![]() Join Date: Feb 2012
Rep Power: 0 ![]() Thanks: 4
(Thread Starter) | Not Ranked : 0 score whats up everybody! i have been a proud owner of a 2008 ms3 for about 4 months now and im thinking about putting some more goodies into the engine. currently i have a short ram intake, 2 resignators taken off the exhaust and a cobb stage 1 one tune. i love it! but im thinking about getting a dp and an inlet hose. im probably going to get the cobb inlet hose but im not sure what to do about the dp. i was looking at the ones on ebay and for 170$ it doesnt look like a bad deal. anyone have any input for me? im open to anything! thanks everyone! |
![]() Join Date: Dec 2011 Location: Red Deer,AB Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,855
| Not Ranked : 0 score Get fuel pump internals before you get a downpipe or you will blow your engine sky high.
__________________ 2010 Mazdaspeed 3 Black Mica w/ Tech Package - Traded In 2014 Ford F150 FX4 Ecoboost - Current |
| The Following User Says Thank You to Dmurray06 For This Useful Post: | KILLER_VIZ (02-28-2012) |
![]() Join Date: Jul 2011 Location: Miami Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,829
Groans: 55
| Not Ranked : 0 score you really won't blow ur engine ..it's not recomended but you will have to be monitoring your FP pressure with your AP.. I have been running a dp with the stock FP internals for months and my fp pressure is well above 1600psi at wot. Just get some internals autotech,kmd or ptp for peace of mind. And @IshiKage has an ebay dp and its holding up great so go for it.
__________________ 08 Black Mica Ms3~full bolt ons/Nishan Tuned-Sold NATOR FL |
| The Following 3 Users Say Thank You to Ms3_Miami For This Useful Post: |
![]() Join Date: Oct 2011 Location: Houston, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 555
Groaned at 28 Times in 14 Posts
| Not Ranked : 0 score Go here then hit up eric@edgeautosports.com Mazdaspeed 3 - 2007-2009 Gen1 - Engine - Fuel - EdgeAutosport.com Oh and donate so you can go to the VIP for sale section. |
| The Following User Says Thank You to KILLER_VIZ For This Useful Post: | Ms3_Miami (02-28-2012) |
![]() Join Date: Feb 2011 Location: Lusby, MD
Rep Power: 496 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 119
| Not Ranked : 0 score auto tech or PTP seems to be the norm for most. edit: sonofabitch im a brownie again...time to donate lol
__________________ 06 MS6 |SP Built motor - Weisco Pistons .020" over, Manley H-Beam Rods, Ported Head, Ported Intake, VTCS Delete, BS Delete, VVT Actuator, Keyed Crank, 6th Port Fuel Injection | ACT 6 Puck w/ Streetlite Flywheel | Bullseye S259 .70 A/R Single Scroll | 3.5" Intake/MAF Housing | Steedspeed Twin Scroll T3 Top Mount Manifold | Tubosmart 40mm EWG | Custom DP | Custom TBE | Custom LTA Intercooler | HKS Type IV TT | Dashhawk | COBB AP | AWR RMM | PTP HPFP Guts | KILLAH BUILT |
| The Following User Says Thank You to Navy_Mech2 For This Useful Post: | manelscout4life (02-28-2012) |
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score kmd or at internals! |
| Not Ranked : 0 score eventually your pump will not hold pressure. i have ~66k on my car and about 40k running with an intake, TIP, cattless dp, exhaust, and an ap and mine started to show signs of wear right before i went on deployment. when i first punch it, pressure dips down to like 11-1200 and then comes back up to my target pressure. in conclusion: your shit will not explode immediately but eventually it will start to go.
| The Following 2 Users Say Thank You to Navy_Mech2 For This Useful Post: | KILLER_VIZ (02-28-2012), Ms3_Miami (02-28-2012) |
Groans: 55
__________________ 08 Black Mica Ms3~full bolt ons/Nishan Tuned-Sold NATOR FL | |
| The Following User Says Thank You to Ms3_Miami For This Useful Post: | KILLER_VIZ (02-28-2012) |
| Not Ranked : 0 score The FP in our engines are cam driven( connected to the internal motor) if they get to bad they can cause your engine to seize. Just get them to be on the safe side man. |
| The Following User Says Thank You to KILLER_VIZ For This Useful Post: | viper1891 (02-28-2012) |
| Banned ![]() Join Date: Feb 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 385
Groaned at 22 Times in 17 Posts
Agreed, get a fuel pump or fuel pump internals to be on the safe side. | |
| The Following 2 Users Say Thank You to HPFPUPGRADE For This Useful Post: | IshiKage (02-29-2012), KILLER_VIZ (02-29-2012) |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
and also when i rebuilt car i forgot cam follower and pump locked up intake cam and snapped vvt and bent valves. | |
| The Following User Says Thank You to Nitr0EngiE For This Useful Post: | KILLER_VIZ (02-29-2012) |
I could see the potential for major damage if you forgot to put the cam follower inside the housing, but that is a different story. Now, I am not saying that its impossible for the fuel pump to cause a huge mechanical issue with the engine... just saying that I have not seen it yet. | |
| The Following User Says Thank You to HPFPUPGRADE For This Useful Post: | IshiKage (02-29-2012) |
(Thread Starter) | Not Ranked : 0 score i see what you guys are saying, and yeah i will probably upgrade the fp before anything, specially if i want to do a higher tune with my cobb |
| The Following User Says Thank You to viper1891 For This Useful Post: | KILLER_VIZ (02-28-2012) |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| Not Ranked : 0 score nothing is going to explode. if the motor doesnt blow off 50psi of fp then its not off 11-1200. just use common sense and dont go wot until you can get pump internals @Ms3_Miami once you install pump internals on stock tune you will see how much power you were missing out on b.c of inadequate fuel
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
| The Following 4 Users Say Thank You to IshiKage For This Useful Post: |
Groans: 55
![]() Join Date: Jul 2011 Location: Santa Fe, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score but once you do the fpi the ebay downpipe is dope as fuck! haha of course its the easiest option if your running a catless dp because its just a piece of metal and spending the least is always best and it still has good build quality however if you wanna go catted id so go with a well known company like atp, cp-e etc since i dont know how the quality of the cats are on the ebay pipes. but catless ebay=ftw
__________________ [SIGPIC][/SIGPIC] 1992 miata, track beast here I come with 2 bride seats!! (current)3076r speed6 owner (traded) 2000 camaro 415rwhp thru midwest chassis fab (sold) |
(Thread Starter) | Not Ranked : 0 score catless dp i think it is . anyone know what a respectable shop would charge (estimate) to put in the fpi? |
![]() | | #19 | ![]() |
| Not Ranked : 0 score Check with your local Nator group they might be able to help you and you wouldn't have to pay a mechanic otherwise it takes about an hour to an hour abd a half to do.
![]() | | #20 | ![]() |
| Not Ranked : 0 score yah i was just pointing out my user error on rebuilding engine causing MAJOR full fail and then the Failure equipment i purchased and had fail on me causing Boom they just just scenarios not related in the fassion your discussing but still good to know to avoid =) When i blew up my stock motor i was on 20 psi 3076r on my current turbo setup and it was perfectly tuned for months i had quit logging and monitoring and was DD and on way home from work i went WOT in like 3rd gear it sputtered a bit and boom, another lesson always watch and log and buy afr gauge ... |
| Newb from Va | ZoomN Cx7 | CX-7 > General Lounge + New Member Welcome | 12 | 04-15-2011 12:51 PM |
| Tuner newb. Got a couple questions. | Dash08 | MazdaSpeed 3/6 - ECU Computer Tuning | 10 | 09-29-2008 09:35 PM |
