Like Tree40Likes
 Old 11-21-2015, 09:57 PM   #361
robbspeed's Avatar
Posts: 1,074   (View Stats)
robbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the world
Groans: 50
Originally Posted by Gitcherex View Post
Yes, ive got them, thought those were just for tuning though. Ill try and pull up the logs and see how they look.
Open accessport manager with your accessport hooked up to the computer. Click filter and select "logs". It should give you list of every log on your accessport. Select the log you want to look at and click the save to computer button. It should be to the right of the list. Once its saved open ATR and click "view". Then select "data log viewer". Then click "file" and select "open data log". You should then see the log you saved and open it.
2011 Mazdaspeed3 w/ tech package
Totaled/ R.I.P.
robbspeed is offline   Reply With Quote
 Old 11-23-2015, 08:57 AM   #362
570msp's Avatar
Posts: 102   (View Stats)
570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold
you can also read the logs in excel as a spreadsheet.
2006 Mazdaspeed 6 rebuilt with v6 rear end
CPE TMIC || Cobb SRI + TIP || Grimmspeed 3 port EBCS || Forge BPV V1 || UR Test Pipe || CPE Single Exit Exhaust || JBR heavy shift knob and shifter bushings || JBR RMM || SU short throw || Corksport Stubby antenna || Glowshift boost and voltage gauges || CS Mudflaps
570msp is offline   Reply With Quote
 Old 12-01-2015, 11:55 PM   #363
Gitcherex's Avatar
Posts: 103   (View Stats)
Gitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud of
Ive been searching for information regarding the Mazda donut exhaust gasket. Haltech recommended it in his how-to thread and there was another thread where cpe was quoted to have said no gasket is required for the meet up between dp and cbe. Once again, Im asking here as to not make a new thread lol (as it is related to downpipes). any recommendations?
Gitcherex is offline   Reply With Quote
 Old 12-02-2015, 05:43 AM   #364
robbspeed's Avatar
Groans: 50
Are you asking about a donut gasket or what downpipe to get?
Totaled/ R.I.P.
 Old 12-02-2015, 06:15 AM   #365
zjnspeed3's Avatar
Posts: 1,436   (View Stats)
I have the Cp-e catless downpipe and I didn't use a donut gasket. Car runs fine and haven't heard any exhaust leaks yet.
 Old 12-02-2015, 06:49 AM   #366
Rommel043's Avatar
Posts: 27   (View Stats)
Rommel043 is just really niceRommel043 is just really niceRommel043 is just really niceRommel043 is just really niceRommel043 is just really nice
yeah I got an EBAY M2 catless downpipe and this flange end literally bolts into the stock CBE
picture attached is also a CP-E downpipe
2012 MS3 BM TECH - COBB SRI - COBB TIP - CORKSPORT TMIC - TURBOSMART KOMPACT BPV - M2 LONG CATLESS DP - AUTOTECH INTERNALS - ACCESSPORT V3 - COBB RMM
PURPLE DRANK TUNED
Rommel043 is offline   Reply With Quote
The Following User Says Thank You to Rommel043 For This Useful Post:
Gitcherex (12-02-2015)
 Old 12-02-2015, 08:25 AM   #367
Gitcherex's Avatar
i was asking about the donut gasket lol. Ive got the m2 being shipped now and I wanted to make sure that I had everything I needed for the install. ive seen 2 mentions of it, both with differing views
 Old 12-02-2015, 08:33 AM   #368
robbspeed's Avatar
Groans: 50
Oh. When I installed mine I had to use an adapter and the new donut gasket I bought didn't fit the catback side of the adapter some how. So I just put a good 40 ft lbs on the bolts and they don't leak one bit. So you can get away with not using it.
Totaled/ R.I.P.
The Following User Says Thank You to robbspeed For This Useful Post:
 Old 12-02-2015, 01:34 PM   #369
Gitcherex's Avatar
sweet thanks guys! Now i dont gotta worry about having a leak lol. Upgrade next week!
littleloogy likes this.
 Old 12-20-2015, 10:06 PM   #370
aviator79's Avatar
Posts: 3,934   (View Stats)
Ebay DP that was on car needed new flex pipe and wanted to install cat.
 Old 01-14-2016, 10:26 PM   #371
Richys10's Avatar
Posts: 61   (View Stats)
Richys10 is a jewel in the roughRichys10 is a jewel in the roughRichys10 is a jewel in the rough
Groaned at 12 Times in 3 Posts
Not too sure what to get. What will give me th most gains, a OBX turbo back exhaust or just a CNT long Catless downpipe with OEM cat back?
Richys10 is offline   Reply With Quote
 Old 01-15-2016, 05:14 AM   #372
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Either way is fine. The OBX will give you a more aggressive sound. However, from what I've seen, its one of the quieter aftermarket exhausts.
Just as an FYI, several people have had fitment issues with the speed daddy catless DP; myself included. Its made a bit short. The DP still fit, but it pulled my entire exhaust forward to mate up with the DP. Had to use C clamps to install it the first time.
Oh, and an extended rear o2 causes a CEL on the Pus. So if you can, one without an extended bung would be preferred. If you have the funds, have someone either cut it or weld in a normal one altogether, before you have it installed. Or do what I do, install it and shut the check engine lights off. lol
Richys10 likes this.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 02-11-2016, 07:00 PM   #373
T_DUBL_U's Avatar
Posts: 5   (View Stats)
T_DUBL_U will become famous soon enough
I've done some searching and haven't really found an answer, but I have a 09 ms3 and the catback and the tail say mazdaspeed. I assume this is an upgrade over stock but I can't find anything about it. Will I be better off getting another catback or is the mazdaspeed version as good as the others.
T_DUBL_U is offline   Reply With Quote
 Old 02-12-2016, 05:10 AM   #374
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
A catback is purely sound, so go with whatever tingles your sack.
Rich Tuned
330WHP and 363TQ
PapaBone (02-12-2016)
 Old 02-12-2016, 12:08 PM   #375
Richys10's Avatar
Default O2 sensor extender
I just bought a CNT catless Downpipe and wanted to use a O2 sensor extender but can't seem to find where to buy one. I'm not sure if the Downpipe already comes with one but does anyone know where I can get an O2 sensor extender? in case mine doesn't come with one
 Old 02-12-2016, 12:22 PM   #376
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
You don't want one. Read my post a few posts up about the extenders.
Rich Tuned
330WHP and 363TQ
 Old 02-12-2016, 11:51 PM   #377
Richys10's Avatar
Ok I see. But arnt O2 sensor extenders made to prevent CEL. How would it cause it to have a CEL?
 Old 02-13-2016, 04:59 AM   #378
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Well the point of them is to lift the o2 out of the stream of emissions so it doesn't read an excessive amount of emissions passing after the cat. However, on our cars (more specifically the 2nd gen) lifting the o2 out of the stream makes the sensor read too little emissions, and it believes the sensor is failing.
I have read of people not even getting a CEL on a catless DP that had a standard bung. With that said, I personally have CELs from the extended bung on my DP. It thinks my o2 sensor is shot, and its probably right these days, after running e85 for like 3 straight years.
Rich Tuned
330WHP and 363TQ
Richys10 (02-13-2016)
 Old 02-13-2016, 09:08 AM   #379
Richys10's Avatar
Ohh ok I see . Makes sense. Thanks man!
 Old 05-10-2016, 03:16 PM   #380
Khang88's Avatar
Posts: 20   (View Stats)
Khang88 is on a distinguished road
How do you guys feel about ebay downpipes?? Crap? Or descent?
Khang88 is offline   Reply With Quote
 Old 05-10-2016, 03:47 PM   #381
T_DUBL_U's Avatar
Ive had mine for about 3 months and no problems. I have heard people having cracks at the welds. Speed daddy seems to be the way to go for the ebay DPs.
The Following User Says Thank You to T_DUBL_U For This Useful Post:
Khang88 (05-10-2016)
 Old 05-11-2016, 06:57 AM   #382
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Ebay is fine. Some on the pus have been short, and it still fits, but as far as I know the 6 its always been fine.
Rich Tuned
330WHP and 363TQ
Khang88 (05-11-2016)
 Old 05-11-2016, 07:16 AM   #383
Gitcherex's Avatar
Ive had my m2 catless downpipe (ebay) for almost 6-7 months now. Only issues I've had is their crappy ass gaskets. Mine burnt to a crisp lol
The Following User Says Thank You to Gitcherex For This Useful Post:
 Old 05-11-2016, 08:09 AM   #384
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
I reused my stock gasket. Fuck their shit.
Rich Tuned
330WHP and 363TQ
 Old 05-11-2016, 08:12 AM   #385
Gitcherex's Avatar
I went back in 2 weeks ago and put the oem dp gasket back on. Tried using some 800* gasket maker to fix the gasket on the vband-3inch pipe (dont recall what its actually called), seems to have worked but idk lol
 Old 05-11-2016, 08:36 AM   #386
Khang88's Avatar
So as far as quality with the downpipe itself and power gains, it good?
 Old 05-11-2016, 08:44 AM   #387
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Power gains on stock turbo are pretty minimal compared to a test pipe only car. You may have a few more over them, but not much. 3-5+ whp. It will definitely spool faster than a catted car for sure. I mean, a K04 is instant spool, but it was definitely noticeable and way more aggressive ramping IMO.
When it comes to BT, you will need the DP.
Personally, an ebay DP and TP are relative in price. Might as well get the m2 DP and do it right to begin with.
Rich Tuned
330WHP and 363TQ
 Old 05-11-2016, 08:53 AM   #388
Rommel043's Avatar
Yeah I agree^^^
Ive had mine for about 30k no issues. get rid of the junk gasket they give you and reuse the stock one.
The DP came up a little short on my genpu but thats nothing longer bolts cant fix.
if you have a genpu, please cut the secondary bung down to half size and/or drill a new hole with a shorter bung. the secondary NEEDS to be close to exhaust stream otherwise youll run rich as fuck AFR's and throw two codes.
I think its the best bang for your buck. Hell, I think it sounds pretty damn good with jsut this DP and the stock catback.
PURPLE DRANK TUNED
 Old 05-11-2016, 08:57 AM   #389
Khang88's Avatar
Thanks guys. Im really considering an ebay dp. Everything else is just too pricey.
 Old 05-11-2016, 09:19 AM   #390
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
I don't think the MS6 DP has the extended rear o2 bung on it. If it does, have a shop weld a standard in before you install it.
Rich Tuned
330WHP and 363TQ
 Old 05-11-2016, 09:37 AM   #391
Gitcherex's Avatar
It does not, so all ya gotta do is make sure you dont fuck up the O2 sensors while taking em out, and you are golden
 Old 05-13-2016, 02:18 PM   #392
Nel Mazdaspeed's Avatar
Posts: 407   (View Stats)
ive had my M2 downpipe for 2 years, absolutely no problems..
Sent from my SAMSUNG-SM-N910A using Tapatalk
The Following User Says Thank You to Nel Mazdaspeed For This Useful Post:
Khang88 (05-13-2016)
 Old 05-13-2016, 02:44 PM   #393
Khang88's Avatar
Cool. How's the power gains on the m2?
 Old 05-13-2016, 03:02 PM   #394
i honestly dont have a diff DP to make comparisons, but according to my tuner they are similar if not the same in gains. the only diff is the quality and workmanship and price.. imo
 Old 05-31-2016, 08:53 PM   #395
Lambo0311's Avatar
Posts: 1   (View Stats)
Lambo0311 has a little shameless behaviour in the past
If anyone can give me opinions on which exhaust is best for the MS3 I'd greatly appreciate it. I just bought my 2012 speed 3 about a month ago.
Lambo0311 is offline   Reply With Quote
The Following User Says NO Thank You to Lambo0311 For This Un-useful Post:
robbspeed (05-31-2016)
 Old 05-31-2016, 09:02 PM   #396
robbspeed's Avatar
Groans: 50
Read your welcome PM. Make an introduction thread and here you go. Definitive Exhaust Thread
Totaled/ R.I.P.
 Old 06-27-2016, 10:52 PM   #397
IT GUY's Avatar
Posts: 141   (View Stats)
IT GUY has a brilliant futureIT GUY has a brilliant futureIT GUY has a brilliant futureIT GUY has a brilliant futureIT GUY has a brilliant futureIT GUY has a brilliant futureIT GUY has a brilliant futureIT GUY has a brilliant futureIT GUY has a brilliant futureIT GUY has a brilliant futureIT GUY has a brilliant future
So I don't post often on here. Hell I haven't even been searching forums much lately. But I just got my CNT 3" catless downpipe in and installed. It was on back order and I waited for months to get it in. I figured for the price and what I have heard and read I couldn't go wrong. In the end I think I'm in love with the feel and sounds. However I cannot recommend this downpipe because of a major issue I had with their product. If you look at the pictures of the downpipe you will see it looks like a decent piece, until you look at the last few pictures when i went to go and install it. The holes on the bellmouth to mount on the turbo no only are a bitch to get to the studs, but they did not line up correctly and had to be filed out larger in order to make the bolts line up correctly. If I was not in the right place doing this it would have been a long day of hell just to go back to stock. Luckily we were able to file the holes larger and put this thing up and down on the lift repeatedly until the holes lined up correctly again.
Now it is time to play with tune and i will try to keep you guys updated on that somewhere else on the forums.
Then next on list is to cut out the 2.5 inch flange on the Magnaflow 15557 exhaust and put on a flat 3 inch flange to match this downpipe (just threw on a flat gasket for now knowing its getting done soon.
2012 Gen2 Velocity Red Mica
Cobb: AP, RMM, SF Intake and Inlet Hose; AT Internals; CNT Catless 3" downpipe; Magnaflow CBE 1557
IT GUY is offline   Reply With Quote
The Following User Says Thank You to IT GUY For This Useful Post:
robbspeed (07-02-2016)
 Old 12-04-2016, 04:53 PM   #398
eliwwjd's Avatar
Posts: 518   (View Stats)
eliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond repute
I know this thread is old but im getting ready to purchase a catted downpipe but im still debating on whether to get divorce or bellmouth due to many different opinions. Justin recommended me corksport or cobb. One is divorce and one is bellmouth. I was reading on other subaru forums that divorce was the way to go, having separate tubes avoiding turbulence, boost spikes and the same time exhaust flow is smoother, giving the car the chance to produce hp and tq efficiently. Others think that bellmouth is the way to go when you have high boost applications and that this model is best suited for the mazdaspeed 3. Normally drag race cars have separate tubes, the wastegate comes out the side of the car or the bottom while the turbo tube out the hood in some cases(divorce way)
With what model do you guys recommend I should go? Ive been inclined towards the divorce but you guys tell me what is your thought
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
eliwwjd is offline   Reply With Quote
 Old 12-16-2016, 03:55 PM   #399
IT GUY's Avatar
I don't have any professional or mathematical advice on this matter. All I can say is mine has treated me great since it's been in. Surprising amount of power being pushed out of my stock ko4.
Sent from my SAMSUNG-SM-G930A using Tapatalk
 Old 12-17-2016, 08:04 AM   #400
Dennisms3's Avatar
Posts: 198   (View Stats)
Dennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant future
Drag racing cars have external wastegates thats why they have a downpipe and and dump pipe for the wastegate. Outr k04 is internally wastegated, so just get a bellmouth and be done with it. Thats what the majority of the people here including me have and no issues.
Dennisms3 is offline   Reply With Quote
The Following User Says Thank You to Dennisms3 For This Useful Post:
robbspeed (12-18-2016)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/official-downpipe-test-pipe-race-pipe-thread-99627/
catless downpipes cause turbo to blow seals?? - Page 4 This thread Pingback 11-10-2014 11:55 AM
Tuner/garage in Brampton/Mississauga area This thread Refback 08-02-2014 08:51 AM
Downpipe options - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Pingback 07-22-2014 10:53 AM
?????????? ?? ??????? 6 mps This thread Refback 02-15-2014 02:51 PM
Aide pour choisir downpipe - Mazda 3 Quebec This thread Refback 08-06-2013 07:10 AM
Mazdaspeed stage 2 downpipe vs racepipe This thread Refback 06-19-2013 09:31 AM
Cat'd DP? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 04-21-2012 07:39 PM
I HATE heat shielding. MPS 6 Post #6 Pingback 12-23-2011 02:44 PM
Which Race Pipe/Test Pipe is the best for a Mazdaspeed 6? ItalianSA MazdaSpeed 6 - Engine, Transmission & Driveline 6 04-20-2009 12:14 PM
Page generated in 0.59521 seconds with 35 queries
