 Old 09-22-2018, 08:37 AM   #1
Fitbkeco's Avatar
Posts: 24   (View Stats)
Fitbkeco is an unknown quantity at this point
Default Oil return line gasket
So I recently have developed an oil leak from the oil return line. It’s leaking at the block side but yesterday I changed the gasket out and it’s still leaking. I’m worried it didn’t tighten the bolts enough but I’m also worried about snapping them or stripping them out. Does did any one every change it before and how much torque can/do I have to put on those bolts to seal it up
Fitbkeco is offline   Reply With Quote
 Old 09-22-2018, 10:26 AM   #2
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
Try replacing those bolts with a stud. At least then you know you will have as much thread engagement as possible.
Those bolts do like to strip out, so be gentle on the torque.
 Old 09-22-2018, 10:12 PM   #3
Solarsurge's Avatar
Posts: 577   (View Stats)
If you have to ask how much torque, you're using too much. OEM gaskets should seal properly. Just make sure you clean both mating surfaces well to remove any old gasket material and/or dirt/debris and that there are no dents or bumps on either side.
Page generated in 0.23875 seconds with 22 queries
