| LinkBack | Thread Tools | Search this Thread | Display Modes |
12-14-2011, 07:55 PM | #1 |
Rep Power: 7488 Thanks: 18,940
Groans: 224
(Thread Starter) | Neutral : +8 score The Official Downpipe/Test Pipe/Race Pipe Thread **** UPDATED 2/2015! Thanks @Inquisitive;! General:The downpipe on your Mazdaspeed vehicle (whether it's a gen1 MS3, gen 2 MS3 or MS6) is the first part of your exhaust coming off of the turbo. The stock or OEM downpipe on your vehicle contains one catalytic converter. Replacing your downpipe is a common upgrade that results in some very impressive power gains over your restrictive OEM unit, while giving your car a louder, more aggressive exhaust note. Warning: It has been seen that after upgrading to a 3" downpipe that some vehicles will end up with smoking turbos. This is because of the reduced back-pressure on the turbo seals, which allows some oil to pass by. There are several easy fixes to resolve this issue, the first and simplest fix is to raise the idle on your vehicle through your tuning software. Another simple fix is to swap out the stock oil feed bolt with a smaller diameter feed hole, @bnoon makes and sells these bolts. A Diagram of the OEM Exhaust: NOTE: GEN 1 AND GEN 2 DOWNPIPES & TEST/RACE PIPES CAN BE USED ON BOTH GENERATIONS Things you NEED to know: Downpipes for Mazdaspeed vehicles are manufactured in two different styles. The first style is generally referred to as just a "3inch downpipe", these units will replace your original downpipe and ONLY the original piece (these are generally coupled to a "race pipe" or "test pipe" *SEE DIAGRAM ABOVE*which removes your secondary catalytic converter). The other style is known as a "Long downpipe" or "Full downpipe", meaning the new part will replace BOTH your stock downpipe and also your stock "race/test pipe". Downpipes are generally sold with two options. They are referred to as either being cat-less or as having a high flow cat (the term cat refers to a catalytic converter). A cat-less downpipe is exactly what it sounds like, it replaces your OEM piece with a new 3" downpipe possessing NO catalytic converters. One possessing a High Flow Cat, also, is exactly what it sounds like, it replaces your stock restrictive cat for a more efficient, higher flowing unit. Generally, cat-less downpipes provide a few more peak ponies and a more aggressive exhaust notes than pieces with a high flow cat, BUT at the risk of the car receiving a CEL (Check Engine Light). Note: If a downpipe contains a high flow cat it is generally a "Long/Full downpipe". However, there are ways to help prevent this CEL by extending your rear/second o2 sensor away from the main flow of exhaust through the downpipe. Some manufacturers include these fixes with their products, while others do not. Commonly spark plug de-foulers are used. The first is left alone and the second is drilled out to 1/2", seen here: Companies also offer o2 extenders taking away the drilling work for you, seen here: Here are some how-to guides for downpipe removal: Gen 1 MS3 & Gen 2 MS3: http://www.mazdaspeedforum.org/forum/foru...-review-16310/ and Corksport also wrote a fantastic install guide here: http://support.corksport.com/instruc...-6-113-WEB.pdf REGARDLESS OF MANUFACTURE, ALL INSTALLS ARE RELATIVELY THE SAME BETWEEN 1ST & 2ND GEN MS3'S You should take care of the HPFP limitations before considering the removal of a cat or going completely cat-less. The DP is the most restrictive section of your exhaust system. The bell housing is so crimped; it is hard to imagine the waste-gate having enough room to open. It contains cat-1, which is heavy, but not as heavy as cat-2. If required for emissions control, if you do not have the software to cancel the CEL (in AP un-tick codes: P0038 and P0420 (if rear spark plug de-fouler does not work)) or if you are allowed to disable two codes only for emissions testing, you will need a fast cat with following oxygen sensor bung for the second sensor. A DP provides faster turbo response times and power gains across the rev range. The transition from decelerating to accelerating is much smoother. The engine just seems to breathe easier, probably due to the increased VE. Divorce pipes reduce the turbulence caused by the opening and closing of the waste-gate. Also, the nature of bell housing designs creates turbulence as the chamber is expanded to cater for the turbo outlet and waste-gate. Having dedicated pipes respectively allows for same size pipes and thus, a smoother flow. By joining further down, they help to speed up the extraction resulting in faster opening of the waste-gate. Descending Genpu purchased popularity order: DownPipe (DP) and Full / Long DP • UR DP • Corksport DP • CP-E DP & Long DP • Cobb DP • ATP Long DP • eBay DP • CNT Long DP • M2 Long DP • Gutted DP • Kozmic DP • Speed Daddy DP • M2 DP • TurboXS DP • Full Race DP • XForce DP • AQ Motorsports Long DP • QAS Long DP • CES Racing Long DP • Protuning Lab DP • Best Mufflers DP Test / Race / Track Pipe (cat-less) (TP / RP) • Ultimate Racing (UR) • CorkSport (CS) • OBX • CP-E • TurboXS • Street Unit (See Warning) • Sure (See Warning) • Cobb 2015 prices and availability: First Section of Pipe Post Turbo DownPipe (DP) and Full / Long DP Test / Race / Track Pipe (cat-less) (TP / RP) ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ DownPipe (DP) and Full / Long DP 3” Ultimate Racing (UR) DP Available from: 3” Ultimate Racing (UR) DP MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) cat-less Version 1 $295, cat-less Version 2 $345, Long DP Ceramic Cat $395, Long DP Metal Substrate Cat $445, extra wideband bung $25) Corksport (CS) DP MS6 DP MS6 Long DP MS3 DP MS3 Long DP Available from: MS6 CS 6 DP MS3 CS 3 DP MS6 (Yes: cat-less $349.99, +$281 for cat (long DP)), MS3 Gen1 (Yes) $299.99 + $281 for cat (long DP) with 65mm or 80mm option, MS3 Gen2 (Yes) $299.99 + $281 for cat (long DP) with 65mm or 80mm option CP-E Long DP MS6 MS3 Available from: MS6 http://cp-e.com/webstore/product/maz...kspl-downpipe/ / MS6 long catted MS3 http://cp-e.com/webstore/product/maz...kspl-downpipe/ / MS3 long catted MS6 (Yes, catted) $621.40, MS3 Gen1 (Yes, catted) $504.40, MS3 Gen2 (Yes, catted) $504.40 Cobb Long DP Available from: Mazdaspeed3 SS 3" Downpipe with High Flow Cat / Long catted MS3 Gen 1&2 MS6 (Not found), MS3 Gen1 (Yes, catted) $695, MS3 Gen2 (Yes, catted) $695 ATP DP MS6 Long DP MS3 Long DP MS3 DP Available from: MS6 Long DP MS6 ATP Long DP MS3 Long DP MS3 ATP Long DP Much less popular: ATP DP MS3 ATP DP MS6 (Yes, V-band) $439 + Mazda 5-bolt to V-band $95, MS3 Gen1 (Yes), MS3 Gen2 (Yes) cat-less, no donut, 3”, Long DP $299, DP $259 CNT Long DP MS3 cat-less MS3 catted Available from: CNT Long DP MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) 76mm cat-less $259, catted $399 M2 Long DP MS6 MS3 Available from: MS6 MS3 MS3 long cat-less MS6 (Yes, cat-less) $140, MS3 Gen1 (Yes, cat-less) $171, MS3 Gen2 (Yes, cat-less) $171 Kozmic DP Available from: MS6 Kozmic MS6 DP Kozmic MS3 DP MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) V-band for use with CP-E EM only $539.99 Speed Daddy DP MS6 MS3 Available from: Speed Daddy DP MS6 (Yes) $318.99 out-of-stock, MS3 Gen1 (Yes) $148.99, MS3 Gen2 (Not found) TurboXS DP Available from: http://turboxs.com/shop/mazda/153-ma...-downpipe.html / 3 long cat-less MS6 (Not found), MS3 Gen1 (Yes, cat-less) $299, MS3 Gen2 (Yes, cat-less) $299 Full Race DP MS3 Prostock MS3 EFR Available from: MS3 Prostock Full Race Prostock DP Full Race EFR DP MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) Prostock $748.99 V-band + $75.34 for MS3, optional $120 silver or black coating on EFR XForce Full TBE only Available from: XForce DP MS6 (Not found), MS3 Gen1 (Not found), MS3 Gen2 (Yes) Australian $1600 AQ Motorsports Long DP Available from: http://www.aqmotorsports.com/product...roducts_id=590 MS6 (Not found), MS3 Gen1 (Yes, catted) $499, MS3 Gen2 (Not found) QAS Full Exhaust System Available from: QAS Full Exhaust System (German) Translated into English QAS Full Exhaust System MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Not found) €899 + shipping from Germany CES Racing Long DP Available from: CES Racing Long DP MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) Australian $1,299 Protuning Lab MS6 DP MS3 DP MS3 Long DP Available from: http://www.protuninglab.com/j220ma6madit.html / MS6 http://www.protuninglab.com/dp-ms3-t.html / MS3 Gen 1 Long http://www.protuninglab.com/doma3tu.html / MS3 Gen 1 & 2 Short MS6 (Yes, catted) $191.99, MS3 Gen1 (Yes) $181.99, MS3 Gen2 (Yes) $173.99 ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ Test / Race / Track Pipe (cat-less) (TP / RP) A Long or Full DP includes the DP and TP / RP. The TP / RP always removes cat-2 and can be purchased with or without resonator delete for use with the OEM / stock DP or aftermarket DP. Ultimate Racing (UR) MS6 Resonated MS3 Available from: MS6 UR MS6 MS3 UR Gen1 1.44 HP, 1.74 more Torque, 3” 304 SS, TIG welded, includes donut gasket, cat-less with resonator option MS6 (Yes) $125 +$100 Resonated or +$100 Ceramic Cat or +$150 Metal Cat, MS3 Gen1 (Yes), MS3 Gen2 (Yes) $150 +$100 Resonated or +$100 Ceramic Cat or +$150 Metal Cat CorkSport Power Series Racepipe MS6 Resonated MS3 Available from: MS6 CorkSport Power Series Racepipe MS6 Resonated MS3 CorkSport Power Series Racepipe MS3 12 WHP by deleting cat-2 (80mm) MS6 (Yes) $178.99, MS3 Gen1 (Yes) $167.99 (Resonated available), MS3 Gen2 (Yes) $167.99 OBX (Amazon) MS3 Available from: MS6 OBX (Amazon) MS6 MS3 OBX (Amazon) MS3 SUS T-304, CNC machined flanges, DUAL-TIG welded MS6 (Yes) $79, MS3 Gen1 (Yes), MS3 Gen2 (Yes) $not known as out-of-stock eBay MS6 MS3 Available from: MS6 eBay MS6 MS3 eBay MS3 MS6 (Yes) $70, MS3 Gen1 (Yes), MS3 Gen2 (Yes) $85 CP-E Nexus Resonator Delete Available from: CP-E Nexus Resonator Delete MS3 MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $259.69 TurboXS Available from: TurboXS 3” T304 SS; with TurboXS CBE got 22-26 WHP, 17-30 ft-lbs MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $177.95 Street Unit (SU) WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730 3” 304 SS cat-less (weight saving) CNC machined flanges, reuses the stock donut flange system to allow for necessary movement. The removal of the 2nd cat will NOT trigger any check engine lights. The test pipe will bolt right up to both the stock and aftermarket cat-back exhaust systems. Sure Flow M3 Track Pipe WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730 removes 2nd cat, 3”, 304 SS, CNC machined flanges, TIG welded, re-uses stock donut flange for flex movements, will not trigger CEL
__________________ MS3 has been retired to daily duty Project 1G; 1991 Eagle Talon TSi. 63MM Borg Warner Powered, Corn-Fed, 2.4L Long Rod Monster Under Construction Stock Turbo-Stock Engine Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA Last edited by Raider; 03-05-2015 at 06:18 AM. Reason: cullen eats penises |
The Following 104 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post: | 08.5MS3 (01-08-2012), 09Speed3Z (12-15-2011), 12blkms3 (12-10-2012), 3dpilot (06-09-2012), 93GTS (06-21-2014), Abu Zib (12-14-2011), Addikted To Boost (11-11-2013), ak_spray (12-31-2011), andrewz17 (06-04-2014), Arnie1229 (02-05-2015), AshFromCan (04-12-2014), Awesomesauce (01-06-2012), bmfms3 (01-01-2012), calizoomzoom (11-11-2013), CaptainCode (03-20-2014), Cheapspeed (04-25-2013), Chev954 (01-26-2013), dagrimey1 (08-19-2014), DISIindahead (12-14-2011), dizzydtrain (01-06-2012), donjohnk (08-08-2013), Donut (07-15-2013), Dumyz (06-02-2012), Easter Bunny (01-27-2012), eliwwjd (12-04-2016), Elusivellama (01-22-2012), El_Diablo (11-24-2012), Fail_6 (01-31-2012), FightaX (07-21-2013), fishin53 (01-30-2012), fooqr (01-27-2012), galens47 (04-18-2013), Hobo (02-12-2012), ItsNox (07-31-2013), Jake5713 (12-15-2011), jkowalski (05-13-2012), jksstar (04-04-2015), jracer (01-06-2012), Juyoung (09-02-2012), J_Logik (12-15-2011), KayWhy (08-08-2013), King_Sp33d (01-25-2014), Koke382 (12-20-2012), kwittrr (06-29-2014), kylec_2003 (05-05-2012), LatinKraze (01-06-2012), m249saw (12-23-2011), mayer (02-24-2012), meelo88 (03-21-2013), Micha (02-13-2012), ms3bamf (01-08-2012), Ms3_Miami (02-03-2012), nb6179505 (06-24-2014), Onelovesoccer (12-22-2011), PapaBruno (10-18-2014), phahengpro (12-28-2012), Pointless (08-30-2012), Poohster (12-24-2011), randino69 (05-27-2012), Raymond (04-11-2013), redmnsterut (12-19-2011), RedTape (06-30-2014), rfinkle2 (01-27-2012), RhoadBlock (12-14-2011), Rhys (07-11-2017), richkidone (01-26-2012), rikyrick87 (12-15-2011), shadesofgray19 (12-15-2011), SKiZ0TT (12-20-2011), SLOWHATCH (01-27-2012), Snappy (11-19-2015), SofaKingAwesome (04-29-2015), spals (06-24-2014), SpankyCuervo (09-05-2015), speed3newb (09-08-2014), SpeedLife (08-16-2013), SpeedNess (02-23-2013), Sqc049 (03-21-2012), Stwok240 (01-06-2012), superq7 (01-06-2012), swsmailman (01-10-2014), themytb (05-17-2012), thepatient77 (03-17-2015), TiGraySpeed6 (12-15-2011), treavis (03-01-2013), TriO (12-14-2011), triphop631 (01-06-2012), turbo test (01-04-2012), uncorked11 (12-15-2011), Vader (01-06-2012), Visual7 (08-23-2013), WAHBAM (12-15-2011), Wallespeed3 (10-31-2014), wankular (01-06-2012), warlockfan92 (02-18-2013), Weazsel (06-02-2012), Westbound (01-29-2019), WetzMS3 (08-05-2014), Wicked Kitten (04-23-2014), Worbit (06-06-2013), xfeejayx (03-23-2012), xTRELLx (01-10-2014), ZetaDrift (05-01-2014), zkrick (03-13-2012) |
12-14-2011, 07:57 PM | #2 |
Join Date: May 2010 Location: Colorado Springs, CO 80915
Rep Power: 0 Thanks: 921
| Not Ranked : 0 score GREAT THREAD!
__________________ 2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD 2012 Jeep Wrangler Unlimited Sport: Current DD |
The Following User Says Thank You to DISIindahead For This Useful Post: | MS3-a(sore)ASS-rex (12-14-2011) |
12-14-2011, 07:59 PM | #3 |
Must Have Teh 10's! Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10778 Thanks: 6,334
| Neutral : +1 score tom if i could i would cum in your hair right now and slap you till you screamed banana good job son
The Following 12 Users Say Thank You to superskaterxes For This Useful Post: | ak_spray (03-27-2012), brandonlee (09-04-2013), CWP_MS3 (03-13-2013), F4LL3N (06-08-2014), Fail_6 (01-31-2012), i8urgti (12-14-2011), MS3-a(sore)ASS-rex (12-14-2011), RhoadBlock (12-14-2011), Speed3Power (01-21-2014), TiGraySpeed6 (12-15-2011), Worbit (06-06-2013), zpele (02-03-2012) |
12-14-2011, 08:04 PM | #4 |
Groans: 224
(Thread Starter) | Not Ranked : 0 score I'm still looking for a good how-to thread for MS6 dp install. If any of you have one just post up the link and I'll add it to the OP. Thanks.
12-14-2011, 09:36 PM | #5 |
Rep Power: 0 Thanks: 2,125
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) |
The Following User Says Thank You to chuckms6 For This Useful Post: | karl-hungus (12-15-2011) |
12-14-2011, 09:53 PM | #6 |
Rep Power: 0 Thanks: 667
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score How-To: MS6 DP Tools needed: Air tools make life MUCH easier Basic socket set Extensions U-Joints Beer 1. Disconnect battery 2. Remove TMIC (if necessary) 3. Remove heat shields 4. Lift front end as high as possible. Use e-brake & chocks behind rear wheels. Place jack stands in secure location under frame rail. 5. Remove upper and lower O2 Sensors...Carefully. 6. Unbolt DP from CBE. Disconnect 2nd Cat to ease removing DP. 7. Unbolt DP from turbo. 8. Curse Mazda for their stupid 5 bolt flange. 9. Expletives. Blood. 10. Swig beer. 11. Remove DP 12. Ice cold beer 13. Finangle new DP into place. Try not to damage anything in your engine bay in frustration. 14. Bolt DP to turbo. 15. Swig beer. Curse Mazda's 5 bolt again. 16. Bolt DP to CBE 17. Install heat shields, TMIC (if you haven't upgraded to a real IC yet), battery. 18. Ice cold beer. Say either "ehh, wasn't too bad" or "Fcuk you Mazda!" As accurate as that is, I'll try to find a real write up for you bro. Great thread homie.
__________________ 2007 MS6 - broked & gone 2006 MS6 - less broked Last edited by RhoadBlock; 12-15-2011 at 10:36 AM. |
The Following 13 Users Say Thank You to RhoadBlock For This Useful Post: | 15driley15 (05-22-2013), bazzarino (06-23-2012), Ferg (12-16-2011), IBEEDAT (08-27-2013), Jdmzms96 (03-28-2013), johnbarr00 (07-16-2013), Juyoung (03-11-2013), miamispeed3 (08-10-2012), MS3-a(sore)ASS-rex (12-15-2011), randino69 (05-27-2012), redboat (02-22-2013), SKiZ0TT (12-16-2011), TiGraySpeed6 (12-15-2011) |
12-14-2011, 10:28 PM | #7 |
Banned Join Date: Nov 2009 Location: Los angeles,Ca
Rep Power: 0 Thanks: 65
Groaned at 14 Times in 6 Posts
| Not Ranked : 0 score 145 + free shipping. Wow Ebay has gone alot cheaper. |
12-15-2011, 04:51 AM | #8 |
| Not Ranked : 0 score lol omg dont remove the stock manifold on the MS6. ill do a write up if i can catch some time later
The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | MS3-a(sore)ASS-rex (12-15-2011), RhoadBlock (12-15-2011) |
12-15-2011, 10:30 AM | #9 |
| Not Ranked : 0 score Holy hell IDK why I wrote that. It was too late for me to be typing I guess lol. Edited that post. Good catch bro |
12-15-2011, 04:58 AM | #10 |
Rep Power: 0 Thanks: 189
| Not Ranked : 0 score well done
__________________ New: 2012 Mazda MX5 Miata True Red |
The Following User Says Thank You to Jake5713 For This Useful Post: | MS3-a(sore)ASS-rex (12-15-2011) |
12-15-2011, 08:50 AM | #11 |
Rep Power: 3058 Thanks: 4,683
| Not Ranked : 0 score cpe guide for the MS6 attached (wow, it was like 0.2 KB below the limit for attaching ) worked like a champ for my install of the M2 dp Question- Looking at the pic included for the MS6 dp from ATP (shown below) I thought the O2 and spare O2 bungs are the opposite- that is the primary is closer to the turbo?
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq | |
12-15-2011, 10:22 AM | #12 |
Rep Power: 0 Thanks: 6,852
Groans: 165
| Not Ranked : 0 score Thanks trying to decide on one now.
__________________ New....Camaro SS/RS Stocked out selling parts. 2011 Black MS3 -GTX3071R , 38mm Tial Wastegate, CPE Exhaust Manifold, Cobb AP, HKS SSQV 4, Autotech Internals, JBR SSP & Bushings, JBR Fully mounted 88 duro, JBR OCC, JBR EGR delete, TWM M1Knob, H&R springs, Ultimate Racing Turbo back, NKG plugs, CP-E FMIC, big MAF, big TIP, Grimmspeed MBC, SPC Rear Camber Arms, JBR Sway bar. 2006 Jeep Wrangler -20 grand of Shit |
The Following User Says Thank You to uncorked11 For This Useful Post: | MS3-a(sore)ASS-rex (12-15-2011) |
12-15-2011, 10:33 AM | #13 |
Rep Power: 0 Thanks: 508
| Not Ranked : 0 score I think a nice addition would to this thread woukd perhaps list some dynos and gains. otherwise nice job Sent from my left nut.
__________________ 2013 Velocity red Mazdaspeed 3 tech. BT 2011 Velocity red Mazdaspeed 3-SOLD. FreeKtuned fitty fitty |
01-08-2012, 10:54 PM | #14 |
Ur moms boyfriend Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 Thanks: 923
Groans: 70
12-15-2011, 10:41 AM | #15 |
Rep Power: 167 Thanks: 182
| Not Ranked : 0 score What a GREAT summary, thanks OP!!!!
__________________ 2010 VRM MS3 JBR RMM, AUTOTECH HPFP INTERNALS, FORGE V2 BPV, DDM 6K LOWS, 8K FOGS, LED SWITCHBACK PARKING LIGHTS, RED CALIPERS |
The Following User Says Thank You to J_Logik For This Useful Post: | MS3-a(sore)ASS-rex (12-15-2011) |
12-15-2011, 10:44 AM | #16 |
Rep Power: 8624 Thanks: 17,845
Groans: 95
| Not Ranked : 0 score Thanks Tom, Well done Sir! Now I'll have to find a nurse for you! @MS3-a(sore)ASS-rex
__________________ Nator is what it does. |
The Following User Says Thank You to kritz For This Useful Post: | MS3-a(sore)ASS-rex (12-15-2011) |
12-15-2011, 11:05 AM | #17 |
| Not Ranked : 0 score Seems like there should be some reference to turbo seals/ vacuum issues / smoking issues that suddenly get very popular after adding in a DP... Loving my home made bnoon bolt- stopped ~90% of my smoking issues along with an idle increase
The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | MS3-a(sore)ASS-rex (12-15-2011) |
01-06-2012, 02:14 AM | #18 |
Rep Power: 0 Thanks: 3
Groaned at 46 Times in 20 Posts
01-06-2012, 12:48 PM | #19 |
| Not Ranked : 0 score and OP yea two of my friends have one and im getting one in a few weeks. imo no reason to get a more expensive one other than namebrand.
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) | |
01-06-2012, 01:32 PM | #20 |
01-06-2012, 03:04 AM | #21 |
Rep Power: 0 Thanks: 10,516
Groans: 89
| Not Ranked : 0 score Awesome !! Thanks
__________________ [SIGPIC][/SIGPIC] 2013 EVO X GSR Wicked White w/Areo H&R springs/H&R 15mm spacers MAP modified 3" Magna Flow cat back MAP catless testpipe MAP UICP Grimmspeed 3 port Cosworth filter SSP relay kit TWM Desert Eagle shift knob AEM wideband gauge Prosport boost gauge EvoX piller pod 30%Tint Slowpoke Tuned 339hp/336tq **** SOLD ***** 2006 speed6 " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " |
The Following User Says Thank You to jracer For This Useful Post: | MS3-a(sore)ASS-rex (01-06-2012) |
01-06-2012, 03:21 AM | #22 |
Rep Power: 0 Thanks: 5,044
Groans: 125
| Not Ranked : 0 score You might want to add a section for eBay pipes since they're awesome and a better price and quality than some of those |
The Following User Says Thank You to TWOptSL0W For This Useful Post: | karl-hungus (01-09-2012) |
01-06-2012, 05:08 AM | #23 |
| Not Ranked : 0 score +1 to the above posts on the M2 & ebay dp's. Mine (an M2 from ebay) is so far holding out well, and no over boosting issues here (yet...), running 20 psi on my everyday tune
The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | IshiKage (01-08-2012) |
01-06-2012, 01:47 PM | #24 |
Groans: 224
(Thread Starter) | Not Ranked : 0 score I'm not posting eBay DP's for the simple fact none of our vendors offer them. And I'd rather see our members buy from them personally. Besides all of your posts cover the eBay one pretty well lol
01-06-2012, 02:35 PM | #25 |
and i thought the point of these threads was to reduce noob questions as a whole, so i just thought it would be a good idea to include them regardless of vendor status because people are going to ask about them
01-06-2012, 03:01 PM | #26 |
Groans: 224
(Thread Starter) | Neutral : -1 score
__________________ MS3 has been retired to daily duty Project 1G; 1991 Eagle Talon TSi. 63MM Borg Warner Powered, Corn-Fed, 2.4L Long Rod Monster Under Construction Stock Turbo-Stock Engine Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA | |
01-06-2012, 03:23 PM | #27 |
| Not Ranked : 0 score this is true, but then you have true noobs such as above who only read the first post...but then again i suppose they could be told to read the whole thread just as easily lol
01-06-2012, 03:24 PM | #28 |
Groans: 224
(Thread Starter) | Not Ranked : 0 score You make a good argument regardless lol
01-06-2012, 07:55 PM | #29 |
| Not Ranked : 0 score On the M2, is that the before/after o2 bungs right next to each other at the top? lol, or is there a lower bung that isn't seen? |
01-06-2012, 08:17 PM | #30 |
| Not Ranked : 0 score there are three bungs total on the m2, two at the top and one at the bottom. all the bungs come with plugs.
01-08-2012, 07:34 PM | #31 |
| Not Ranked : 0 score 07 08 09 Mazda Mazdaspeed 3 Turbo 3" Down Pipe Downpipe | eBay Will that one fit the 2010's? I was going to go with the M2, but this one is a little cheaper, and the end of the M2 one has a part that sticks out passed the flange? |
01-08-2012, 10:39 PM | #32 |
Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 Thanks: 5,682
Groans: 278
My Ebay DP
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" | |
01-08-2012, 09:26 PM | #33 |
| Not Ranked : 0 score That ebay link is an M2 dp. Sorry I can't say what years it will fit, I'm not sure of the speed3 exhaust difference between years/generations Also, FWIW, that's the same vendor I purchased my M2 dp from on ebay.
The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | thems3driver (03-15-2014) |
01-08-2012, 09:28 PM | #34 |
| Not Ranked : 0 score Do you know why some of them have the extension after the flange at the end? for example: Stainless Steel Exhaust Downpipe Mazda 07 08 09 10 Mazdaspeed 3 Hatchback | eBay and then this one doesn't: 07 08 09 Mazda Mazdaspeed 3 Turbo 3" Down Pipe Downpipe | eBay confused |
01-08-2012, 10:09 PM | #35 |
Rep Power: 0 Thanks: 631
The Following 2 Users Say Thank You to Bob-o For This Useful Post: | infeKteDx (01-08-2012), Nliiitend1 (01-08-2012) |
01-08-2012, 10:12 PM | #36 |
| Not Ranked : 0 score Wow...awesome, thanks for clearing that up haha. |
01-08-2012, 10:13 PM | #37 |
Rep Power: 4020 Thanks: 10,876
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
01-08-2012, 11:59 PM | #38 |
| Not Ranked : 0 score Lol i believe in them, but i dont believe ud get much more than 5 whp and 10wtq.,which in my opinion is not worth the hassle. Sent from my left nut.
01-09-2012, 12:22 AM | #39 |
Groans: 70
| Not Ranked : 0 score Ohh is that what it is? |
01-09-2012, 07:38 AM | #40 |
| Not Ranked : 0 score I agree...if we actually have ANY dynos of before/after DP only. But how many ppl have spent the money to do that? |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/official-downpipe-test-pipe-race-pipe-thread-99627/ | ||||
Posted By | For | Type | Date | |
catless downpipes cause turbo to blow seals?? - Page 4 | This thread | Pingback | 11-10-2014 11:55 AM | |
Tuner/garage in Brampton/Mississauga area | This thread | Refback | 08-02-2014 08:51 AM | |
Downpipe options - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums | This thread | Pingback | 07-22-2014 10:53 AM | |
?????????? ?? ??????? 6 mps | This thread | Refback | 02-15-2014 02:51 PM | |
Aide pour choisir downpipe - Mazda 3 Quebec | This thread | Refback | 08-06-2013 07:10 AM | |
Mazdaspeed stage 2 downpipe vs racepipe | This thread | Refback | 06-19-2013 09:31 AM | |
Cat'd DP? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Refback | 04-21-2012 07:39 PM | |
I HATE heat shielding. MPS 6 | Post #6 | Pingback | 12-23-2011 02:44 PM |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Which Race Pipe/Test Pipe is the best for a Mazdaspeed 6? | ItalianSA | MazdaSpeed 6 - Engine, Transmission & Driveline | 6 | 04-20-2009 12:14 PM |
