Like Tree7Likes
 Old 01-09-2013, 08:48 PM   #1
Payne Racing 67's Avatar
Posts: 4,483   (View Stats)
Payne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the world
Groaned at 64 Times in 49 Posts
Default The Official "2nd Gear Is Dead" Thread
Well, the dreaded 2nd gear popout/grind is a well known issue for our platform. I'm currently in the process of getting mine fixed(and fighting Mazda for my warranty). It aggrivates me immensely to know that it's such an issue, has happened to multiple cars, and not only do they not fix the issue at production, they give many of us an issue as far as covering it. I've decided to start an official thread on this and see if we can get somewhere with it. Also, in the case of mods/waranties, there are 2 laws: The Lemon Law: http://www.carlemon.com/ As well as the Magnuson-Moss Act, which basically states that a dealer/car corporation cannot deny warranty work based solely on the fact that you have aftermarket parts. They have to actually physically be able to prove the mods caused your issue/failure.
So what I want is:
Year/Model(speed3/6)
Mileage 2nd gear started acting up/went
How it happened/progressed
When it happened ie down/upshifting
Stock? or what mods? Shifter parts ie sts, knob, etc.
Using FoMoCo fluid?
Was it covered/repaired
Did it happen again?
I need anyone who's ever had an issue to post.
2010 Mazdaspeed3
10,500 Miles
Went to downshift to 2nd gear, in a parking lot and it popped out when I let the clutch out. It progressed from there throughout 2 days, to finally not going in at all on an up/downshift
At the time I had intake, blowoff valve, Cobb Accessport, Full Exhaust, full motor mounts, Stage 2 tune
It was covered, and they replaced the trans.
Now, at 35,000 miles the issue has happened again.
Pretty much the exact same situation but at a slower pace. @Raider; would you mind helping me with this? Maybe make it a sticky if you think we should?
@dantes5823; @amggilly305; @NJSPEED3; @TWOptSL0W; @ArcticSpeed3; @bf360; @rigor; @Blck350z; @MS3-a(sore)ASS-rex; @johnheer; @kramer; @JimmyMac; @occschemguy; @MS6 Alan; @clos561; @06Speed6; @mazspeedshiz; @Captain KR; @kteevan;
Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq.
#HAR Hidden Agendas Racing
Payne Racing 67 is offline   Reply With Quote
The Following 7 Users Say Thank You to Payne Racing 67 For This Useful Post:
06Speed6 (01-09-2013), Code Monkey (01-13-2013), danieldolina70 (01-12-2013), dturboman (01-11-2013), jm211 (01-10-2013), Juyoung (04-24-2013), SLOWHATCH (04-19-2013)
 Old 01-09-2013, 08:52 PM   #2
dantes5823's Avatar
Posts: 6,576   (View Stats)
Same issue, still works tho. It has its days. Also @Payne Racing 67; maybe include trans fluid just to know all the variables, maybe shifter parts as well.
12' Speed3
Not sure on mileage but early teens.
Probably fully bolted already.
Popped out of gear one day.
Sure SSP. Fomoco trans fluid.
The Following User Says Thank You to dantes5823 For This Useful Post:
Payne Racing 67 (01-09-2013)
 Old 01-09-2013, 09:00 PM   #3
12' Speed3
Thanks Noted
 Old 01-09-2013, 09:03 PM   #4
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
Dan needs to be in here
Skreets be calling...
The Following 3 Users Say Thank You to BobtailedSnail For This Useful Post:
danieldolina70 (01-12-2013), dantes5823 (01-09-2013), Payne Racing 67 (01-10-2013)
 Old 01-09-2013, 09:11 PM   #5
A quote from @06Speed6; in his thread:Broken gears, shift forks, and syncros which basically sums up the issue:
"The synchros are crap which makes it hard to get into the next gear which wears or bends the shift fork which causes the synchro to not fully engage which causes the gears to not completely engage which causes the gear teeth to wear and break which causes the gear grind we have and the inability to use a gear."
Yes him and Joe, can you tag them? Also @superskaterxes; had the issue at one point
@mrdouble99; @Cmoney82; @Nataphen; @Raysfan; @speed3Texas; @BoostinBA; @MS_Driver; @jellowood; A quote from him: "I have the 2nd gear pop out issue at 19,500 miles. Just took it in today and they're talking with Mazda. Mechanic said he saw on their "Techline" that their were numerous speed 3 issues with bushings and fork issues" @harryclay; @akbrazil; @DISIindahead; @ckurth; @alphasaur; @turd burglar; @sliversurfer3; @reddeerspeed3; @England15j; @speed3sailor;
Last edited by Payne Racing 67; 01-09-2013 at 09:37 PM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to Payne Racing 67 For This Useful Post:
06Speed6 (01-09-2013), Jh8909 (01-10-2013), speed3Texas (02-02-2016)
 Old 01-09-2013, 09:13 PM   #6
What's the cost for the repair?
 Old 01-09-2013, 09:20 PM   #7
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
@mrdouble99;
Im gonna retract part of that. Lets try this again...
The shift fork pads are made of nylon which hardens over hundreds of heat cycles and begins to crack, the cracks weaken the pad and slowly become larger, eventually the pad starts breaks apart and you begin to lose the ability to fully engage the syncro which damages the syncro teeth which lose the ability to hold a gear because they are not fully meshing because the broken shifter pad can no longer push them far enough together.
Thats better.
silvapain and Payne Racing 67 like this.
2006 Mazdaspeed 6
The Following 9 Users Say Thank You to 06Speed6 For This Useful Post:
802MS3 (01-10-2013), btstarcher (02-15-2014), Dano (01-10-2013), Jh8909 (01-10-2013), Juyoung (04-24-2013), Payne Racing 67 (01-09-2013), silvapain (01-13-2013), SLOWHATCH (01-10-2013), TWOptSL0W (01-10-2013)
 Old 01-09-2013, 09:24 PM   #8
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
36000 miles lost plastic pads on 1st 2nd gear fork
paid to fix myself, voided warranty for catless exhaust. damn dealers
local trans shop $1800.00
never had any grinds just gone, all at once.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following 2 Users Say Thank You to mxlplx71 For This Useful Post:
danieldolina70 (01-12-2013), Payne Racing 67 (01-09-2013)
 Old 01-09-2013, 09:26 PM   #9
Mfinlay04's Avatar
Posts: 827   (View Stats)
I've only ever driven my Mazdaspeed so IDK if im experiencing the same issue but I do get a second gear grind occasionally.
110k
Royal Purple MTF
I haven't had it pop out on me, but I did find that if i change the pressure on the shifter I can get it to shift without grinding pretty consistently. If I press to hard to the left when shifting from 1st to 2nd I get crazy grind, 50% wont even go into the gear and is a SOB. I've found by allowing it to be in a neutral position from first to second, I shift with just my pointer and middle finger I get a butter smooth shift. Seems like my alignment is off, if that makes sense. I saw a thread that someone posted about fine tuning the shift knob, i might give this a try and see if that improves the shifting quality.
The Following User Says Thank You to Mfinlay04 For This Useful Post:
 Old 01-09-2013, 09:28 PM   #10
Speeeeeed
06Speed6's Avatar
I guess that I should explain something else too, when you pop out of gear you arent actually poping out of gear, the gears are constantly meshed and cannot seperate. Instead they free spin on a shaft and are connected to one half of the syncro, the other half of the syncro is connected to the shaft. The shifter fork pushes both halves of the syncro together which connects the gear to the shaft. So when it pops out of gear, it is actually the splined halves of the syncro poping apart because they arent fully seated.
2006 Mazdaspeed 6
The Following 4 Users Say Thank You to 06Speed6 For This Useful Post:
Code Monkey (01-13-2013), MD1032 (10-19-2014), Payne Racing 67 (01-09-2013), TWOptSL0W (01-10-2013)
 Old 01-09-2013, 09:40 PM   #11
They said $4000...but the guy literally went in, saw the mods, and said that based on that, and the cars "previous history" they can't do it. As per the Magnuson-Moss Act, they by law, cannot do that. I'd like to know what "previous history" the car has had because it's news to me. The only thing I've ever brought the car in for other than routine maintenence was the first time SECOND GEAR died...which in that case would maybe make the guy think that obviously it's a defect in these cars??
The Following 2 Users Say Thank You to Payne Racing 67 For This Useful Post:
06Speed6 (01-09-2013), Mizzle (01-09-2013)
 Old 01-10-2013, 12:40 AM   #12
jkowalski's Avatar
Posts: 289   (View Stats)
jkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the worldjkowalski is the leader of the world
2010 speed 3
Problem started around 33k miles would only pop out of gear when slowing down for bumps. Now 2 weeks later i have to physically hold it into 2nd.
Car is bolted minus the manifolds and tuned with an act 6 puck, jbr ssp, knob, bushings and mounts
2010 Speed3 35r 12.404@120 sold
2014 camaro 1SS 1LE 12.22@115 also sold
2015 Mazda 6 stock ass daily
jkowalski is offline   Reply With Quote
The Following 3 Users Say Thank You to jkowalski For This Useful Post:
danieldolina70 (01-12-2013), Jsn_Rob (01-12-2013), Payne Racing 67 (01-10-2013)
 Old 01-10-2013, 01:44 AM   #13
danieldolina70's Avatar
Posts: 366   (View Stats)
danieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the worlddanieldolina70 is the leader of the world
Mine started 2 weeks after going big turbo, started popping out of gear then two days later no second at all.18000 miles on 2012
[SIGPIC][/SIGPIC]//GT3076r EWG///GUARDIAN ANGEL///JMF INTAKE MANI///COBB EBC///LONG TUBE MANI///RICH TUNE///CPE PRE FILTER///CPE INTAKE and TIP COMBO///CPE TMM AND RMM///TURBO SMART BPV///CPE BIG ASS FMIC WITH CRASH BAR///COOLANT BYPASS///NGK-1 PLUGS///CPE HPFP/// LONG TUBE DP///CPE TRITON CBE///SURE PMM///SURE RSB///AEROFORCE GUAGES///JBR OCC///RALLY ARMOR FLAPS///6000 k HID LOWS AND FOGS///YELLOW-SPEED COILOVERS///KONIG WHEELS WITH 245/40/18 MICHELIN PS2 TIRES /KILLER BUILT TRANS WITH ACT 6 PUCK AND PRO LIGHT FLYWHEEL ////////// NATOR DELAWARE///////////////////////
STICKERS WON'T MAKE YOUR CAR FASTER .BUT HANGING WITH GUYS WITH NATOR STICKERS WILL
321 hp 359 tq Nator Pa. DYNO DAY 10/13/12 WITH KO4 TURBO
369 hp 368 tq NO meth or e85 ... MNM dyno day ......
danieldolina70 is offline   Reply With Quote
The Following 2 Users Say Thank You to danieldolina70 For This Useful Post:
 Old 01-10-2013, 01:54 AM   #14
mxlplx71's Avatar
Groans: 128
all need aluminum fork pads
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following 3 Users Say Thank You to mxlplx71 For This Useful Post:
danieldolina70 (01-10-2013), James Geese (02-08-2013), Payne Racing 67 (01-10-2013)
 Old 01-10-2013, 01:55 AM   #15
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
This is seriously a nightmare. Can't believe this happens to so many people.
www.tunedbynishan.com
The Following 4 Users Say Thank You to ms3blackmica For This Useful Post:
danieldolina70 (01-10-2013), Juyoung (04-24-2013), mxlplx71 (01-10-2013), Payne Racing 67 (01-10-2013)
 Old 01-10-2013, 03:41 AM   #16
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
08 ms3
Pops out of 2nd gear on decel
Started around 40-50k
....also caused motor to explode...twice
The Following 6 Users Say Thank You to TWOptSL0W For This Useful Post:
danieldolina70 (01-10-2013), Dano (01-10-2013), dantes5823 (01-10-2013), memin (02-05-2013), Payne Racing 67 (01-10-2013), Voltron (01-15-2013)
 Old 01-10-2013, 04:17 AM   #17
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
2009 Mazdaspeed 3
First time happened around 15k miles. Had it rebuilt under warranty. Lost 2nd and 4th maybe 20k later. Received new trans under warranty.
Fully bolted except manifolds on stock clutch. Also had a short shifter which I think is partially to blame. Now just base bushings and a heavy knob and shits butter.
Popped out on decel, had to physically hold it in place. 4th quit life completely.
NATOR PA
The Following 2 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
Payne Racing 67 (01-10-2013), trf5000 (01-10-2013)
 Old 01-10-2013, 05:11 AM   #18
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
2010 ms3 - purchased with around 30k and at 38k now.
Mine grinds into 2nd when I try to shift quickly. No issues with it popping out (yet).
Added a JBR SSP, CS RMM inserts, and FO MO CO fluid. Better but still does it on occasion.
Matt
 Old 01-10-2013, 07:30 AM   #19
Kempdipspeed6's Avatar
Posts: 1   (View Stats)
Kempdipspeed6 will become famous soon enough
2006 MazdaSpeed6(RIP)
44k when purchased.
Problem occurred at around 50k
One day I down shifted into 2nd gear going maybe 20 mph and I noticed it was not in gear anymore. Sometimes the car would grind in this gear as well along with upshifting it would pop out depending on how I would shift I guess you can say but I did notice that would happen sometimes. Now I'm not sure if you guys can tell but while the car is in 2nd gear keep a light hand on the shifter and you'll feel the car coming out of gear there will be a vibration from the shifter. Now the car was completely stock no accidents or anything at this point in time. This issue was not fixed I got hit with the wear and tear bull shit so it was not covered but also, anybody who lives in the upstate NY area do not go to Compass Motors in Middletown NY,10940 they ruined my stock motor and forced me to do a build on my car screw them bastards.
First post was for you Mr. Payne!
-John K.
Kempdipspeed6 is offline   Reply With Quote
The Following User Says Thank You to Kempdipspeed6 For This Useful Post:
 Old 01-10-2013, 07:38 AM   #20
trf5000's Avatar
Posts: 2,290   (View Stats)
Mine is only angry when its cold, as soon as it warms up its fine. I also have the fomoco fluid.......
I am sure I will be on this list eventually.
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
The Following User Says Thank You to trf5000 For This Useful Post:
 Old 01-10-2013, 07:52 AM   #21
Here is a Youtube video showing the issue, and there are numerous comments from others with the issue.
Dumyz (01-12-2013), Juyoung (04-24-2013), MrPrime (01-12-2013)
 Old 01-10-2013, 08:00 AM   #22
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
amoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the world
Groans: 53
Groaned at 31 Times in 22 Posts
Sort of seems like a different material is needed for these shift pads. If people are losing gears with >30k miles, some serious wear is happening here.
You know.... Moose stuff
amoosenamedhank is offline   Reply With Quote
The Following User Says Thank You to amoosenamedhank For This Useful Post:
 Old 01-10-2013, 08:44 AM   #23
Mine was Completely gone by 18,000 miles on a 2012 ,,, I'm missing my Subi
The Following User Says Thank You to danieldolina70 For This Useful Post:
 Old 01-10-2013, 08:53 AM   #24
Yup its ridiculous. If it doesnt work, join me in going back to the Mustang world???
 Old 01-10-2013, 09:27 AM   #25
x09MS3GT's Avatar
Posts: 409   (View Stats)
x09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the world
Groaned at 92 Times in 11 Posts
08.5 MS3
33k miles.
I do not have problems popping OUT of 2nd gear, however, I DO have problems getting INTO 2nd gear if i shift anywhere under 2500 rpm from first.
I've found that if i double clutch 2nd it goes in smooth without a problem. While it is a pain in the fucking ass, ive learened to just double clutch that gear without even thinking about it anymore. It's annoying as fuck.
4th seems to do it as well on occasion, but like i mentioned above, its usually when shifting into the gear below 2500 rpm.
--Cobb Sri--Cobb Tip--Cobb Airbox--Cobb Fmic--Cobb Bpv--Cobb Turbo-back----Cobb V3 Ap--Cobb Rmm--Jbr Pmm--Jbr Tmm--Cobb Sts----6510's--Autotech's--KW V2'S--Jbr Fsb--Jbr Rsb--STOPTECH Sport Kit--E30 FREEKTuned --
x09MS3GT is offline   Reply With Quote
The Following User Says Thank You to x09MS3GT For This Useful Post:
BottleOfCola13 (05-08-2013)
 Old 01-10-2013, 10:10 AM   #26
England15j's Avatar
Posts: 1,910   (View Stats)
2010 ms3 purchased at 10k miles, 2nd gear would pop out on downshift when releasing the clutch. After I noticed it happening took about 2-3 weeks till physically having to hold in 2nd. Mods at the time were intake, tip, test pipe, jbr ssp, and shifter base bushings. Stocked out took it in and no issues on warranty exact miles were 20463 at the time if rebuild
 Old 01-10-2013, 01:24 PM   #27
dturboman's Avatar
Posts: 1,174   (View Stats)
dturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the world
Odd my tranny has been a beast, 167k on it not one issue...running RL fluid, many 2nd gear 5500rpm drops too.
dturboman is offline   Reply With Quote
The Following 4 Users Say Thank You to dturboman For This Useful Post:
Juyoung (04-24-2013), Payne Racing 67 (01-10-2013), skeeter149 (01-12-2013), Voltron (01-15-2013)
 Old 01-10-2013, 05:26 PM   #28
Because it isnt an issue of power, its an issue of poorly made parts, some are lucky
Sent from the Smurfmobile
 Old 01-10-2013, 05:32 PM   #29
alphasaur's Avatar
Posts: 2,847   (View Stats)
Groans: 235
Did pablo tell you about my woes?
car:2008 Mazdaspeed 3
mileage: Bought the car with 63k, noticed the issue about a week after I had it (presumably had the issue prior to buying and I never really noticed it)
How it happened/progressed: 2nd gear engine braking
When it happened ie down/upshifting: I only noticed it while engine braking in 2nd, the gear would pop out. RECENTLY occasionally grinding gears. Seems to have gotten worse and worse over time with the pop out, only a few seconds of engine braking and pops out.
Stock? or what mods? Shifter parts ie sts, knob, etc.: Bought the car with a cobb ap, intake and rmm. Started using a heavy shit knob and it somewhat alleviated the issue for a few months. Also installed full mounts hoping it was a bad mount fucking it up.
Using FoMoCo fluid?: Yup.
Was it covered/repaired: Out of warranty. Bought the car at 63k, had 84.5k when I put in a new transmission.
Did it happen again?: only 1k on the new transmission, knock on wood it doesn't. I always rev matched and I feel that bought me a few K miles as 2nd gear was still usable 20k after noticing the issue, I will continue revmatching. I've kinda learned to drive without 2nd/ease it in to second so I'm hoping to avoid the issue again
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/lol nator.
 Old 01-10-2013, 05:41 PM   #30
thehead's Avatar
Posts: 1,141   (View Stats)
thehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the world
Groans: 143
after having my tranny go out, I had the extended warranty, mentioned the Magnuson-Moss act and they laughed at me basically, just an fyi, it won't help you win your case, at least it didn't me and everyone else I've seen on the forums (mostly subaru) mine was about $3000 to rebuild (with installation, etc)
2016 BMW M235i
[Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles
Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals
Electrical - GS EBC - Cobb AP Richtune in progress
Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's
Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40.
thehead is offline   Reply With Quote
The Following User Says Thank You to thehead For This Useful Post:
 Old 01-10-2013, 05:44 PM   #31
alphasaur's Avatar
Groans: 235
magnuson-moss really only works if you lawyer up...and that ends up costing you more in the end.
I bought a transmission off the forums, act 6 puck & prolite, and super install from pablo and ended up at ~$2k. It's probably cheaper to buy a new transmission and swap in than rebuild.
Dano likes this.
/speed 3- bye
/lol nator.
The Following 2 Users Say Thank You to alphasaur For This Useful Post:
Dano (01-10-2013), Payne Racing 67 (01-10-2013)
 Old 01-10-2013, 05:52 PM   #32
Interesting to see that more gen2 owners have this issue.
Also, the people that have had the issue, have you determined a way to see if the transmission has the problem when out of the car (ie buying used?)
@Tomas; can chime in as well since he's taken his tranny apart at least a couple of times.
Payne Racing 67 likes this.
Last edited by Lex; 01-10-2013 at 05:52 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-10-2013, 05:58 PM   #33
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
@Captain KR and @superskaterxes are having this issue as well....I think
 Old 01-10-2013, 05:58 PM   #34
Originally Posted by RichieRichness View Post
@ is having this issue as well....I think
Yea he is
 Old 01-10-2013, 06:05 PM   #35
Ray Danger 2020's Avatar
Posts: 768   (View Stats)
Ray Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the world
Mine seems to only pop out once in a very blue moon. Usually when leaving work. I park next to my boss's house and he's pretty old so I don't want to annoy him so I get outta there pretty quickly with the car relatively not warmed up. It's a slight downgrade (and I mean slight) going down tithe stop sign and I'm usually going about 25mph or so. When I let off the gas to slow down it might pop out. It's only doe it a few times and I thought it may have been my fault maybe not putting it in gear all the way. Also I occasionally have trouble going 1st-2nd when WOT. Again, once in a blue moon. Never when I'm racing. Always seems to happen when I'm just trying to show off and it makes me look like a noob grinding gears.
Anyway.
Ray
'12 BM3 ~20,000mi
All mods in sig. Still factory trany fluid.
Happened mostly around like 12-15,000mi.
Power: BORG WARNER S360 TURBO w/ .70A/R SINGLE SCROLL HOTSIDE HTP 3.5" WHALE PEEN TIAL 44mm EWG (red) FJ PERFORMANCE TUBULAR MANIFOLD w/ VBAND EWG OUTLET/VBAND CATLESS DP/VTA EWG TUBE/FMIC PIPING - HOTSIDE ROUTED UNDER CAR/AN OIL FEED/DRAIN LINES ULTIMATE RACING CBE TREADSTONE TR1035 FMIC CORE AUTOTECH HPFP INTERNALS COBB TUNING ACCESSPORT GO FAST BITS TMS RESPONS BOV NGK LTR7IX-11
Handling: JAMES BARONE RACING RSB/88aRMM/88aTMM/80aPMM SONIC TUNING S3 COILOVERS STOPTECH SPORT STOP CROSS DRILLED ROTORS BRIDGESTONE POTENZA RE-11 235/40/18 SPC REAR CAMBER ARMS
Extra Shit:SURE SHORTCUT/COUNTERSHIFT/ANCHORS JAMES BARONE RACING SPHERICAL HEAVY KNOB/51r BATTERY TRAY/STAGE II OCC CORKSPORT LED REAR BUMPER REFLECTORS/LED INTERIOR KIT/URETHANE EXHAUST HANGERS/GAS HOOD PROP STRUTS BOSCH 3-BAR MAP SENSOR BITWISE PnP MAP HARNESS COBB TUNING 3-PORT EBCS DDM TUNING 8000K LOWS/3000K FOGS O.Z. RACING ULTRALEGGERAS 18x8 +48 MUTEKI SR48 OPEN ENDED LUGS NUTS ARP 100-7708 EXTENDED WHEEL STUDS HELLA SUPERTONES RALLY ARMOUR MUDFLAPS (BLACK WTH RED LETTERS)
K04 POWER FIGURES
277HP/325TQ SixTuned On 93
314HP/356TQ Rfinkle2 Tuned With 33% Corn
S360 POWER FIGURES
365HP/356TQ Purple Drank Tuned ON 93
421HP/392TQ Purple Drank Tuned w/ 3 GAL E85 MIX
NUMBERS LIMITED BY STOCK BLOCK ON STOCK FUELING TILL SPRING
Ray Danger 2020 is offline   Reply With Quote
The Following 2 Users Say Thank You to Ray Danger 2020 For This Useful Post:
alphasaur (01-10-2013), Sei Ling Kha (11-19-2015)
 Old 01-10-2013, 06:06 PM   #36
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
07, 61.5k miles, bought at 43.5k miles ~13 months ago, not a single issue. When going from 2nd to 3rd I miss it sometimes, but that's on me. short shift plate/bushings/knob/yaddayadda for 15k miles or so now. I've been to VIR and a race or two, never had a tranny issue.
I know this doesn't really add to the broken tranny thread, but just throwing my experience in there.
Blue Pu.
 Old 01-10-2013, 06:11 PM   #37
alphasaur's Avatar
Groans: 235
I'd only buy used from someone reputable on the forums. Not sure how you'd be able to tell w/o taking it apart.
/speed 3- bye
/lol nator.
 Old 01-10-2013, 06:31 PM   #38
jm211's Avatar
Posts: 943   (View Stats)
I agree.
Most on here mod, most on here drive hard(er) than most. This shouldn't even be a problem with heavily modded cars. I understand if you grind every 3rd shift but this shouldn't be happening even if you drive it hard, correctly.
I think someone cheaped out on parts or just another design flaw on the platform.
I have the works shifter wise: Heavy weight, SSP, Anchors, shift weight, Amsoil. I don't have pop out issues as I don't downshift. I don't downshift because I'm afraid it will go toast. I do get resistance mid shift and the usual clunking (clunking within gearbox, not a Motor mount)
55k miles
The Following User Says Thank You to jm211 For This Useful Post:
 Old 01-10-2013, 06:33 PM   #39
ArcticSpeed3's Avatar
Posts: 543   (View Stats)
ArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the world
2011 Speed3. Started at 13k miles, owned the car since new with 21 miles. Randomly started grinding while downshifting to 2nd, then started to pop out, then wouldn't go in gear at all. Mods in sig, Sure shift weight, anchors and JBR weighted knob. Stock Mazda trans fluid
Stocked it out when I took it to the dealership. Was covered under warranty. But was told they got me a brand new trans, but discovered that they lied and just rebuilt the broken parts in the trans. Currently at 25K miles and hasn't happened again. I drag race my car pretty heavily. I put about 300 1/4 mile passes on it last summer.
2006 MS6 BCM
"Fully Bolted, DSS Rear Axles, Soon GTX3076R, SB Stg 3 Drag Clutch, 6th Port" (DRAG CAR)
2009 Chevy TBSS AWD 3SS
"Full Exhaust, Intake, Tune" (MAN VAN)
1997 Lexus SC300 Black/Black
"2JZGTE, BW S366 @15psi" (SOLD)
2011 MS3 CBM
"Fully Bolted" (Parted Out and Sold)
ArcticSpeed3 is offline   Reply With Quote
The Following User Says Thank You to ArcticSpeed3 For This Useful Post:
 Old 01-10-2013, 06:42 PM   #40
TheFlash's Avatar
Posts: 2,095   (View Stats)
09 MS3
43k
When cold 2nd will grind in if I move straight down from 1st. I have to shift in neutral and then down into 2nd to avoid the grind.
No pop out issues just that nasty grind going into 2nd cold.
I drive a Mazda
The Following 2 Users Say Thank You to TheFlash For This Useful Post:
doublea (01-13-2013), jm211 (01-10-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/official-2nd-gear-dead-thread-134845/
Thoughts on a speed6 : cars This thread Refback 11-17-2014 08:02 PM
Is this a good deal? : cars This thread Refback 05-30-2014 02:35 PM
06/07 mazdaspeed 6 or 2013/14 mazda 6? : cars This thread Refback 04-18-2014 03:25 PM
[NSW] Potential future MPS owner - Common faults? This thread Refback 07-28-2013 10:20 PM
Transmission / clutch help This thread Refback 04-10-2013 09:26 PM
Forum Mazda Performance Series - Zobacz temat - Biegi - hacz?ce/blokuj?ce/ci??ko wchodz?ce/zgrzytaj?ce... This thread Refback 01-26-2013 04:36 AM
Official: "High Gear" Mustang chosen to be SEMA's first all-female build [w/video] Haltech Automotive News 0 06-06-2012 03:50 PM
Page generated in 0.63863 seconds with 46 queries
