| LinkBack | Thread Tools | Search this Thread | Display Modes |
05-05-2012, 01:35 AM | #81 |
Rep Power: 0 Thanks: 10
| Not Ranked : 0 score
__________________ 2007 TRUE RED MS3 GT RX-8 WHEELS/DRILLED & SLOTTED ROTORS KONI YELLOW/COBB SPRINGS/JBR RSB/HOTCHKIS FSB COBB OTS STAGE 2 MAP RMM/COBB INTAKE/COBB TIH/ETS TMIC OBX TEST PIPE/AUTOTECH INTERNALS/FORGE BPV V2 |
05-05-2012, 01:37 AM | #82 |
Rep Power: 0 Thanks: 689
| Not Ranked : 0 score It's not the only cat, and no, you can't pass emissions with a catless DP.
__________________ 2010 Mazda Speed3 Autotech HPFP internals, Cobb AP V3, Corksport Springs, Skid Plate, TIP, TMIC, SRI, JBR 88 duro dogbone, RSB, Shifter bushings, Shift knob, 80 Duro TMM and PMM, OCC, Silicone Bypass Hose and Boost Tubes, Ulimate Racing axle back, Catless RP, Catted DP, Forge Motorsports V2 BOV, 6000k DDM low beams and fogs, iRotors cross drilled and slotted rotors, Akebono Ceramic pads, Tanabe Front Strut Tower Bar, Ruff Racing 355 wheels, 18x8, +40, 235/40-18 tires FREEKTUNED! 2003 Chevy S-10 2014 Toyota Camry 2011 Dodge Challenger R/T 1997 Geo Prizm |
05-13-2012, 01:52 PM | #83 |
Rep Power: 100 Thanks: 0
| Not Ranked : 0 score good thread, very helpfull for when i get around to installing an exhaust system |
05-14-2012, 06:42 PM | #84 |
Rep Power: 0 Thanks: 13
| Not Ranked : 0 score Who has the new catted CS downpipe? Does the divorced wastegate design have a significant benefit over a bellmouth design?
__________________ 2010 CWP MS3 Cobb AP | Corksport SRI+TIP | Mangaflow Catback | Autotech Internals |
05-17-2012, 11:51 AM | #85 |
| Not Ranked : 0 score Anyone?
07-23-2012, 05:49 PM | #86 |
Rep Power: 0 Thanks: 58
Groaned at 18 Times in 11 Posts
| Not Ranked : 0 score Exhaust Downpipe Mazda 07 08 09 Mazdaspeed 3 Cat-less | eBay Does this "m2 performance" have the secondary o2 bung extended to avoid a CEL? I can't see from the pictures
__________________ 2009 Mazdaspeed3 GT Cobb SRI E4P Short Throw shifter |
08-05-2012, 03:57 PM | #87 |
Rep Power: 0 Thanks: 9
| Not Ranked : 0 score Hey Guys quick question, I have a MazdaSpeed 6 that has a Corksport racepipe and CBE. I'm looking into getting a downpipe but I can not use Corksports because they are Catless. With good ol Connecticut law I can not run catless. Will these other downpipes be compatible with what I'm running now? Will it make the car sound like Crap? |
08-05-2012, 04:05 PM | #88 |
Rep Power: 0 Thanks: 11,169
Groans: 423
Tapa
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts | |
The Following 4 Users Say Thank You to smoogs12 For This Useful Post: | chuckms6 (08-05-2012), EddyV1987 (08-06-2012), MS3-a(sore)ASS-rex (08-05-2012), Speed3eak (09-19-2012) |
08-05-2012, 07:11 PM | #89 |
Rep Power: 0 Thanks: 2,125
| Not Ranked : 0 score it depends on how conneticut does emissions testing, visual, code scan, or sniffer, or all three?
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) |
08-05-2012, 07:20 PM | #90 |
Groans: 423
If the tech is a reaaal dick he might visual check. But most give no fucks.
08-05-2012, 07:30 PM | #91 |
| Not Ranked : 0 score oh. then catless and delete code in ap. if they check system readiness then go with the o2 sensor spacer.
The Following User Says Thank You to chuckms6 For This Useful Post: | smoogs12 (08-05-2012) |
08-05-2012, 07:33 PM | #92 |
Groans: 423
08-05-2012, 07:35 PM | #93 |
| Not Ranked : 0 score fersure lol. yea o2 spacer is the way to go.
09-19-2012, 01:29 PM | #94 |
Rep Power: 0 Thanks: 3,452
Groans: 82
Do you have a 1/2" drill bit? Order some spark-plug non-foulers and make the extender yourself. It's really simple and works like a charm. Does anybody make a 3" v-band upper downpipe for the MS3? I haven't been able to find one. The old style UR DP looks like it was made for a 3" v-band but knowing UR they would most likely charge extra for a non-standard option. It doesn't look like the MS3 flange -> v-band adapter would work either because I'd be working with a very limited amount of space. | |
The Following User Says Thank You to Speed3eak For This Useful Post: | El_Diablo (11-24-2012) |
09-19-2012, 09:55 PM | #95 |
Robust Mongoloid Join Date: Aug 2009 Location: South Charlotte, NC
Rep Power: 6481 Thanks: 9,137
Groans: 399
| @Raider.......this isn't a sticky anymore??
__________________ ______________________ Built By NATOR Tons of Ricer Mods
09-20-2012, 05:57 AM | #96 |
6 mods and some Kool-Aid Join Date: Mar 2008 Location: Jax, FL
Rep Power: 28977 Thanks: 20,271
| Not Ranked : 0 score Not sure whathappened, but it is fixed |
10-01-2012, 08:21 PM | #97 |
| Not Ranked : 0 score Sorry for the noob question. I want to replace my stock dp. If i replace the fuel pump internals would i be fine? Or do i still need to raise the RPM's with an AP? Only reason I ask is that if i need the AP im scrapping the dp idea for now cuz I'm on a low budget right now. |
10-01-2012, 08:39 PM | #98 |
Rep Power: 0 Thanks: 6,068
| Not Ranked : 0 score 1. rmm 2. ap 3. fp 4. sri 5. dp 4 and 5 can be switched but I wouldn't run a dp without an ap to monitor.
__________________ Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed. [SIGPIC][/SIGPIC] |
10-01-2012, 09:15 PM | #99 |
| Not Ranked : 0 score OK thanks for the help. Just one more question. What are rmm and sri? |
10-01-2012, 09:25 PM | #100 |
Rep Power: 0 Thanks: 4,855
| Not Ranked : 0 score Rear motor mount, Short Ram Intake Because you have donate mod.
__________________ 2010 Mazdaspeed 3 Black Mica w/ Tech Package - Traded In 2014 Ford F150 FX4 Ecoboost - Current |
The Following 5 Users Say Thank You to Dmurray06 For This Useful Post: | Dimenus (12-10-2012), jeopardy98 (10-02-2012), Juyoung (03-11-2013), kylec_2003 (10-03-2012), SLOWHATCH (11-19-2012) |
10-01-2012, 09:35 PM | #101 |
| Not Ranked : 0 score Ok and thanks again for the help. |
The Following User Says Thank You to William.Fraim For This Useful Post: | Dmurray06 (10-01-2012) |
10-19-2012, 07:04 PM | #102 |
Rep Power: 0 Thanks: 1,541
| Not Ranked : 0 score I noticed the mention to smoking due to 3" DP, does that include both catted/catless? Will having a high flow cat help with the back pressure issue or no difference? |
10-20-2012, 01:08 PM | #103 |
Rep Power: 0 Thanks: 0
| Not Ranked : 0 score great thread |
11-18-2012, 10:25 AM | #104 |
Rep Power: 0 Thanks: 16
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score Anyone running a full race DP *edit: I'm a ginormous cocksucker who doesn't read, research, or pay attention. Please flame me, it makes my peepee come out from it's reverse status. Last edited by Chimmike; 11-19-2012 at 06:20 AM. |
The Following User Says NO Thank You to IzSo_MS3 For This Un-useful Post: | Chimmike (11-19-2012) |
11-18-2012, 10:39 AM | #105 |
| Not Ranked : 0 score A downpipe is a downpipe. Full race is just expensive as shit...they all do the same thing.
11-18-2012, 03:10 PM | #106 |
Rep Power: 0 Thanks: 545
| Not Ranked : 0 score Weren't you just told that a downpipe is a downpipe? How many threads are you going to post in or create while asking the same question and getting the same answer? @chimmike; Tapatalk LIKE A BOSS!
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. |
11-18-2012, 03:14 PM | #107 |
| Not Ranked : 0 score I was just asking if anyone was running a full race that's it sorry if I pissed anyone off but dam |
11-18-2012, 04:13 PM | #108 |
Rep Power: 3058 Thanks: 4,683
| Not Ranked : 0 score Far as I know a few people run the FRDP. If you want to go that route then do. Many, myself included don't see any sense in paying so much more for the name, but lots of people want the name as much as the product. Sometimes it just for the name, sometimes for the support or customer service. In the case of down pipes, I can get 3 or 4 m2's for the same cost, and the quality is comparable enough that I'm satisfied. As for performance, a dp is a dp is a dp...
11-18-2012, 04:19 PM | #109 |
| Not Ranked : 0 score *damn
The Following 3 Users Say Thank You to jeopardy98 For This Useful Post: |
11-18-2012, 05:14 PM | #110 |
Groans: 82
| Not Ranked : 0 score For catless, yeah - but IDK about the catted downpipes. For example, I have a CNT and the catalytic converter looks like a few sheets of crimped metal in concentric circles. I'm not so sure that it so much converts catalytics as it just cools down the exhaust flow. It isn't even very good at that - I got the same PID people get from running catless. Backed out the o2 sensor with a single spark plug defouler (two defoulers set of the "cat is clogged" PID) and everything was a-ok. I don't mind as the reason I got the cat in the first place was to prevent boost spikes. I'm more than happy with it, largely because of the price - $300 shipped. The cast bell-mouth housing is awesome, welds are solid, etc. etc. I know that UR has two different catalytic converter options. I don't know if there's a huge difference between the two unless you're running like 500 whp or something, and even then you'd just leave the cat out. I've been running 17:1 AFRs at cruise/low loads and after 5k all seems well. Latest vDynos show 280whp and 320 lb-ft which is about right for 17 psi and 11* of timing @ RL. I'm not running any meth and my car is knock-happy so my timing curve is probably about 2* less than anyone else you're going to see here. If it goes bad or w/e I'll either pull off the pipe and knock it out or have a shop cut it out and weld in a straight pipe. Probably the former as I'm a pretty cheap bastard. |
11-19-2012, 06:21 AM | #111 |
Will fuck up ur day Join Date: Feb 2010 Location: Parrish, FL
Rep Power: 4200 Thanks: 5,803
Groans: 433
| Neutral : -1 score
PLEASE, spend that much money on a downpipe. I beg of you. While I'm sitting here around 450whp with an ebay downpipe. PLEASE, buy the full race downpipe. fuckin assclown.
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. | |
11-19-2012, 06:50 AM | #112 |
| Not Ranked : 0 score I didn't say I was buying one but I do have the resources to buy one and much more an I won't break my bank account doing so I just set my finances up my hole life to do stuff like that you just got to work at it an besides the point I'm going with ATP Long DP what the fucking fuck |
11-19-2012, 09:34 AM | #113 |
| Neutral : +1 score *whole
11-19-2012, 01:55 PM | #114 |
The Following 2 Users Say Thank You to chuckms6 For This Useful Post: | Dmurray06 (11-19-2012), jeopardy98 (11-19-2012) |
11-19-2012, 02:05 PM | #115 |
| Not Ranked : 0 score I made one out of dryer vent piping and a pie tin and found it clears the P2187 CEL. Awesome. |
11-19-2012, 02:42 PM | #116 |
| Not Ranked : 0 score You did use the v-band clamp to secure it to the turbo housing, right?
11-19-2012, 02:50 PM | #117 |
| Not Ranked : 0 score Going MacGruber on that shit lol!! |
11-19-2012, 02:59 PM | #118 |
Rep Power: 7488 Thanks: 18,940
Groans: 224
(Thread Starter) | Not Ranked : 0 score Banned from the thread for being an annoying cocksucker. Crap up someone else's thread.
11-19-2012, 06:57 PM | #119 |
| Neutral : +1 score Tapatalk LIKE A BOSS!
12-09-2012, 01:57 PM | #120 |
Groaned at 42 Times in 5 Posts
| Not Ranked : 0 score Awesome Post. I just installed a downpipe to my ms3. Would you happen to know if I need to change the map in the AP from stage 1 to stage 2? |
The Following User Says NO Thank You to JLM027 For This Un-useful Post: | jeopardy98 (12-09-2012) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/official-downpipe-test-pipe-race-pipe-thread-99627/ | ||||
Posted By | For | Type | Date | |
catless downpipes cause turbo to blow seals?? - Page 4 | This thread | Pingback | 11-10-2014 11:55 AM | |
Tuner/garage in Brampton/Mississauga area | This thread | Refback | 08-02-2014 08:51 AM | |
Downpipe options - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums | This thread | Pingback | 07-22-2014 10:53 AM | |
?????????? ?? ??????? 6 mps | This thread | Refback | 02-15-2014 02:51 PM | |
Aide pour choisir downpipe - Mazda 3 Quebec | This thread | Refback | 08-06-2013 07:10 AM | |
Mazdaspeed stage 2 downpipe vs racepipe | This thread | Refback | 06-19-2013 09:31 AM | |
Cat'd DP? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Refback | 04-21-2012 07:39 PM | |
I HATE heat shielding. MPS 6 | Post #6 | Pingback | 12-23-2011 02:44 PM |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Which Race Pipe/Test Pipe is the best for a Mazdaspeed 6? | ItalianSA | MazdaSpeed 6 - Engine, Transmission & Driveline | 6 | 04-20-2009 12:14 PM |
