are pulling your leg.
MINI H1 6.0 - CAR LED TAILS
chaser27 (02-19-2014), cshunter (02-06-2014), Easter Bunny (02-18-2014), Gr33ntumb (02-06-2014), Zmcg1995 (02-06-2014)
 Old 02-06-2014, 11:12 AM   #23
Zmcg1995's Avatar
Got major snow yesterday so the shop was closed but hopefully ill get a call from them sometime today. Will let you know what they say.
 Old 02-16-2014, 04:12 PM   #24
Zmcg1995's Avatar
So i just put the new corksport TIP and took it out and still doesnt pull like it used too. Turbo kicks in at about 3k rpms and not hard just smoothly kicks in. Did a boost leak test and didnt seem to find or hear anything. Any ideas of what the problem could be?
 Old 02-16-2014, 04:53 PM   #25
Zmcg1995's Avatar
Dont have boost gauge either... when should the turbo kick in? It used to kick in at around 2.5k rpm and now its 3+k and not as strong
 Old 02-16-2014, 04:53 PM   #26
btstarcher's Avatar
Posts: 4,852   (View Stats)
Check all your connections. You really need to get something to monitor your vehicle in realtime at least, or something to log. The Torque app in Google Play works well enough.
SnailTune in progress
 Old 02-16-2014, 05:09 PM   #27
blackms3_71's Avatar
Posts: 2,250   (View Stats)
U really should stop trying to see if it works without doing anything. And u installed a tip but didnt bother to look around for loose hoses or couplers? Sounds like ur car is telling u something but ur just not getting the hint
For the sack of ur motor stop flooring it and drive easy till someone looks at it
Last edited by blackms3_71; 02-16-2014 at 05:09 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-16-2014, 05:10 PM   #28
Zmcg1995's Avatar
Lol i did everything you just listed. I checked just about every hose and coupler... i did a boost leak test.. thats why i asked what others thought
 Old 02-16-2014, 05:34 PM   #29
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Check to see if the waste gate arm is still attached to the flapper...
I had this happen to me once
btstarcher (02-16-2014), Zmcg1995 (02-16-2014)
 Old 02-16-2014, 06:50 PM   #30
Zmcg1995's Avatar
Sorry but im not sure where to look... what does that look like and can i see it from just looking under the hood?
 Old 02-16-2014, 07:17 PM   #31
Guessing you have the heat shielding etc still there, so it might not be the easiest thing to see...
But if you look from the left hand side along the dp towards the turbo, you might be able to see this:
http://www.mazdaspeedforum.org/forum/foru....php?p=1715057
Can see the bit sticking out? That's not supposed to be there. The waste gate arm is supposed to be connected to it.
In this instance, it moved freely (bad)
This isn't our turbo, but hopefully it gives you an idea as to how it should be:
Can see the rod is attached to a "flapper" mine fell off
Also, might be a silly comment... But only stick your hand down there if you know it's cold :p
jm211 (02-17-2014), sleeperstang1994 (02-16-2014)
 Old 02-16-2014, 07:17 PM   #32
you said the shop was closed for the snow? Did you reschedule your appt.? sounds like you still need to get this checked out by a professional.
 Old 02-16-2014, 07:46 PM   #33
Zmcg1995's Avatar
Yeah i cant seem to see that... i can see the wastegate actuator but cant see the arm on the other end of the rod
 Old 02-16-2014, 08:14 PM   #34
Zmcg1995's Avatar
I can feel it with my hand and it seems to be perfectly fine and connected.
 Old 02-16-2014, 08:21 PM   #35
steelknight7d's Avatar
Posts: 78   (View Stats)
steelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud of
Groaned at 31 Times in 12 Posts
If you don't have the funds for an ap either get the torque app, or get an ultra gauge it's cheap but shows boost.
Corksport core/cx piping, HTP 3" intake, Grimmspeed EBCS, Autotech internals, Turbo Smart 50/50, CNT CBE, Sure PMM, Perm knob, Cobb AP, Matt Damond occ, JBR SSP, JBR TMM, JBR rmm, JBR Shifter bushings, ATP catted dp, NGK Plugs 1 step colder,H&R springs,hotchkis rsb, 5mm spacers, moog endlinks, Corksport strut bar, CP-e tow plate, Stratified by LEX
steelknight7d is offline   Reply With Quote
 Old 02-16-2014, 08:55 PM   #36
Zmcg1995's Avatar
Idk what to check... checked all the tubes and clamps.. did a boost leak test and didnt hear or see any leaks... runs fine just doesnt pull hard at all..
 Old 02-16-2014, 09:01 PM   #37
Zmcg1995's Avatar
Also while i had my TIP off i could see the turbo wheel and it had a little play in it... should it move at all up and down? Is that normal/okay?
 Old 02-16-2014, 09:04 PM   #38
btstarcher's Avatar
And without any datalogs there's really nothing we can do. I'm guessing you have a hose disconnected somewhere or a crack on the EBCS nipple from where you disconnected/reattached the hose to the TIP. Or even the hose from the IM to the BPV.
 Old 02-16-2014, 09:12 PM   #39
Zmcg1995's Avatar
I need someone around philly to come help me out lol
i did a boost leak test though and didnt seem to find anything leaking or cracked
Last edited by Zmcg1995; 02-16-2014 at 09:12 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-16-2014, 09:17 PM   #40
btstarcher's Avatar
What did you use to check for leaks? Soapy water? Where did you check? Also what PSI did you set the air compressor to? Where did you attach the boost leak tester to?
Los Angeles: 2014 Porsche Panamera Turbo S is a 911 Turbo for the family man Haltech Automotive News 0 11-21-2013 10:20 AM
Official: 2014 Porsche 911 Turbo and Turbo S debut [w/video] Haltech Automotive News 0 05-03-2013 07:50 AM
First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo Haltech Automotive News 2 05-04-2009 06:48 PM
Page generated in 0.60172 seconds with 31 queries
