 Old 08-12-2017, 08:00 PM   #1
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
A leakdown test will tell you where the leakage is occurring. The technician is supposed to listen for where the air is leaking from. If I had to guess, yes, I would say the problem is likely in the bottom end, likely cracked ringlands. 15% leakdown on a stock motor is a lot.
2007 Mazdaspeed3 GT
Confusing electrical problem ShintaroIchi MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 08-02-2015 01:30 AM
Mostly good compression but shit leakdown results VA2010MS3 2010 MS3 - Engine, Transmission & Driveline 1 07-23-2015 09:43 PM
Bad Leakdown Mofford12 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 10-29-2014 04:26 PM
Leakdown test question torq MazdaSpeed 3/6 - Turbo Induction 0 08-09-2013 08:29 PM
Page generated in 0.22391 seconds with 21 queries
