Like Tree40Likes
 Old 12-14-2011, 07:55 PM   #1
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Neutral  +8 score
Default The Official Downpipe/Test Pipe/Race Pipe Thread
**** UPDATED 2/2015! Thanks @Inquisitive;!
General:The downpipe on your Mazdaspeed vehicle (whether it's a gen1 MS3, gen 2 MS3 or MS6) is the first part of your exhaust coming off of the turbo. The stock or OEM downpipe on your vehicle contains one catalytic converter. Replacing your downpipe is a common upgrade that results in some very impressive power gains over your restrictive OEM unit, while giving your car a louder, more aggressive exhaust note.
Warning: It has been seen that after upgrading to a 3" downpipe that some vehicles will end up with smoking turbos. This is because of the reduced back-pressure on the turbo seals, which allows some oil to pass by. There are several easy fixes to resolve this issue, the first and simplest fix is to raise the idle on your vehicle through your tuning software. Another simple fix is to swap out the stock oil feed bolt with a smaller diameter feed hole, @bnoon makes and sells these bolts.
A Diagram of the OEM Exhaust:
NOTE: GEN 1 AND GEN 2 DOWNPIPES & TEST/RACE PIPES CAN BE USED ON BOTH GENERATIONS
Things you NEED to know: Downpipes for Mazdaspeed vehicles are manufactured in two different styles. The first style is generally referred to as just a "3inch downpipe", these units will replace your original downpipe and ONLY the original piece (these are generally coupled to a "race pipe" or "test pipe" *SEE DIAGRAM ABOVE*which removes your secondary catalytic converter). The other style is known as a "Long downpipe" or "Full downpipe", meaning the new part will replace BOTH your stock downpipe and also your stock "race/test pipe".
Downpipes are generally sold with two options. They are referred to as either being cat-less or as having a high flow cat (the term cat refers to a catalytic converter). A cat-less downpipe is exactly what it sounds like, it replaces your OEM piece with a new 3" downpipe possessing NO catalytic converters. One possessing a High Flow Cat, also, is exactly what it sounds like, it replaces your stock restrictive cat for a more efficient, higher flowing unit. Generally, cat-less downpipes provide a few more peak ponies and a more aggressive exhaust notes than pieces with a high flow cat, BUT at the risk of the car receiving a CEL (Check Engine Light). Note: If a downpipe contains a high flow cat it is generally a "Long/Full downpipe".
However, there are ways to help prevent this CEL by extending your rear/second o2 sensor away from the main flow of exhaust through the downpipe. Some manufacturers include these fixes with their products, while others do not.
Commonly spark plug de-foulers are used. The first is left alone and the second is drilled out to 1/2", seen here:
Companies also offer o2 extenders taking away the drilling work for you, seen here:
Here are some how-to guides for downpipe removal:
Gen 1 MS3 & Gen 2 MS3: http://www.mazdaspeedforum.org/forum/foru...-review-16310/ and Corksport also wrote a fantastic install guide here: http://support.corksport.com/instruc...-6-113-WEB.pdf REGARDLESS OF MANUFACTURE, ALL INSTALLS ARE RELATIVELY THE SAME BETWEEN 1ST & 2ND GEN MS3'S
You should take care of the HPFP limitations before considering the removal of a cat or going completely cat-less.
The DP is the most restrictive section of your exhaust system. The bell housing is so crimped; it is hard to imagine the waste-gate having enough room to open. It contains cat-1, which is heavy, but not as heavy as cat-2. If required for emissions control, if you do not have the software to cancel the CEL (in AP un-tick codes: P0038 and P0420 (if rear spark plug de-fouler does not work)) or if you are allowed to disable two codes only for emissions testing, you will need a fast cat with following oxygen sensor bung for the second sensor. A DP provides faster turbo response times and power gains across the rev range. The transition from decelerating to accelerating is much smoother. The engine just seems to breathe easier, probably due to the increased VE.
Divorce pipes reduce the turbulence caused by the opening and closing of the waste-gate. Also, the nature of bell housing designs creates turbulence as the chamber is expanded to cater for the turbo outlet and waste-gate. Having dedicated pipes respectively allows for same size pipes and thus, a smoother flow. By joining further down, they help to speed up the extraction resulting in faster opening of the waste-gate.
Descending Genpu purchased popularity order:
DownPipe (DP) and Full / Long DP
• UR DP
• Corksport DP
• CP-E DP & Long DP
• Cobb DP
• ATP Long DP
• eBay DP
• CNT Long DP
• M2 Long DP
• Gutted DP
• Kozmic DP
• Speed Daddy DP
• M2 DP
• TurboXS DP
• Full Race DP
• XForce DP
• AQ Motorsports Long DP
• QAS Long DP
• CES Racing Long DP
• Protuning Lab DP
• Best Mufflers DP
Test / Race / Track Pipe (cat-less) (TP / RP)
• Ultimate Racing (UR)
• CorkSport (CS)
• OBX
• CP-E
• TurboXS
• Street Unit (See Warning)
• Sure (See Warning)
• Cobb
2015 prices and availability:
First Section of Pipe Post Turbo
3” Ultimate Racing (UR) DP
Available from: 3” Ultimate Racing (UR) DP
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) cat-less Version 1 $295, cat-less Version 2 $345, Long DP Ceramic Cat $395, Long DP Metal Substrate Cat $445, extra wideband bung $25)
Corksport (CS) DP
MS6 DP
MS6 Long DP
MS3 DP
MS3 Long DP
Available from:
MS6
CS 6 DP
MS3
CS 3 DP
MS6 (Yes: cat-less $349.99, +$281 for cat (long DP)), MS3 Gen1 (Yes) $299.99 + $281 for cat (long DP) with 65mm or 80mm option, MS3 Gen2 (Yes) $299.99 + $281 for cat (long DP) with 65mm or 80mm option
CP-E Long DP
MS6
MS3
Available from:
MS6
http://cp-e.com/webstore/product/maz...kspl-downpipe/ / MS6 long catted
MS3
http://cp-e.com/webstore/product/maz...kspl-downpipe/ / MS3 long catted
MS6 (Yes, catted) $621.40, MS3 Gen1 (Yes, catted) $504.40, MS3 Gen2 (Yes, catted) $504.40
Cobb Long DP
Available from: Mazdaspeed3 SS 3" Downpipe with High Flow Cat / Long catted MS3 Gen 1&2
MS6 (Not found), MS3 Gen1 (Yes, catted) $695, MS3 Gen2 (Yes, catted) $695
ATP DP
MS6 Long DP
MS3 Long DP
MS3 DP
Available from:
MS6 Long DP MS6 ATP Long DP
MS3 Long DP MS3 ATP Long DP
Much less popular: ATP DP MS3 ATP DP
MS6 (Yes, V-band) $439 + Mazda 5-bolt to V-band $95, MS3 Gen1 (Yes), MS3 Gen2 (Yes) cat-less, no donut, 3”, Long DP $299, DP $259
CNT Long DP
MS3 cat-less
MS3 catted
Available from: CNT Long DP
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) 76mm cat-less $259, catted $399
M2 Long DP
MS6
MS3
Available from:
MS6
 MS6 long cat-less MS6 long cat-less
MS3
MS3 long cat-less
MS6 (Yes, cat-less) $140, MS3 Gen1 (Yes, cat-less) $171, MS3 Gen2 (Yes, cat-less) $171
Kozmic DP
Available from:
MS6
Kozmic MS6 DP
Kozmic MS3 DP
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) V-band for use with CP-E EM only $539.99
Speed Daddy DP
MS6
MS3
Available from: Speed Daddy DP
MS6 (Yes) $318.99 out-of-stock, MS3 Gen1 (Yes) $148.99, MS3 Gen2 (Not found)
TurboXS DP
Available from: http://turboxs.com/shop/mazda/153-ma...-downpipe.html / 3 long cat-less
MS6 (Not found), MS3 Gen1 (Yes, cat-less) $299, MS3 Gen2 (Yes, cat-less) $299
Full Race DP
MS3 Prostock
MS3 EFR
Available from:
MS3 Prostock
Full Race Prostock DP
Full Race EFR DP
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) Prostock $748.99 V-band + $75.34 for MS3, optional $120 silver or black coating on EFR
XForce Full TBE only
Available from: XForce DP
MS6 (Not found), MS3 Gen1 (Not found), MS3 Gen2 (Yes) Australian $1600
Available from: http://www.aqmotorsports.com/product...roducts_id=590
MS6 (Not found), MS3 Gen1 (Yes, catted) $499, MS3 Gen2 (Not found)
QAS Full Exhaust System
Available from:
QAS Full Exhaust System (German)
Translated into English
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Not found) €899 + shipping from Germany
CES Racing Long DP
Available from: CES Racing Long DP
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) Australian $1,299
Protuning Lab
MS6 DP
MS3 DP
MS3 Long DP
Available from: http://www.protuninglab.com/j220ma6madit.html / MS6
http://www.protuninglab.com/dp-ms3-t.html / MS3 Gen 1 Long
http://www.protuninglab.com/doma3tu.html / MS3 Gen 1 & 2 Short
MS6 (Yes, catted) $191.99, MS3 Gen1 (Yes) $181.99, MS3 Gen2 (Yes) $173.99
A Long or Full DP includes the DP and TP / RP. The TP / RP always removes cat-2 and can be purchased with or without resonator delete for use with the OEM / stock DP or aftermarket DP.
MS6 Resonated
MS3
Available from:
MS6
UR MS6
MS3
UR Gen1
1.44 HP, 1.74 more Torque, 3” 304 SS, TIG welded, includes donut gasket, cat-less with resonator option
MS6 (Yes) $125 +$100 Resonated or +$100 Ceramic Cat or +$150 Metal Cat, MS3 Gen1 (Yes), MS3 Gen2 (Yes) $150 +$100 Resonated or +$100 Ceramic Cat or +$150 Metal Cat
CorkSport Power Series Racepipe
MS6 Resonated
MS3
Available from:
MS6
CorkSport Power Series Racepipe MS6 Resonated
MS3
CorkSport Power Series Racepipe MS3
12 WHP by deleting cat-2 (80mm)
MS6 (Yes) $178.99, MS3 Gen1 (Yes) $167.99 (Resonated available), MS3 Gen2 (Yes) $167.99
OBX (Amazon)
MS3
Available from:
MS6
OBX (Amazon) MS6
MS3
OBX (Amazon) MS3
SUS T-304, CNC machined flanges, DUAL-TIG welded
MS6 (Yes) $79, MS3 Gen1 (Yes), MS3 Gen2 (Yes) $not known as out-of-stock
eBay
MS6
MS3
Available from:
MS6
eBay MS6
MS3
eBay MS3
MS6 (Yes) $70, MS3 Gen1 (Yes), MS3 Gen2 (Yes) $85
CP-E Nexus Resonator Delete
Available from: CP-E Nexus Resonator Delete MS3
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $259.69
TurboXS
Available from: TurboXS
3” T304 SS; with TurboXS CBE got 22-26 WHP, 17-30 ft-lbs
MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $177.95
Street Unit (SU)
WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730
3” 304 SS cat-less (weight saving) CNC machined flanges, reuses the stock donut flange system to allow for necessary movement. The removal of the 2nd cat will NOT trigger any check engine lights. The test pipe will bolt right up to both the stock and aftermarket cat-back exhaust systems.
Sure Flow M3 Track Pipe
removes 2nd cat, 3”, 304 SS, CNC machined flanges, TIG welded, re-uses stock donut flange for flex movements, will not trigger CEL
kritz, SpankyCuervo, 2con and 5 others like this.
NATOR PA
The Following 104 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
08.5MS3 (01-08-2012), 09Speed3Z (12-15-2011), 12blkms3 (12-10-2012), 3dpilot (06-09-2012), 93GTS (06-21-2014), Abu Zib (12-14-2011), Addikted To Boost (11-11-2013), ak_spray (12-31-2011), andrewz17 (06-04-2014), Arnie1229 (02-05-2015), AshFromCan (04-12-2014), Awesomesauce (01-06-2012), bmfms3 (01-01-2012), calizoomzoom (11-11-2013), CaptainCode (03-20-2014), Cheapspeed (04-25-2013), Chev954 (01-26-2013), dagrimey1 (08-19-2014), DISIindahead (12-14-2011), dizzydtrain (01-06-2012), donjohnk (08-08-2013), Donut (07-15-2013), Dumyz (06-02-2012), Easter Bunny (01-27-2012), eliwwjd (12-04-2016), Elusivellama (01-22-2012), El_Diablo (11-24-2012), Fail_6 (01-31-2012), FightaX (07-21-2013), fishin53 (01-30-2012), fooqr (01-27-2012), galens47 (04-18-2013), Hobo (02-12-2012), ItsNox (07-31-2013), Jake5713 (12-15-2011), jkowalski (05-13-2012), jksstar (04-04-2015), jracer (01-06-2012), Juyoung (09-02-2012), J_Logik (12-15-2011), KayWhy (08-08-2013), King_Sp33d (01-25-2014), Koke382 (12-20-2012), kwittrr (06-29-2014), kylec_2003 (05-05-2012), LatinKraze (01-06-2012), m249saw (12-23-2011), mayer (02-24-2012), meelo88 (03-21-2013), Micha (02-13-2012), ms3bamf (01-08-2012), Ms3_Miami (02-03-2012), nb6179505 (06-24-2014), Onelovesoccer (12-22-2011), PapaBruno (10-18-2014), phahengpro (12-28-2012), Pointless (08-30-2012), Poohster (12-24-2011), randino69 (05-27-2012), Raymond (04-11-2013), redmnsterut (12-19-2011), RedTape (06-30-2014), rfinkle2 (01-27-2012), RhoadBlock (12-14-2011), Rhys (07-11-2017), richkidone (01-26-2012), rikyrick87 (12-15-2011), shadesofgray19 (12-15-2011), SKiZ0TT (12-20-2011), SLOWHATCH (01-27-2012), Snappy (11-19-2015), SofaKingAwesome (04-29-2015), spals (06-24-2014), SpankyCuervo (09-05-2015), speed3newb (09-08-2014), SpeedLife (08-16-2013), SpeedNess (02-23-2013), Sqc049 (03-21-2012), Stwok240 (01-06-2012), superq7 (01-06-2012), swsmailman (01-10-2014), themytb (05-17-2012), thepatient77 (03-17-2015), TiGraySpeed6 (12-15-2011), treavis (03-01-2013), TriO (12-14-2011), triphop631 (01-06-2012), turbo test (01-04-2012), uncorked11 (12-15-2011), Vader (01-06-2012), Visual7 (08-23-2013), WAHBAM (12-15-2011), Wallespeed3 (10-31-2014), wankular (01-06-2012), warlockfan92 (02-18-2013), Weazsel (06-02-2012), Westbound (01-29-2019), WetzMS3 (08-05-2014), Wicked Kitten (04-23-2014), Worbit (06-06-2013), xfeejayx (03-23-2012), xTRELLx (01-10-2014), ZetaDrift (05-01-2014), zkrick (03-13-2012)
 Old 12-14-2011, 07:57 PM   #2
DISIindahead's Avatar
Posts: 911   (View Stats)
DISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the world
GREAT THREAD!
andale927 likes this.
2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD
2012 Jeep Wrangler Unlimited Sport: Current DD
DISIindahead is offline   Reply With Quote
The Following User Says Thank You to DISIindahead For This Useful Post:
MS3-a(sore)ASS-rex (12-14-2011)
 Old 12-14-2011, 07:59 PM   #3
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
Neutral  +1 score
tom if i could i would cum in your hair right now and slap you till you screamed banana
good job son
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
The Following 12 Users Say Thank You to superskaterxes For This Useful Post:
ak_spray (03-27-2012), brandonlee (09-04-2013), CWP_MS3 (03-13-2013), F4LL3N (06-08-2014), Fail_6 (01-31-2012), i8urgti (12-14-2011), MS3-a(sore)ASS-rex (12-14-2011), RhoadBlock (12-14-2011), Speed3Power (01-21-2014), TiGraySpeed6 (12-15-2011), Worbit (06-06-2013), zpele (02-03-2012)
 Old 12-14-2011, 08:04 PM   #4
Groans: 224
I'm still looking for a good how-to thread for MS6 dp install. If any of you have one just post up the link and I'll add it to the OP.
Thanks.
NATOR PA
 Old 12-14-2011, 09:36 PM   #5
chuckms6's Avatar
Posts: 1,618   (View Stats)
cant leave out m2/ebay products. someone is bound to ask
ebay ms6 dp
m2 ms6 dp
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
The Following User Says Thank You to chuckms6 For This Useful Post:
karl-hungus (12-15-2011)
 Old 12-14-2011, 09:53 PM   #6
RhoadBlock's Avatar
Posts: 793   (View Stats)
Groaned at 7 Times in 4 Posts
How-To: MS6 DP
Tools needed:
Air tools make life MUCH easier
Basic socket set
Extensions
U-Joints
Beer
1. Disconnect battery
2. Remove TMIC (if necessary)
3. Remove heat shields
4. Lift front end as high as possible. Use e-brake & chocks behind rear wheels. Place jack stands in secure location under frame rail.
5. Remove upper and lower O2 Sensors...Carefully.
6. Unbolt DP from CBE. Disconnect 2nd Cat to ease removing DP.
7. Unbolt DP from turbo.
8. Curse Mazda for their stupid 5 bolt flange.
9. Expletives. Blood.
10. Swig beer.
11. Remove DP
12. Ice cold beer
13. Finangle new DP into place. Try not to damage anything in your engine bay in frustration.
14. Bolt DP to turbo.
15. Swig beer. Curse Mazda's 5 bolt again.
16. Bolt DP to CBE
17. Install heat shields, TMIC (if you haven't upgraded to a real IC yet), battery.
18. Ice cold beer. Say either "ehh, wasn't too bad" or "Fcuk you Mazda!"
As accurate as that is, I'll try to find a real write up for you bro. Great thread homie.
2007 MS6 - broked & gone
2006 MS6 - less broked
The Following 13 Users Say Thank You to RhoadBlock For This Useful Post:
15driley15 (05-22-2013), bazzarino (06-23-2012), Ferg (12-16-2011), IBEEDAT (08-27-2013), Jdmzms96 (03-28-2013), johnbarr00 (07-16-2013), Juyoung (03-11-2013), miamispeed3 (08-10-2012), MS3-a(sore)ASS-rex (12-15-2011), randino69 (05-27-2012), redboat (02-22-2013), SKiZ0TT (12-16-2011), TiGraySpeed6 (12-15-2011)
 Old 12-14-2011, 10:28 PM   #7
Postulio4joo's Avatar
Posts: 284   (View Stats)
Postulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the world
Groaned at 14 Times in 6 Posts
145 + free shipping. Wow Ebay has gone alot cheaper.
Postulio4joo is offline   Reply With Quote
 Old 12-15-2011, 04:51 AM   #8
Must Have Teh 10's!
lol omg dont remove the stock manifold on the MS6.
ill do a write up if i can catch some time later
MS3-a(sore)ASS-rex (12-15-2011), RhoadBlock (12-15-2011)
 Old 12-15-2011, 04:58 AM   #9
Jake5713's Avatar
Posts: 1,775   (View Stats)
well done
The Following User Says Thank You to Jake5713 For This Useful Post:
 Old 12-15-2011, 08:50 AM   #10
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
cpe guide for the MS6 attached (wow, it was like 0.2 KB below the limit for attaching )
worked like a champ for my install of the M2 dp
Question-
Looking at the pic included for the MS6 dp from ATP (shown below)
I thought the O2 and spare O2 bungs are the opposite- that is the primary is closer to the turbo?
340hp / 371tq
redboat (01-22-2013), SKiZ0TT (12-16-2011)
 Old 12-15-2011, 10:22 AM   #11
uncorked11's Avatar
Posts: 1,238   (View Stats)
Groans: 165
Thanks trying to decide on one now.
New....Camaro SS/RS
Stocked out selling parts.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
The Following User Says Thank You to uncorked11 For This Useful Post:
 Old 12-15-2011, 10:30 AM   #12
RhoadBlock's Avatar
Holy hell IDK why I wrote that. It was too late for me to be typing I guess lol. Edited that post. Good catch bro
 Old 12-15-2011, 10:33 AM   #13
2011speed's Avatar
Posts: 1,497   (View Stats)
I think a nice addition would to this thread woukd perhaps list some dynos and gains. otherwise nice job
Sent from my left nut.
white'swhiteMPS likes this.
FreeKtuned
fitty fitty
The Following 3 Users Say Thank You to 2011speed For This Useful Post:
chaser27 (01-09-2014), Ferg (12-16-2011), Juyoung (03-11-2013)
 Old 12-15-2011, 10:41 AM   #14
J_Logik's Avatar
Posts: 129   (View Stats)
J_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the world
What a GREAT summary, thanks OP!!!!
2010 VRM MS3
JBR RMM, AUTOTECH HPFP INTERNALS,
FORGE V2 BPV, DDM 6K LOWS, 8K FOGS, LED SWITCHBACK PARKING LIGHTS, RED CALIPERS
J_Logik is offline   Reply With Quote
The Following User Says Thank You to J_Logik For This Useful Post:
 Old 12-15-2011, 10:44 AM   #15
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Thanks Tom, Well done Sir! Now I'll have to find a nurse for you!
@MS3-a(sore)ASS-rex
Nator is what it does.
 Old 12-15-2011, 11:05 AM   #16
Seems like there should be some reference to turbo seals/ vacuum issues / smoking issues that suddenly get very popular after adding in a DP...
Loving my home made bnoon bolt- stopped ~90% of my smoking issues along with an idle increase
340hp / 371tq
 Old 01-06-2012, 02:14 AM   #17
infeKteDx's Avatar
Posts: 385   (View Stats)
infeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the world
Groaned at 46 Times in 20 Posts
Anyone have this ?
M2 Performance
infeKteDx is offline   Reply With Quote
 Old 01-06-2012, 03:04 AM   #18
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Awesome !! Thanks
Sebs6 likes this.
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
MS3-a(sore)ASS-rex (01-06-2012)
 Old 01-06-2012, 03:21 AM   #19
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
You might want to add a section for eBay pipes since they're awesome and a better price and quality than some of those
The Following User Says Thank You to TWOptSL0W For This Useful Post:
karl-hungus (01-09-2012)
 Old 01-06-2012, 05:08 AM   #20
+1 to the above posts on the M2 & ebay dp's.
Mine (an M2 from ebay) is so far holding out well, and no over boosting issues here (yet...), running 20 psi on my everyday tune
340hp / 371tq
IshiKage (01-08-2012)
 Old 01-06-2012, 12:48 PM   #21
chuckms6's Avatar
Originally Posted by infeKteDx View Post
Anyone have this ?
M2 Performance
told you so @RhoadBlock lol
and OP yea two of my friends have one and im getting one in a few weeks. imo no reason to get a more expensive one other than namebrand.
 Old 01-06-2012, 01:32 PM   #22
RhoadBlock's Avatar
What did I ever say about eBay DPs?? lol
 Old 01-06-2012, 01:47 PM   #23
Groans: 224
I'm not posting eBay DP's for the simple fact none of our vendors offer them. And I'd rather see our members buy from them personally.
Besides all of your posts cover the eBay one pretty well lol
alansxe likes this.
NATOR PA
 Old 01-06-2012, 02:35 PM   #24
chuckms6's Avatar
sorry @RhoadBlock i thought this was your thread for some reason lol
and i thought the point of these threads was to reduce noob questions as a whole, so i just thought it would be a good idea to include them regardless of vendor status because people are going to ask about them
TiGraySpeed6 likes this.
 Old 01-06-2012, 03:01 PM   #25
Groans: 224
Neutral  -1 score
If you haven't noticed there should be enough posted about them in just the comments to give people enough answers towards them lol
NATOR PA
 Old 01-06-2012, 03:23 PM   #26
chuckms6's Avatar
this is true, but then you have true noobs such as above who only read the first post...but then again i suppose they could be told to read the whole thread just as easily lol
 Old 01-06-2012, 03:24 PM   #27
Groans: 224
You make a good argument regardless lol
NATOR PA
 Old 01-06-2012, 07:55 PM   #28
infeKteDx's Avatar
On the M2, is that the before/after o2 bungs right next to each other at the top? lol, or is there a lower bung that isn't seen?
 Old 01-06-2012, 08:17 PM   #29
chuckms6's Avatar
there are three bungs total on the m2, two at the top and one at the bottom. all the bungs come with plugs.
 Old 01-08-2012, 07:34 PM   #30
infeKteDx's Avatar
07 08 09 Mazda Mazdaspeed 3 Turbo 3" Down Pipe Downpipe | eBay
Will that one fit the 2010's? I was going to go with the M2, but this one is a little cheaper, and the end of the M2 one has a part that sticks out passed the flange?
 Old 01-08-2012, 09:26 PM   #31
That ebay link is an M2 dp. Sorry I can't say what years it will fit, I'm not sure of the speed3 exhaust difference between years/generations
Also, FWIW, that's the same vendor I purchased my M2 dp from on ebay.
340hp / 371tq
thems3driver (03-15-2014)
 Old 01-08-2012, 09:28 PM   #32
infeKteDx's Avatar
Do you know why some of them have the extension after the flange at the end?
for example:
Stainless Steel Exhaust Downpipe Mazda 07 08 09 10 Mazdaspeed 3 Hatchback | eBay
and then this one doesn't:
confused
 Old 01-08-2012, 10:09 PM   #33
Bob-o's Avatar
Posts: 1,312   (View Stats)
for example:
confused
Cause it's a loose flange that can move up and down the pipe...
The Following 2 Users Say Thank You to Bob-o For This Useful Post:
infeKteDx (01-08-2012), Nliiitend1 (01-08-2012)
 Old 01-08-2012, 10:12 PM   #34
infeKteDx's Avatar
Wow...awesome, thanks for clearing that up haha.
 Old 01-08-2012, 10:13 PM   #35
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 01-08-2012, 10:39 PM   #36
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
all of the dps on ebay are the same, they are just sold and named by different vendors. have had my ebay dp for 1 year still going stong looks good no CELS
My Ebay DP
2015 Mazda 6
 Old 01-08-2012, 10:54 PM   #37
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
Says the guy that doesn't believe in aftermarket downpipes....
 Old 01-08-2012, 11:59 PM   #38
2011speed's Avatar
Lol i believe in them, but i dont believe ud get much more than 5 whp and 10wtq.,which in my opinion is not worth the hassle.
FreeKtuned
fitty fitty
 Old 01-09-2012, 12:22 AM   #39
Ur moms boyfriend
Groans: 70
Ohh is that what it is?
 Old 01-09-2012, 07:38 AM   #40
RhoadBlock's Avatar
I agree...if we actually have ANY dynos of before/after DP only. But how many ppl have spent the money to do that?
The Following 2 Users Say Thank You to RhoadBlock For This Useful Post:
2011speed (01-09-2012), chaser27 (01-09-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/official-downpipe-test-pipe-race-pipe-thread-99627/
catless downpipes cause turbo to blow seals?? - Page 4 This thread Pingback 11-10-2014 11:55 AM
Tuner/garage in Brampton/Mississauga area This thread Refback 08-02-2014 08:51 AM
Downpipe options - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Pingback 07-22-2014 10:53 AM
?????????? ?? ??????? 6 mps This thread Refback 02-15-2014 02:51 PM
Aide pour choisir downpipe - Mazda 3 Quebec This thread Refback 08-06-2013 07:10 AM
Mazdaspeed stage 2 downpipe vs racepipe This thread Refback 06-19-2013 09:31 AM
Cat'd DP? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 04-21-2012 07:39 PM
I HATE heat shielding. MPS 6 Post #6 Pingback 12-23-2011 02:44 PM
Which Race Pipe/Test Pipe is the best for a Mazdaspeed 6? ItalianSA MazdaSpeed 6 - Engine, Transmission & Driveline 6 04-20-2009 12:14 PM
Page generated in 0.71840 seconds with 39 queries
