![]() Join Date: Jan 2018
Rep Power: 0 ![]() Thanks: 2
![]() Join Date: Dec 2017 Location: Idaho
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
| Not Ranked : 0 score I would say if compression is zero..... Bent/broken valves, piston gone or well fucked, compression tester not being hooked up correctly....
__________________ 2011 MS3 Tech - 2008 Jeep Grand Cherokee CRD - 1989 Crown Vic LTD LX - 1985 Lincoln Town Car Signature The key to happiness is owning a car ridiculously slower than your 'fast' car. |
| Not Ranked : 0 score A leakdown will tell you where it's failing.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | Pu Manchu (02-27-2018) |
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score compression tests would be a complete waste of time if they weren't so easy. you're gonna have to do a leak down test, and do it correctly.
__________________ 94 M MS6 IS350 |
| Another compression thread. | 94dsm | Mazdaspeed3/6 General Discussion | 8 | 02-23-2018 03:23 PM |
| Low compression and BNR S4 | feldm4n | MazdaSpeed 3 - Engine, Transmission & Driveline | 0 | 04-17-2017 04:46 PM |
| Bad Compression | 'MERICA | MazdaSpeed 6 - Engine, Transmission & Driveline | 14 | 08-08-2012 12:55 PM |
| Low compression | MaverickX3 | MazdaSpeed 6 - Engine, Transmission & Driveline | 55 | 12-10-2010 04:41 PM |
