![]() Join Date: Sep 2019
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score ). The car, mechanically, seems pretty sound, and I've taken an interest in the forums to learn all about what my vehicle and accessport is telling me.One thing that tends to linger in my mind as I'm driving is the little section in my Accessport titled "KR." I actually drive around with it on constantly and always seem to grab it and check the reading after I do a WOT pull or I hear a sound that seems fishy (ie backfire). I've seen some pretty high readings (1-2*) and now that I've learned how to datalog, I found that it looks good under a WOT pull and the zoom zooming around town will show some pretty interesting readings. Now, I've done my fair share of exploring the forums and learning about Timing and how it is affected with daily driving, and WOT pulls. Today, I got into a little pull with an EVO X and it sure was fun, but i heard an interesting noise that may have been attributed to how close/possibly over redline i was but, when i checked my KR reading after my fun with the EVO, I read a 4.2*. You could imagine how much i was sh**ing my pants. So i got home, parked it and wondered about it for an hour or two about what it could have been. I finally gave in and took the car for some datalogging. I ended up checking my datalogs (attached), and to my surprise, they looked fine. Now my question is, what could my reading of 4.2* KR be a result of? Does the PCM cut timing as a result of over revving (past redline) and throw a reading like this? Please be easy on my ignorance, and if there is a thread that i haven't found, could somebody point me in the direction? Thanks for your continued awesomeness! |
![]() Join Date: Aug 2016 Location: vermont
Rep Power: 43 ![]() Thanks: 12
| Not Ranked : 0 score Im far from an expert so Ill ask the others to confirm or deny for me, but might it be a rmm going bad? i was getting interment knock readings around those levels until i swapped the stock mount for a deamon rmm. with the engine slopping around the knock sensor becomes upset. |
__________________ 2012 Mazdaspeed 3 Engine: Manley 88m Platinum Series Pistons|Manley H Beam Rods|Corksport Injector Seals|ARP Crank Pulley Bolt|ARP L19 Head Studs|ARP Main Stud Set|JBR BSD w/ Baffle|Supertech Valve Spring Kit/Dual Valve Springs|JBR PMM/Cobb RMM|Damond EGR Delete|Bosch 3.5 Bar MAP Sensor Turbo/Accesories: BNR S4 Turbo|AEM Water/Meth Kit|HTP 3.5 Intake|Greddy FMIC 2 1/2" Piping|Turbosmart BOV Transmission: ACT 6 Puck Clutch|Streetlite Flywheel|JBR Transmission Motor Mount|Sure Motorsports Counterweight/Short Shift/Plate/Shifter Bushings | |
(Thread Starter) | Not Ranked : 0 score Car shifts great, no issues. It actually pulls really well, that’s why I was confused. And I was pushing it pretty hard this particular pull, hitting close to or above redline.
| Newb Help | kerseyms3 | Mazdaspeed3/6 General Discussion | 7 | 04-11-2012 08:32 PM |
| a newb with newb questions | viper1891 | Mazdaspeed3/6 General Discussion | 19 | 02-28-2012 11:27 PM |
| Newb from Va | ZoomN Cx7 | CX-7 > General Lounge + New Member Welcome | 12 | 04-15-2011 12:51 PM |
