Like Tree40Likes
 Old 06-05-2015, 09:17 AM   #321
Rommel043's Avatar
Posts: 27   (View Stats)
Rommel043 is just really niceRommel043 is just really niceRommel043 is just really niceRommel043 is just really niceRommel043 is just really nice
my question is, will any 3" long downpipe mate right up to the stock catback exhaust or will i have to get a donut adapter?
Thanks fellas
Rommel043 is offline   Reply With Quote
 Old 06-05-2015, 04:52 PM   #322
aromig's Avatar
Posts: 289   (View Stats)
Thanks fellas
If the catback side flange tapers to 65mm, you're good. If it stays 80mm/3inch all the way, it won't work unless you can rig it somehow. Personally recommend against that though.
 Old 07-02-2015, 10:36 AM   #323
GregScuba's Avatar
Posts: 96   (View Stats)
GregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the worldGregScuba is the leader of the world
Not sure if this has already been mentioned, but I just stumbled upon this, and thought I'd throw it in the mix. Apparently Magnaflow makes a DP. No idea how it performs though.
Magnaflow/Catalytic Converter 51545 at AutoZone.com
nomorecivic! likes this.
2010 Liquid Silver Mazdaspeed 3
Cobb AP v3, tuning by Stratified Automotive Controls, Autotech HPFP internals, one step colder NGK Iridium plugs, Cobb DP, Magnaflow 3" CBE, Corksport SRI/TIP, Corksport Race RMM 80A, Synapse Synchronic DV in push mode A+B, Treadstone TR6 FMIC, JBR FMIC piping kit, JBR Silicone recirc hose, JBR rear sway bar, Bilstein B14 coilovers, SPC adjustable rear camber arms, Stoptech SS brake lines and brake pads, 17x9" et+45mm Enkei Racing RPF1's, 245/40/17 Hankook RS3's, JBR 5mm hub/wheel spacers in front.
GregScuba is offline   Reply With Quote
The Following 3 Users Say Thank You to GregScuba For This Useful Post:
Gitcherex (12-03-2015), Koke382 (07-02-2015), littleloogy (07-02-2015)
 Old 07-03-2015, 06:59 AM   #324
Inquisitive's Avatar
Posts: 220   (View Stats)
Several members have the Magnaflow CBE, but I haven't seen the Magnaflow DP before. Thanks for sharing this.
Not for sale in the state of California - lol
Do you happen to know what it fits (MS6, MS3 Gen1 and / or Gen2)? It just says Mazda(10) when I push "Vehicle Fitment".
Also, can you see a price? It might be picking up my foreign address or that I do not have a logon.
Inquisitive is offline   Reply With Quote
The Following User Says Thank You to Inquisitive For This Useful Post:
GregScuba (07-08-2015)
 Old 07-06-2015, 11:56 PM   #325
GregScuba's Avatar
Price I see is $490. Fitment is for gen1 or gen2 Mazdaspeed3.
The Following User Says Thank You to GregScuba For This Useful Post:
Inquisitive (07-07-2015)
 Old 08-13-2015, 08:12 AM   #326
Gorky_Park's Avatar
Posts: 45   (View Stats)
Gorky_Park is a jewel in the roughGorky_Park is a jewel in the roughGorky_Park is a jewel in the rough
I have a test pipe already, so wanted a catless short DP.
I can't seem to find M2 brand on eBay anymore, should I go with Mazda mazdaspeed 3 MS3 2 3L Turbo I4 O2 Bungs Exhaust 3 inch Downpipe with Flex | eBay or J2 Racing Turbo Downpipe Down Pipe Exhaust 07 09 Mazda 3 MAZDASPEED3 Disi MZR | eBay ? One is $90 another is $120.
I plan on getting HPFP internals, and AP with Freektune OTS+ 93 map
Thanks
2009 MS3 GT
Damond RMM/PMM, AP V3, Cobb SRI and TIP, AT HPFP, Forge V1 BPV, E30 tuned by Purple Drank
Gorky_Park is offline   Reply With Quote
 Old 08-13-2015, 09:34 AM   #327
Thanks
Most of the e-bay downpipes are the same thing, just re-branded.
Gorky_Park (08-13-2015)
 Old 08-18-2015, 09:11 AM   #328
elementality199's Avatar
Posts: 13   (View Stats)
elementality199 has a little shameless behaviour in the past
what size are the non foulers? i went to auto zone and had like 5 different sizes, going to go full catless and want to buy these to install with it.
elementality199 is offline   Reply With Quote
 Old 08-28-2015, 02:48 PM   #329
dutchbuffalo's Avatar
Posts: 25   (View Stats)
dutchbuffalo has a spectacular aura aboutdutchbuffalo has a spectacular aura about
I bought the ebay testpipe for my MS6 and it doesn't line up right, both ends are straight up and down and one should be angled. Anyone else have this problem and came up with a solution ?
http://www.motorxp.info/gqmotor/img/TP-3016-5.JPG ebay testpipe
http://corksport.com/images/thumbnai...g?t=1439599012 Corksport testpipe
2007 Mazdaspeed 6 -Cobb SRI - Forge BPV - Custom Test Pipe
dutchbuffalo is offline   Reply With Quote
 Old 10-25-2015, 10:41 AM   #330
fd97's Avatar
Posts: 6   (View Stats)
fd97 has a little shameless behaviour in the past
So im running an ebay downpipe with a built in spacer. Because of the spacer i'm getting a lean code because apparently in MS3's both o2 sensors measure afr. I'm looking to get a tune soon and i'm wondering if this can have negative effects.
fd97 is offline   Reply With Quote
 Old 10-25-2015, 10:42 AM   #331
littleloogy's Avatar
Posts: 4,005   (View Stats)
Nice first post... Did you read your welcome PM?
 Old 10-25-2015, 11:00 AM   #332
fd97's Avatar
i did
 Old 10-25-2015, 11:12 AM   #333
Turbo_Steve's Avatar
Posts: 944   (View Stats)
i did
I assume you are running upgraded fuel pump internals and have a CUSTOM tune then...
If not, you will find out what happens soon enough.
Soon to come.
WHO KNOWS? A.D.D. FTW!
 Old 10-25-2015, 11:22 AM   #334
fd97's Avatar
hpfp internals yes, no tune tho. I don't think it's actually running lean, the O2 sensor spacer is causing the lean code
 Old 10-25-2015, 11:27 AM   #335
Default The Official Downpipe/Test Pipe/Race Pipe Thread
You put the spacer on the primary O2 sensor?
 Old 10-25-2015, 11:28 AM   #336
speed23's Avatar
Posts: 1,480   (View Stats)
IIRC, they dont both register afr, only the first one. You better double check that just incase.
 Old 10-25-2015, 11:34 AM   #337
fd97's Avatar
Thats what i thought too nut only people running spacers get lean codes
The spacer is built in. And that would be of no good use to have a spacer on the primary because it's before the cat and wouldn't measure efficiency
 Old 10-25-2015, 02:22 PM   #338
You are running lean because you don't have a custom tune, or because of some other issues you have with the car.
The rear narrowband o2 helps with correcting sensor drift of the primary wideband o2. over time with the rear sensor spaced out, the primary will drift rich. This will make the car run richer than what the 02 sensor is reading.
Either plug the rear bung and have a standard bung welded in, or delete the rear 02 and turn off the codes.
AND GET A TUNE BEFORE YOU BLOW UP
Soon to come.
 Old 10-25-2015, 04:54 PM   #339
fd97's Avatar
Then why does the code only appear with the spacer? When the stock dp is on no codes appear
 Old 10-25-2015, 05:07 PM   #340
fd97's Avatar
And what is O2 sensor drift?
Also, if the ecu got a rich signal from the primary O2, then wouldn't the lean code come from the injectors being maxed on stock ecu settings because it's running too rich?
Last edited by fd97; 10-25-2015 at 05:07 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-25-2015, 08:18 PM   #341
When you swap to a catless downpipe, you remove a big source of back pressure. Your engine will flow more air at the same amount of boost as before. You need to tune for this. These cars are very sensitive to removing the cats and many have blown up from not being tuned and having upgraded fuel pump internals. Swapping to catless without a tune = lean.
Get a tune....
Unless you want to buy a new motor.
I'm done
Soon to come.
The Following 2 Users Say Thank You to Turbo_Steve For This Useful Post:
CWP_MS3 (10-26-2015), littleloogy (10-26-2015)
 Old 10-26-2015, 05:26 AM   #342
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
The extended rear oxygen sensor bung should only through codes for the rear oxygen sensor. Meaning, it thinks its broken because its not reading an adequate amount of emissions.
For example, I get a P0137 and P0139, and now I have a P0140. lol
P0137 - Rear 02 low voltage
P0139 - Oxygen Sensor Circuit Slow Response (Bank1, Sensor2)
P0140 - 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 11-20-2015, 06:29 PM   #343
Gitcherex's Avatar
Posts: 103   (View Stats)
Gitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud ofGitcherex has much to be proud of
I just purchased my 06 MS6 about a month ago, it came with magaflow cbe. I was changing the oil the other day and i checked out the dp. the (midpipe?) doesnt appear to be stock (pic attached) as i dont see the cat. can anyone confirm? would this mean I only need a new downpipe (rather than dp and test pipe)?
p.s. i checked for pics of the oem exhaust system but couldnt find any, and figured this would be the best place to ask rather than make a new post about downpipes.
Gitcherex is offline   Reply With Quote
 Old 11-20-2015, 06:36 PM   #344
570msp's Avatar
Posts: 102   (View Stats)
570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold570msp is a splendid one to behold
That is indeed an aftermarket test pipe. What brand I have no idea. As far as replacing the downpipe you have one of two options. One is to get a short downpipe (Like the corksport dp) which bolts up to your current test pipe. Or if you get a long downpipe it will replace both the stock DP and test pipe you have now (Like CPe, M2, etc). If you read the OP it explains the difference between both DPs. Hope this helps.
2006 Mazdaspeed 6 rebuilt with v6 rear end
CPE TMIC || Cobb SRI + TIP || Grimmspeed 3 port EBCS || Forge BPV V1 || UR Test Pipe || CPE Single Exit Exhaust || JBR heavy shift knob and shifter bushings || JBR RMM || SU short throw || Corksport Stubby antenna || Glowshift boost and voltage gauges || CS Mudflaps
570msp is offline   Reply With Quote
The Following User Says Thank You to 570msp For This Useful Post:
Gitcherex (11-20-2015)
 Old 11-20-2015, 06:50 PM   #345
Gitcherex's Avatar
Thanks for the quick reply! I was reading about the downpipes and test pipes for the last couple of weeks, and finally checked what I had a couple days ago. I just wanted to make sure before i spent the money on the new dp/testpipe. now it can go towards a tune lol
 Old 11-20-2015, 06:56 PM   #346
570msp's Avatar
Before you go spending money on a new DP make sure you have HPFP internals installed. Hopefully whoever had the car before you got it tuned and replaced them already. HPFP internals first, Tune second, even if it's not a full custom I'd recommend the $75 tune from Freek. He will get you to where your car is running safe so when you have the money you can get that DP and not a new engine.
 Old 11-20-2015, 07:05 PM   #347
Gitcherex's Avatar
The previous owner had told me the car had upgraded hpfp internals. While i have kept an eye on the fp during my wot pulls and havent noticed any dips, short of pulling it apart, is there another way to verify this?
 Old 11-20-2015, 07:08 PM   #348
robbspeed's Avatar
Posts: 1,074   (View Stats)
robbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the world
Groans: 50
I was looking at your vehicle info and saw hpfp internals in the description. How do you know you have them?
2011 Mazdaspeed3 w/ tech package
Totaled/ R.I.P.
robbspeed is offline   Reply With Quote
 Old 11-20-2015, 07:50 PM   #349
Gitcherex's Avatar
The guy i purchased the vehicle from had told me the hpfp internals were installed, but other than that Im not 100% sure. I have kept an eye on my fuel pressure during wot pulls, and there are no dips (highest i remember is about 1850). I have the cobb ap gauge showing me the hpfp actual pressure (among other things)
The Following User Says Thank You to Gitcherex For This Useful Post:
robbspeed (11-20-2015)
 Old 11-21-2015, 09:59 AM   #350
hollar1211's Avatar
Posts: 495   (View Stats)
hollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond repute
Do you mean lowest was 1850?
Sent from my 0PM92 using Tapatalk
2008.5 Speed3 GT
Freek Tuned e33: Cobb AP, Autotech Internals, UR Test Pipe, CPE TMIC, JBR Power Path Stage 2 SRI-TIP/ Short Shifter/ Solid Shifter Bushings/ Heavy Shift Knob/ 88 Duro RMM/ EGR Delete & Block Off Plate/ Throttle Body TIG, NGK IX 6510, 18x8 +35 Drag DR-49
hollar1211 is offline   Reply With Quote
 Old 11-21-2015, 02:19 PM   #351
Gitcherex's Avatar
the highest i recall seeing was about 1850, very likely that it was higher. Ill do a wot log and see what the highest comes out to be. Ive decided to actually pull it out and clean the hpfp (and to verify its been upgraded) once i get my jbr stage 2 sri. kill 2 birds with one stone.
 Old 11-21-2015, 02:55 PM   #352
robbspeed's Avatar
Groans: 50
That's a good idea. I would just inspect. There should be no need for cleaning unless the thing was running E. With good fuel and regular oil changes they should be in fine shape. Also, when I go wot my hpfp actual pressure spikes to the mid 1800's and then holds in the upper 1700's through out the rev range and I have a 3" catted DP with stage 2 map. So unless I'm missing some piece of info on the ms6 i'd say that's good fuel pressure for after market internals.
Totaled/ R.I.P.
 Old 11-21-2015, 04:24 PM   #353
Gitcherex's Avatar
Alright. 2 pulls later and the hpfp actual maxed out at 1849 and stayed around 1600s-1700s during each pull (3rd/4th x2). ill still pull it to be sure! and no, no E yet but im running seafoam through each tank to clean it out to do a mix in the future.
 Old 11-21-2015, 04:28 PM   #354
deasuma's Avatar
Posts: 185   (View Stats)
deasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the worlddeasuma is the leader of the world
Did it dip below 1600 at all?
Sent from my SM-N920P using Tapatalk
2010 mazdaspeed 3,CS turbo, cobb ap v3, autotech hpfp, htp 3.5" full intake, ISC N1 Coilovers, CS short shift plate, CS 70&80 durometer RMM, CS mudflaps, Stratified e30 tune, Treadstone FMIC w/ TR8 Core, CS Turbo, CS full DP w/ High flow Cat,CPE Triton CBE, Cobb ebcs, Bosch 3 bar map sensor, CS OCC, HKS SSQV IV BPV.
deasuma is offline   Reply With Quote
 Old 11-21-2015, 04:36 PM   #355
robbspeed's Avatar
Groans: 50
Upper 1600's? I don't like to put additives or cleaning agents in my vehicle so I can't comment on what effect that will have. I think one of the moderators on this forum bench tested seafoam and found it to do nothing.
deasuma likes this.
Totaled/ R.I.P.
The Following User Says Thank You to robbspeed For This Useful Post:
deasuma (11-21-2015)
 Old 11-21-2015, 04:52 PM   #356
Gitcherex's Avatar
Yeah it dipped down into the upper 1600s (didnt see anything lower) then stayed around mid 1700s. I tried to log it, but im unsure on how to access it atm lol.
i was reading up on a thread in the e85 section, he seafoamed the tank a few times and i dont think he had the black death issue
 Old 11-21-2015, 04:59 PM   #357
robbspeed's Avatar
Groans: 50
If you go into "gauges" you just hit the center button it should start logging. Then hit the center button again to stop logging. You might have to go into settings in the gauges function and select all the parameters you want logged if it isn't already set up. It may be different if you have the v2
Totaled/ R.I.P.
 Old 11-21-2015, 05:05 PM   #358
Gitcherex's Avatar
that part I did, but actually viewing the logs is where i am stuck.
I did some quick searching. GlorifiedBozo is the OP of that thread. he did use Phates inline fuel filter however as well though.
 Old 11-21-2015, 05:07 PM   #359
robbspeed's Avatar
Groans: 50
You need accessport manager and accesstuner race
I'm assuming you have them. If not, go to cobbs website and order it for free. Then they'll send you a link to download within 24 hrs
deasuma likes this.
Totaled/ R.I.P.
Gitcherex (11-21-2015)
 Old 11-21-2015, 09:08 PM   #360
Gitcherex's Avatar
Yes, ive got them, thought those were just for tuning though. Ill try and pull up the logs and see how they look.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/official-downpipe-test-pipe-race-pipe-thread-99627/
catless downpipes cause turbo to blow seals?? - Page 4 This thread Pingback 11-10-2014 11:55 AM
Tuner/garage in Brampton/Mississauga area This thread Refback 08-02-2014 08:51 AM
Downpipe options - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Pingback 07-22-2014 10:53 AM
?????????? ?? ??????? 6 mps This thread Refback 02-15-2014 02:51 PM
Aide pour choisir downpipe - Mazda 3 Quebec This thread Refback 08-06-2013 07:10 AM
Mazdaspeed stage 2 downpipe vs racepipe This thread Refback 06-19-2013 09:31 AM
Cat'd DP? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 04-21-2012 07:39 PM
I HATE heat shielding. MPS 6 Post #6 Pingback 12-23-2011 02:44 PM
Which Race Pipe/Test Pipe is the best for a Mazdaspeed 6? ItalianSA MazdaSpeed 6 - Engine, Transmission & Driveline 6 04-20-2009 12:14 PM
Page generated in 0.59678 seconds with 38 queries
