  • 1 Post By silvapain
 Old 03-23-2012, 08:10 PM   #1
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
Default Our PCV System and improving Vacuum on the Crankcase - Eliminate Smoking Turbo Issue
Ok I know there are threads on Krankvents which are even more extensively debated but I'm trying to bring this concept more to the forefront of the discussion so that a larger percentage of our forum members can understand what's going on with our PCV valve and the smoking turbo issue.
I have attached an MS Paint diagram of how the flow is with our stock system. As you can see from the diagram that shows flow while NOT under boost pressure, the vacuum produced in our intake manifold, pulls vapors out of our crankcase through the PCV valve. Air rushes in through our valve cover vent to replace the air that's being sucked out of the crank case. As a result, there is somewhat of a vacuum on our crankcase but often not strong enough to allow draining of oil out of our turbo lines thus causing smoking.
In mockup #2 that shows the situation while under boost, our crankcase PCV valve is now shut since flow is only one way and that is OUT of the crankcase through the PCV valve. Our intake system, ahead of the turbo is mostly not under vacuum but under boost, when the turbo is sucking air in, a vacuum DOES exist within our intake system, whether that be a short ram intake, cool air intake or stock airbox. This vacuum is then pulling vapors out through our valve cover and back into our air intake system.
Summary, both under idle/vacuum conditions and under boost, there is always a source of vacuum on the crankcase BUT HERE IS THE PROPOSED ADDITION:
While the car is at idle, that's when we start to have smoking turbo because the vacuum flow to the crankcase ends up being too weak, most likely because air is so easily flowing BACK INTO THE CRANKCASE through the valve cover opening. If we install a check valve or just another plain old PCV valve here, allowing air to only LEAVE the valve cover, we can achieve the following:
1)Oil vapors are still vented into the intake because the added valve will allow
vapors to EXIT...
2)Since flow is only one way, and that's OUT of the valve cover, a much
stronger vacuum is maintained AT ALL TIMES within the crankcase.
3)Oil drainage out of the turbo at idle should be much more efficient in the
presence of higher vacuum.
4)Sealing of piston rings enhance in the presence of a steadier vacuum.
5)A LOT LESS WATER being pulled into our crankcase and then into our catch
cans. As a result of air NOT being pulled steadily in through our valve cover
port, there won't be the constant supply of moisture that precipitates out
into the crankcase/oil catch can. This should help reduce that hideous
sludge that we've found, caking up in our catch can and lines leading to the
catch can. Remember the peanut butter as some of us call it?
So my question is, does anyone see a problem with this? I think someone mentioned in one of the threads at one point, perhaps on the mazda6club, that it wasn't good to have too much vacuum in our crankcase but not sure if that's going to be a problem with our cars since it's kind of weak in the first place. I realize that this touches on the concept of the usage of KrankVents but in isolating out just the junction between our valve cover and the intake system, I think this may be a trouble spot where we lose a lot of our vacuum to the crankcase, at idle.
Thanks for staying with me on this long post. I think we may have something here that could improve our ill-designed PCV system.
mczimer is offline   Reply With Quote
The Following 3 Users Say Thank You to mczimer For This Useful Post:
802MS3 (03-23-2012), BigRedSpecial (03-24-2012), rob ms6gt (03-25-2012)
 Old 03-24-2012, 02:36 AM   #2
leon78's Avatar
Posts: 2,595   (View Stats)
@bnoon
2013 Scion FR-S (Whiteout)
Less parking more racing
 Old 03-24-2012, 02:58 AM   #3
ljudgeii's Avatar
Posts: 180   (View Stats)
ljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond repute
I tried that with a failing stock PCV valve back in 2009, worked fine til I went TBE with high flow cat
07 Black Mica with Sunroof"
11/17/11 ZZ-SB (Spun #4 Rod Bearing @97,643 miles)
"I'm back Baby" says the almighty Bender
CURRENT MODS:
Cobb ATR self tune+JBR WP+FMIC+BNR S3+MI+IM+CP-e EXMAN:
VDyno 351hp and 331tq
BEST 1320:
COBB AP S2+MSCAI2+FMIC-v1.03i Best ET on 2Nov08 13.6@98mph (yeah I missed 5th gear)
ljudgeii is offline   Reply With Quote
 Old 03-24-2012, 07:20 AM   #4
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Just move the line from the valve cover closer to the turbo inlet. That's Mazda's solution, and that's all
I had to do to fix my smoking turbo.
Tapadatass
bigriver likes this.
bigriver (03-27-2012)
 Old 03-24-2012, 07:29 AM   #5
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
I have an all metal PCV valve from a twin turbo supra for this exact purpose.
(~$1.50 from advance auto, all metal construction and a bullet proof, long-lasting reputation)
However the combo punch of 900 RPM idle, bnoon bolt and Rotella 5-40 has dealt a blow to my smoking issue. Next long weekend I will also be rebuilding my ~62K miles K04 to install new seals as well. Rebuild kit runs about $50, and should take longer to get it out of and/or back into the car than to do the actual rebuild.
340hp / 371tq
 Old 03-24-2012, 07:59 AM   #6
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
Interesting idea... I haven't had any smoking issues yet, but wouldn't this also cut down on the amount of crap being dumped into the manifold?
Needed: Driver mod
 Old 03-24-2012, 06:44 PM   #7
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Just so that noobs know, krankvents are not pcv valves. You still need a pcv with them and the extra restriction of having two valves on an already poor vacuum source probably negates alot of the benefits.
2006 Mazdaspeed 6
 Old 03-24-2012, 09:40 PM   #8
EL F00LI0's Avatar
Posts: 703   (View Stats)
EL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the world
Subbed for some good info.
Sent from my BlackBerry 9300 using Tapatalk
2008 MAZDASPEED 3 GT
| Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP |
| Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 |
| Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip |
EL F00LI0 is offline   Reply With Quote
 Old 03-25-2012, 12:35 PM   #9
RaceBuilt's Avatar
Posts: 173   (View Stats)
RaceBuilt is the leader of the worldRaceBuilt is the leader of the worldRaceBuilt is the leader of the worldRaceBuilt is the leader of the worldRaceBuilt is the leader of the worldRaceBuilt is the leader of the worldRaceBuilt is the leader of the worldRaceBuilt is the leader of the worldRaceBuilt is the leader of the worldRaceBuilt is the leader of the worldRaceBuilt is the leader of the world
Groaned at 18 Times in 16 Posts
This vent situation is alight but not the correct way to fix the smoking issue. The two main reasons to have a catch can are, #1 to catch oil blow by from the motor caused by excessive pressure. #2 to free up pressure from the block so you can make more reliable HP. What a lot of people dont realize is a lot of pressure builds under the pistons causing ring failure. In many pro drag cars, they add a vacuum pump plumbed from the block to remove added pressure caused by the forced air in the combustion chamber. There is not reason to plumb it back into the intake tube at all. I'll put up some pictures of what I'm talking about later today. Say what you want about this but I've had years of experince in this matter.
@IshiKage
vapors to EXIT...
RaceBuilt is offline   Reply With Quote
The Following 3 Users Say Thank You to RaceBuilt For This Useful Post:
06Speed6 (03-26-2012), IshiKage (03-25-2012), mczimer (03-28-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/our-pcv-system-improving-vacuum-crankcase-eliminate-108777/
Burning Oil help This thread Refback 03-26-2012 08:18 AM
CrankCase Evacuation System SilverDemon MazdaSpeed 3 - How-To's 402 01-29-2012 03:16 PM
Crankcase breather system 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 65 06-06-2010 04:19 PM
MS6 Vacuum Pressure Issue Speed_Demon MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 03-09-2010 04:52 PM
Found what my smoking issue was turd burglar MazdaSpeed 3/6 - Turbo Induction 1 01-31-2010 02:47 PM
Smoking turbo issue - Gone for me! kgb MazdaSpeed 3 - Engine, Transmission & Driveline 16 05-27-2009 03:56 PM
Page generated in 0.32486 seconds with 29 queries
