 Old 11-16-2017, 10:05 AM   #1
ieang's Avatar
Posts: 6   (View Stats)
ieang will become famous soon enough
Default No crank - lights flickering
Hey all, new 2009 MS3 owner. I am having some weird issues with trying to start the car.
Here is some background: bought the car with timing chain noise. Drove it once, just to get it home. I finished the repair using the How To: VVT thread and put the car together, tried to start the car twice. It cranked, but on the second time a bunch of fuel sprayed on top of the transmission and spilled onto the ground. I discovered the leak to originate from the nut on the hard line under the HPFP.
Just got around to retightening the nut using some threads on this forum and putting the car back together. I tried to start it, after priming the HPFP about 10 times (no leaking, as far as I can tell), but as soon as I crank it, I hear a click, no crank, then and the lights on the instrument panel start flickering. It looks like a log in a fire, crackling. I remove the key, reinsert the key, turn it to on position, and the lights start flickering again. If I remove and reinstall the battery and put the key to the on position, the lights look normal.
I had the battery checked and there is ample voltage and CCA. I will look at fuses, lock/unlock the door a few times to see if its the immobilizer, and maybe try hitting the starter tonight, but other than that I am at a loss as to the flickering lights issue. Anyone experienced this before? If so, anything I should look for?
ieang is offline   Reply With Quote
 Old 11-16-2017, 11:47 AM   #2
flapjack's Avatar
Posts: 121   (View Stats)
flapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to behold
I'm assuming you've tried this already? If your car does not start
Also I would check the ground on the HPFP itself.When it's not connected or contacting right it can cause starting issues.
flapjack is offline   Reply With Quote
 Old 11-16-2017, 01:43 PM   #3
ieang's Avatar
Thanks for the link. I will check the starter wire first.
I made sure not to even touch that ground on the HPFP, but I will make sure its connected and tight.
 Old 11-17-2017, 02:43 PM   #4
ieang's Avatar
just as an update, I got the car started. I did not do anything special aside from cycling the remote locks and then running a big wrench across the engine (serious), after which the car decided to start up. All I know is I am happy it's working now...
 Old 11-17-2017, 04:41 PM   #5
aackthpt's Avatar
Posts: 1,450   (View Stats)
2013 'speed3, silver
Stage Bro
The Following User Says Thank You to aackthpt For This Useful Post:
monkey.bones.007 (11-17-2017)
Flickering headlight while turning ryoonc CX-7 > Car Audio & Electronics 7 05-28-2018 12:32 PM
Oil Pressure Light Flickering BackRoads MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 04-02-2018 06:41 PM
HID Flickering Issues Airman3454 Exterior 25 01-22-2015 04:48 PM
Flickering AccessPort someguy 2010 MS3 - ECU Computer Tuning 10 01-13-2014 05:02 PM
flickering hid's jman46 MazdaSpeed 3/6 - Car Audio & Electronics 3 05-31-2010 06:10 AM
Page generated in 0.28084 seconds with 22 queries
