| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Neutral : +1 score
And checking the chain for slack needs to be done with the engine at operating temp. The chain tensioner is oil pressure actuated. No oil pressure, no tension.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals | |
![]() Join Date: Sep 2011 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
| Not Ranked : 0 score Got one of you freeloaders in my bay right now. It's so obvious when you guys stock out. You leave things loose...bolts have markings on them that indicate they have been tampered with...Mode 6 data in the PCM isnt filled, incomplete monitor flags.. Not that I give a shit because I'm making my 4 hours either way. It's just funny, the stories people come up with to protect their warranty coverage. ![]() He might be talking about a little chain guide that most engines have between the cam gears. One could easily be bolted to the oil control valve and keep the timing chain from slapping the valve cover. |
| The Following 7 Users Say Thank You to timjs For This Useful Post: | laxplayermjd (01-18-2012), memin (01-20-2012), pipe (01-22-2012), sidekick (12-25-2013), Teethkikr (01-22-2012), thehead (02-12-2012), TheProYodler (01-29-2016) |
| The Following User Says Thank You to Raider For This Useful Post: | sidekick (12-25-2013) |
![]() Join Date: Feb 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| The Following User Says NO Thank You to CurrentlyPissed For This Un-useful Post: | kunfu (05-06-2012) |
No body wants to do warranty work when there is customer pay work to do. As you know, (and most people do NOT know) is that warranty pays so little, it's borderline criminal. Technicians are still forced to be paid by the same ancient method that was designed long ago, and made sense when the auto industry had plenty of work. Now, cars are so fucking reliable, there's no work. Our shop had 13 mechanics back in the mid 90's (from what the old timers have told me) and now the shop BARELY supports 3. Shit, I sat around for 5 hours today not making a single dime before I went home early. Sorry for ranting, but you get my point. Take your car to a busy shop that would rather do 30k's and used car inspections instead of warranty, and they will screw you over modifications. Take your car to a smaller dealer that doesn't have the work volume of the larger dealer, and they will happily take the 4+ hours of work to replace your timing chain.. it's that simple. Technicians only get paid while they are working, so ANY work is better then NO work. With that said, I'd rather do oil changes all fucking day than do another timing chain. I'm sick of them. | |
| Not Ranked : 0 score 2007-2009 MS3.... 4.3 hours. 2010 MS3 4.5 hours. All MS6... 4.5 hours. All CX-7 ... 4.4 hours. It's doable in that time. But, I'm too fucking anal about silicone. I spend so much time cleaning the timing cover and the engine that I screw myself on every one I do. But I'd rather lose a little money then have to re-do the job for free because an oil leak. |
| Blocked Wastegate Actuator hose to Turbo inlet | supersswa | MazdaSpeed 3/6 - Turbo Induction | 1 | 01-07-2012 01:05 PM |
| atp turbo pricing question, lines and actuator cost 300$?! | leo766 | MazdaSpeed 3/6 - Big Turbo Builds | 32 | 11-08-2010 11:30 PM |
| GS EBCS with a stock turbo/actuator | 06Speed6 | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 05-27-2010 07:49 PM |
| Government ends warranty program for GM, Chrysler | Haltech | Automotive News | 0 | 07-21-2009 10:20 AM |
