 Old 11-14-2012, 10:21 PM   #1
Stealthvr4's Avatar
Posts: 84   (View Stats)
Stealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to all
Default No gas pedal response
So I'm having some issues with a new ms6 purchase.. The car shows no response from gas pedal. I replaced the throttle body with a known working one thinking that was the problem. Any ideas?
Stealthvr4 is offline   Reply With Quote
 Old 11-15-2012, 12:16 AM   #2
chuckms6's Avatar
Posts: 1,618   (View Stats)
You check the connection to the app on the pedal?
Tapatalking
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
 Old 11-15-2012, 10:15 AM   #3
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
you didn't notice that when you bought it?
it's fun to do bad things
 Old 11-15-2012, 10:29 AM   #4
KevMS6's Avatar
Posts: 316   (View Stats)
Does the car start?
Have you driven the car since purchasing?
Tuned with by
 Old 11-15-2012, 10:40 AM   #5
Ayaritz's Avatar
Posts: 586   (View Stats)
Ayaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the world
Is there a CEL? It could be the position sensor being all dumb
like mine and putting it in doghouse mode. Basically you give it gas but RPM's raise veryyy slowly and don't go past 2k or so.
Happens to me maybe once every 3 months.
Basically to fix it:
Disconnect battery.... wait 5 minutes.... reconnect battery... zoom zoom drive away
Try that, assuming you didn't disconnect battery when you replaced the TB initially.
Ayaritz is offline   Reply With Quote
 Old 11-15-2012, 10:45 AM   #6
Stealthvr4's Avatar
Car was purchased through a auction. Car starts idles rough for about a minute then dies, while running its dumping a neighborhoods worth of smoke out the back. No gas response during any of this. Pedal is plugged in along with the tb. Brand new maf sensor.
 Old 11-15-2012, 10:51 AM   #7
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Sounds like you bought a car without testing it out first, and you bought a car with a blown engine.
Check compression and timing chain tautness.
Tapadatass
Chimmike (11-15-2012), jack_hammer (11-15-2012)
 Old 11-15-2012, 11:22 AM   #8
Groans: 549
Tapadatass
definitely need to start with the VERY basics on this one. compression test should definitely be first thing. i hope you don't need this to run anytime soon.
also, if you pay up and become VIP, you will be opened to a world of knowledge that is well worth the cost of admission.
 Old 11-15-2012, 12:29 PM   #9
Stealthvr4's Avatar
Timing chain was tight. I'll do a compression test tonight. If the motor was bad what about the no gas response what so ever
 Old 11-15-2012, 12:38 PM   #10
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
before doing compression test, do piston height test via a screwdriver and cranking the motor by hand. If bent rod, you could throw thru the block just doing something like a compression test.
Also, check for mods. Sounds like the car was heavily modded at one point, lol.
check for vacuum leak/leak after the MAF.
07 MS3
The original Genpoo Hater
 Old 11-15-2012, 04:41 PM   #11
rob ms6gt's Avatar
Posts: 416   (View Stats)
You never answered if you have any codes. You should.
ROB MS6GT
 Old 11-16-2012, 09:47 AM   #12
Stealthvr4's Avatar
Yea I have a cel. I don't have a scanner on hand. One of the codes was pedal possision sensor.
 Old 11-16-2012, 10:00 AM   #13
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
Ok............ I'll be the one to say it.
Are you sure you're stepping on the right pedal??
Lets just make sure we got that outta the way first.
______________________
Built By NATOR
Tons of Ricer Mods
 Old 11-16-2012, 10:07 AM   #14
Stealthvr4's Avatar
R u for real.....
The Following 3 Users Say NO Thank You to Stealthvr4 For This Un-useful Post:
09Speed3Z (11-16-2012), jm211 (12-04-2012), zpele (11-19-2012)
 Old 11-16-2012, 01:49 PM   #15
kgb
kgb's Avatar
Posts: 808   (View Stats)
kgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the world
Groans: 88
Just curious but how much did you pay?
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
kgb is offline   Reply With Quote
 Old 11-16-2012, 01:49 PM   #16
KevMS6's Avatar
Awesome ^^
Tuned with by
The Following User Says Thank You to KevMS6 For This Useful Post:
 Old 11-16-2012, 01:56 PM   #17
Stealthvr4's Avatar
5k to my doorstep from ca to ny
The Following User Says Thank You to Stealthvr4 For This Useful Post:
kgb (10-08-2018)
 Old 11-16-2012, 03:03 PM   #18
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
Your sarcasm detectors obviously need new batteries OP.......
Built By NATOR
Tons of Ricer Mods
 Old 11-16-2012, 03:55 PM   #19
jm211's Avatar
Posts: 943   (View Stats)
Does the idle sound ok? I mean if your rods were so far gone you would be able to hear it.
1: Piston height check. The two outsides should match and the two insides should match.
2: all ok? Pressure test. What is normal? about 180 (ish)
3: Is there oil in the car?
4: How do the spark plugs look?
5: Is your intercooler missing a hose?
6: How do you know the code being thrown if you haven't got a reader to pull it?
The Following User Says Thank You to jm211 For This Useful Post:
chuckms6 (11-16-2012)
 Old 11-16-2012, 05:09 PM   #20
chuckms6's Avatar
this. also for 5k shipped cross country i dont think you could have gone wrong.
get a code reader and see whats up. the $120 harbor freight is perfect for what it is, i love mine.
also check all of your fuses. engine bar fuses can cause weird symptoms if they are blown.
 Old 11-18-2012, 10:08 AM   #21
rob ms6gt's Avatar
Hmmm; Perhaps this could be your problem.
ROB MS6GT
 Old 11-18-2012, 02:17 PM   #22
rob ms6gt's Avatar
ROB MS6GT
 Old 11-19-2012, 03:00 PM   #23
Stealthvr4's Avatar
2 codes 2119 & 2138. Car idles until gas pedal is pushed in, then traction light comes on with check engine and car dies. I'm gunna try swapping the electronic gas pedal out.
 Old 11-19-2012, 04:10 PM   #24
chuckms6's Avatar
Those codes are for tps and app, that would be the correct fix for your issue.
Tapatalking
 Old 11-19-2012, 06:57 PM   #25
Stealthvr4's Avatar
Tapatalking
I sure hope so....
 Old 11-19-2012, 07:42 PM   #26
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Check plumbing from PCV valve to intake manifold. Check all air lines out of IM are in good order.
If the previous owner had a catch and removed it and did not add the OEM hoses back before it was impounded it could run the way you describe it.
 Old 12-04-2012, 02:38 PM   #27
Stealthvr4's Avatar
So I cleared the codes instslled new" app". Same problem exists, car starts and revs at 1500k. when I tapped the gas before traction light came on and car died. Now traction light comes on but car stays running with no pedal response. Still running rich with black smoke. Any help greatly appreciated. Same 2 codes presist
 Old 12-04-2012, 03:28 PM   #28
chuckms6's Avatar
have you checked the throttle body for blockage?
Edit, I guess you have. I'm out of ideas.
Tapatalking
 Old 12-04-2012, 03:43 PM   #29
jm211's Avatar
I'll buy it 2500$ cash.
I suggest starting taking the simple stuff apart. (assuming ALL fuses checked)
Since its not the TPS, maybe check the fuel line or in tank pump to make sure air isn't getting in.
I don't fuckin' know..
Remove all intake, intercooler, inspect TB, EGR, hoses, Plugs, Do a piston height check, HPFP, was there a boost gauge installed?
 Old 12-04-2012, 05:43 PM   #30
chuckms6's Avatar
op try to find a scantool that does live data or an ap. at idle you should be around 14.7 afr, +-8 ltft, and -19inhg vacuum. if any of these numbers are off it will help direct you to your problem.
also, try running it withough the maf plugged in and checking for air leaks. check your fuses with a test light as well.
 Old 12-05-2012, 09:41 AM   #31
chuckms6's Avatar
Might be time to start checking circuits and wiring too.
Tapatalking
 Old 12-05-2012, 09:59 AM   #32
tjamison's Avatar
Posts: 187   (View Stats)
tjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond reputetjamison has a reputation beyond repute
Go VIP and get the factory manual. On page 8,279 of 10 million there's a procedure in there for essentially resetting the TPS or actuator. I lost my throttle input after changing my starter, and following this did the trick.
It's something along the lines of turn the key on for 10 minutes, off, run for some amount of time, blah, blah...
EDIT: I had P2119, too.
2007 MAZDASPEED3 GT
MS SRI | CS TIP | JBR RMM | JBR RSB | CS Struts/Shocks | Whiteline ALK
tjamison is offline   Reply With Quote
The Following 2 Users Say Thank You to tjamison For This Useful Post:
chuckms6 (12-05-2012), Stealthvr4 (12-05-2012)
 Old 12-05-2012, 09:59 AM   #33
just for shits and giggles, post the VIN
 Old 12-05-2012, 11:09 AM   #34
Stealthvr4's Avatar
It's worth a shot....
Jm1gg12l561103263
Last edited by Stealthvr4; 12-05-2012 at 11:09 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-05-2012, 11:22 AM   #35
Yeh, it looks to have some front and rear collision history, almost as if damaged before sale even. Vehicle salvage history: VIN number - JM1GG12L561103263
 Old 12-05-2012, 11:28 AM   #36
Stealthvr4's Avatar
I' did buy from insurance auction... No sign of front or rear end collision.
 Old 10-07-2018, 12:48 AM   #37
Bluemica2373's Avatar
Posts: 2   (View Stats)
Bluemica2373 can only hope to improve
Did you ever solve this?
Bluemica2373 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to Bluemica2373 For This Un-useful Post:
MSMS3 (10-09-2018), Pu Manchu (10-10-2018), Thor Hammer (10-09-2018)
 Old 10-09-2018, 01:46 PM   #38
MSMS3's Avatar
Posts: 2,825   (View Stats)
Do you realize that you are responding to a thread from 2012? And responding to OP who last posted anything here in January of 2015, over three years ago! Chances are very high that he has long since moved on.
This is not what I would call an auspicious beginning. Maybe start a new thread if you are having a specific issue that we might help you with? Just a thought . . .
monkey.bones.007 (10-09-2018)
 Old 10-09-2018, 02:49 PM   #39
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
So are you're saying he won't get this solved by asking in this thread?
Sent from my SM-N960U using Tapatalk
MSMS3 (10-10-2018), Thor Hammer (10-09-2018)
 Old 10-10-2018, 12:18 AM   #40
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
ugh, why do these guys always look so familiar?
94 M
MS6
IS350
The Following 2 Users Say Thank You to Pu Manchu For This Useful Post:
monkey.bones.007 (10-10-2018), MSMS3 (10-10-2018)
Terrible response with BNR S3! EmPeEs6 MazdaSpeed 3/6 - Big Turbo Builds 17 07-16-2012 05:52 PM
In Response To An Allegation Haltech Automotive News 1 09-28-2011 09:41 PM
Throttle response MaverickX3 MazdaSpeed 6 - Engine, Transmission & Driveline 4 06-28-2010 01:12 PM
Race Roots Response.. Race Roots Mazdaspeed3/6 General Discussion 78 01-17-2010 08:43 AM
The HKS CORPORATE response to the HKS SSQ BOV clown_car MazdaSpeed 3/6 - Turbo Induction 5 01-30-2009 09:02 PM
Page generated in 0.55968 seconds with 37 queries
