Like Tree40Likes
 Old 05-05-2012, 01:35 AM   #81
Spectrum24x's Avatar
Posts: 276   (View Stats)
Spectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond repute
Sorry for the noob question but is the cat in the downpipe the only cat on the car? If its not the only cat is it possible to pass emissions with a Catless dp?
2007 TRUE RED MS3 GT
RX-8 WHEELS/DRILLED & SLOTTED ROTORS
KONI YELLOW/COBB SPRINGS/JBR RSB/HOTCHKIS FSB
COBB OTS STAGE 2 MAP
RMM/COBB INTAKE/COBB TIH/ETS TMIC
OBX TEST PIPE/AUTOTECH INTERNALS/FORGE BPV V2
Spectrum24x is offline   Reply With Quote
 Old 05-05-2012, 01:37 AM   #82
greatdane68's Avatar
Posts: 456   (View Stats)
It's not the only cat, and no, you can't pass emissions with a catless DP.
2010 Mazda Speed3
FREEKTUNED!
2003 Chevy S-10
2014 Toyota Camry
2011 Dodge Challenger R/T
1997 Geo Prizm
 Old 05-13-2012, 01:52 PM   #83
gyoku2006@gmail.com's Avatar
Posts: 55   (View Stats)
gyoku2006@gmail.com has disabled reputation
good thread, very helpfull for when i get around to installing an exhaust system
gyoku2006@gmail.com is offline   Reply With Quote
 Old 05-14-2012, 06:42 PM   #84
VertigoM's Avatar
Posts: 27   (View Stats)
VertigoM is a glorious beacon of lightVertigoM is a glorious beacon of lightVertigoM is a glorious beacon of lightVertigoM is a glorious beacon of lightVertigoM is a glorious beacon of lightVertigoM is a glorious beacon of light
Who has the new catted CS downpipe? Does the divorced wastegate design have a significant benefit over a bellmouth design?
2010 CWP MS3
Cobb AP | Corksport SRI+TIP | Mangaflow Catback | Autotech Internals
VertigoM is offline   Reply With Quote
 Old 05-17-2012, 11:51 AM   #85
VertigoM's Avatar
Anyone?
2010 CWP MS3
 Old 07-23-2012, 05:49 PM   #86
93silvergt's Avatar
Posts: 554   (View Stats)
93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world
Groaned at 18 Times in 11 Posts
Exhaust Downpipe Mazda 07 08 09 Mazdaspeed 3 Cat-less | eBay
Does this "m2 performance" have the secondary o2 bung extended to avoid a CEL? I can't see from the pictures
2009 Mazdaspeed3 GT
Cobb SRI E4P Short Throw shifter
93silvergt is offline   Reply With Quote
 Old 08-05-2012, 03:57 PM   #87
EddyV1987's Avatar
Posts: 7   (View Stats)
EddyV1987 is an unknown quantity at this point
Hey Guys quick question,
I have a MazdaSpeed 6 that has a Corksport racepipe and CBE. I'm looking into getting a downpipe but I can not use Corksports because they are Catless. With good ol Connecticut law I can not run catless. Will these other downpipes be compatible with what I'm running now? Will it make the car sound like Crap?
EddyV1987 is offline   Reply With Quote
 Old 08-05-2012, 04:05 PM   #88
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
Just go catless and run a couple non-foulers on the second o2 sensor.
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following 4 Users Say Thank You to smoogs12 For This Useful Post:
chuckms6 (08-05-2012), EddyV1987 (08-06-2012), MS3-a(sore)ASS-rex (08-05-2012), Speed3eak (09-19-2012)
 Old 08-05-2012, 07:11 PM   #89
chuckms6's Avatar
Posts: 1,618   (View Stats)
it depends on how conneticut does emissions testing, visual, code scan, or sniffer, or all three?
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
 Old 08-05-2012, 07:20 PM   #90
smoogs12's Avatar
Groans: 423
We only do a scan in CT.
If the tech is a reaaal dick he might visual check. But most give no fucks.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 08-05-2012, 07:30 PM   #91
chuckms6's Avatar
oh. then catless and delete code in ap. if they check system readiness then go with the o2 sensor spacer.
The Following User Says Thank You to chuckms6 For This Useful Post:
smoogs12 (08-05-2012)
 Old 08-05-2012, 07:33 PM   #92
smoogs12's Avatar
Groans: 423
...if they check system readiness....
This they do. Dont go in after clearing codes or pulling power to the car. You will fail
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 08-05-2012, 07:35 PM   #93
chuckms6's Avatar
fersure lol. yea o2 spacer is the way to go.
EddyV1987 likes this.
 Old 09-19-2012, 01:29 PM   #94
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
Yes you can, And no it doesn't.
Do you have a 1/2" drill bit? Order some spark-plug non-foulers and make the extender yourself. It's really simple and works like a charm.
Does anybody make a 3" v-band upper downpipe for the MS3? I haven't been able to find one. The old style UR DP looks like it was made for a 3" v-band but knowing UR they would most likely charge extra for a non-standard option. It doesn't look like the MS3 flange -> v-band adapter would work either because I'd be working with a very limited amount of space.
The Following User Says Thank You to Speed3eak For This Useful Post:
El_Diablo (11-24-2012)
 Old 09-19-2012, 09:55 PM   #95
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
@Raider.......this isn't a sticky anymore??
______________________
Built By NATOR
Tons of Ricer Mods
 Old 09-20-2012, 05:57 AM   #96
Not sure whathappened, but it is fixed
 Old 10-01-2012, 08:21 PM   #97
William.Fraim's Avatar
Posts: 22   (View Stats)
William.Fraim is a splendid one to beholdWilliam.Fraim is a splendid one to beholdWilliam.Fraim is a splendid one to beholdWilliam.Fraim is a splendid one to beholdWilliam.Fraim is a splendid one to beholdWilliam.Fraim is a splendid one to beholdWilliam.Fraim is a splendid one to behold
Sorry for the noob question. I want to replace my stock dp. If i replace the fuel pump internals would i be fine? Or do i still need to raise the RPM's with an AP? Only reason I ask is that if i need the AP im scrapping the dp idea for now cuz I'm on a low budget right now.
William.Fraim is offline   Reply With Quote
 Old 10-01-2012, 08:39 PM   #98
jeopardy98's Avatar
Posts: 1,920   (View Stats)
jeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the world
1. rmm
2. ap
3. fp
4. sri
5. dp
4 and 5 can be switched but I wouldn't run a dp without an ap to monitor.
Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed.
jeopardy98 is offline   Reply With Quote
 Old 10-01-2012, 09:15 PM   #99
OK thanks for the help. Just one more question. What are rmm and sri?
 Old 10-01-2012, 09:25 PM   #100
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Rear motor mount, Short Ram Intake
Because you have donate mod.
The Following 5 Users Say Thank You to Dmurray06 For This Useful Post:
Dimenus (12-10-2012), jeopardy98 (10-02-2012), Juyoung (03-11-2013), kylec_2003 (10-03-2012), SLOWHATCH (11-19-2012)
 Old 10-01-2012, 09:35 PM   #101
Ok and thanks again for the help.
The Following User Says Thank You to William.Fraim For This Useful Post:
Dmurray06 (10-01-2012)
 Old 10-19-2012, 07:04 PM   #102
agentgordon27's Avatar
Posts: 560   (View Stats)
I noticed the mention to smoking due to 3" DP, does that include both catted/catless? Will having a high flow cat help with the back pressure issue or no difference?
 Old 10-20-2012, 01:08 PM   #103
tdjach's Avatar
tdjach will become famous soon enough
great thread
tdjach is offline   Reply With Quote
 Old 11-18-2012, 10:25 AM   #104
IzSo_MS3's Avatar
IzSo_MS3 will become famous soon enoughIzSo_MS3 will become famous soon enough
Groaned at 6 Times in 3 Posts
Anyone running a full race DP
*edit: I'm a ginormous cocksucker who doesn't read, research, or pay attention. Please flame me, it makes my peepee come out from it's reverse status.
IzSo_MS3 is offline   Reply With Quote
The Following User Says NO Thank You to IzSo_MS3 For This Un-useful Post:
Chimmike (11-19-2012)
 Old 11-18-2012, 10:39 AM   #105
Dmurray06's Avatar
A downpipe is a downpipe. Full race is just expensive as shit...they all do the same thing.
The Following 2 Users Say Thank You to Dmurray06 For This Useful Post:
Chimmike (11-19-2012), chuckms6 (11-18-2012)
 Old 11-18-2012, 03:10 PM   #106
GODspeed7's Avatar
Posts: 3,456   (View Stats)
Weren't you just told that a downpipe is a downpipe? How many threads are you going to post in or create while asking the same question and getting the same answer? @chimmike;
Tapatalk LIKE A BOSS!
2012 Mazdaspeed3 Black Mica
The Following 2 Users Say Thank You to GODspeed7 For This Useful Post:
Chimmike (11-19-2012), Dmurray06 (11-18-2012)
 Old 11-18-2012, 03:14 PM   #107
IzSo_MS3's Avatar
I was just asking if anyone was running a full race that's it sorry if I pissed anyone off but dam
 Old 11-18-2012, 04:13 PM   #108
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Far as I know a few people run the FRDP. If you want to go that route then do. Many, myself included don't see any sense in paying so much more for the name, but lots of people want the name as much as the product.
Sometimes it just for the name, sometimes for the support or customer service. In the case of down pipes, I can get 3 or 4 m2's for the same cost, and the quality is comparable enough that I'm satisfied.
As for performance, a dp is a dp is a dp...
340hp / 371tq
Dmurray06 (11-18-2012), IzSo_MS3 (11-18-2012)
 Old 11-18-2012, 04:19 PM   #109
jeopardy98's Avatar
*damn
The Following 3 Users Say Thank You to jeopardy98 For This Useful Post:
Dmurray06 (11-18-2012), johnredding (11-19-2012), Speed3eak (11-18-2012)
 Old 11-18-2012, 05:14 PM   #110
Speed3eak's Avatar
Groans: 82
For catless, yeah - but IDK about the catted downpipes. For example, I have a CNT and the catalytic converter looks like a few sheets of crimped metal in concentric circles. I'm not so sure that it so much converts catalytics as it just cools down the exhaust flow. It isn't even very good at that - I got the same PID people get from running catless. Backed out the o2 sensor with a single spark plug defouler (two defoulers set of the "cat is clogged" PID) and everything was a-ok.
I don't mind as the reason I got the cat in the first place was to prevent boost spikes. I'm more than happy with it, largely because of the price - $300 shipped. The cast bell-mouth housing is awesome, welds are solid, etc. etc.
I know that UR has two different catalytic converter options. I don't know if there's a huge difference between the two unless you're running like 500 whp or something, and even then you'd just leave the cat out.
I've been running 17:1 AFRs at cruise/low loads and after 5k all seems well. Latest vDynos show 280whp and 320 lb-ft which is about right for 17 psi and 11* of timing @ RL. I'm not running any meth and my car is knock-happy so my timing curve is probably about 2* less than anyone else you're going to see here. If it goes bad or w/e I'll either pull off the pipe and knock it out or have a shop cut it out and weld in a straight pipe. Probably the former as I'm a pretty cheap bastard.
 Old 11-19-2012, 06:21 AM   #111
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Neutral  -1 score
what the FUCK does it matter ?
PLEASE, spend that much money on a downpipe. I beg of you. While I'm sitting here around 450whp with an ebay downpipe. PLEASE, buy the full race downpipe.
fuckin assclown.
07 MS3
The original Genpoo Hater
 Old 11-19-2012, 06:50 AM   #112
IzSo_MS3's Avatar
I didn't say I was buying one but I do have the resources to buy one and much more an I won't break my bank account doing so I just set my finances up my hole life to do stuff like that you just got to work at it an besides the point I'm going with ATP Long DP what the fucking fuck
 Old 11-19-2012, 09:34 AM   #113
jeopardy98's Avatar
Neutral  +1 score
*whole
The Following 2 Users Say Thank You to jeopardy98 For This Useful Post:
Dmurray06 (11-19-2012), Speed3eak (11-19-2012)
 Old 11-19-2012, 01:55 PM   #114
chuckms6's Avatar
Originally Posted by jeopardy98 View Post
*whole
There were much more than that lol
Tapatalking
The Following 2 Users Say Thank You to chuckms6 For This Useful Post:
Dmurray06 (11-19-2012), jeopardy98 (11-19-2012)
 Old 11-19-2012, 02:05 PM   #115
I made one out of dryer vent piping and a pie tin and found it clears the P2187 CEL. Awesome.
Mfinlay04 likes this.
chuckms6 (11-19-2012), Dmurray06 (11-19-2012), Mfinlay04 (04-22-2013)
 Old 11-19-2012, 02:42 PM   #116
jeopardy98's Avatar
You did use the v-band clamp to secure it to the turbo housing, right?
 Old 11-19-2012, 02:50 PM   #117
IzSo_MS3's Avatar
Going MacGruber on that shit lol!!
 Old 11-19-2012, 02:59 PM   #118
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Banned from the thread for being an annoying cocksucker. Crap up someone else's thread.
NATOR PA
 Old 11-19-2012, 06:57 PM   #119
GODspeed7's Avatar
Neutral  +1 score
 Old 12-09-2012, 01:57 PM   #120
JLM027's Avatar
Posts: 6   (View Stats)
JLM027 is infamous around these partsJLM027 is infamous around these partsJLM027 is infamous around these parts
Groaned at 42 Times in 5 Posts
Awesome Post. I just installed a downpipe to my ms3. Would you happen to know if I need to change the map in the AP from stage 1 to stage 2?
JLM027 is offline   Reply With Quote
The Following User Says NO Thank You to JLM027 For This Un-useful Post:
jeopardy98 (12-09-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/official-downpipe-test-pipe-race-pipe-thread-99627/
catless downpipes cause turbo to blow seals?? - Page 4 This thread Pingback 11-10-2014 11:55 AM
Tuner/garage in Brampton/Mississauga area This thread Refback 08-02-2014 08:51 AM
Downpipe options - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Pingback 07-22-2014 10:53 AM
?????????? ?? ??????? 6 mps This thread Refback 02-15-2014 02:51 PM
Aide pour choisir downpipe - Mazda 3 Quebec This thread Refback 08-06-2013 07:10 AM
Mazdaspeed stage 2 downpipe vs racepipe This thread Refback 06-19-2013 09:31 AM
Cat'd DP? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 04-21-2012 07:39 PM
I HATE heat shielding. MPS 6 Post #6 Pingback 12-23-2011 02:44 PM
Which Race Pipe/Test Pipe is the best for a Mazdaspeed 6? ItalianSA MazdaSpeed 6 - Engine, Transmission & Driveline 6 04-20-2009 12:14 PM
Page generated in 0.56002 seconds with 42 queries
