 Old 02-16-2012, 03:43 PM   #1
ms6forthewin's Avatar
Posts: 525   (View Stats)
ms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the world
Default overboosting stage 2 ots
So yesterday, I loaded a stage 2 sf tih + ic 91 map. I drove it around for about 50 miles and today when I went on ramp to get on the freeway I decided to go wot. Turns out I was hitting around 19 - 20lbs around 4k to 5k rpm and then of course fuel cut.
anyone else experience this? I thought ppl weren't hitting desired boost, while im here overboosting lol
Should I turn down the wgdc?
-2014 Evo X GSR
-2007 MAZDASPEED 6 (SOLD)
BNR S3// ALL-SUPPORTING MODS
ms6forthewin is offline   Reply With Quote
 Old 02-17-2012, 02:29 AM   #2
BobbleHead's Avatar
Posts: 2,237   (View Stats)
Groans: 186
everyone's wastegate responds differently. You can fix it by lower WGDCs. It will take some time to get them right.
Also with your mods you should try 18-19 psi. If you get no knock then enjoy it! Just raise the fuel cut
 Old 02-17-2012, 02:57 AM   #3
going bk to my old map, lol
-2014 Evo X GSR
Overboosting in 4th, but not 3rd? WorstEpEver MazdaSpeed 3/6 - ECU Computer Tuning 14 08-23-2011 08:13 AM
Overboosting? phlselspd6 Mazdaspeed3/6 General Discussion 32 01-16-2011 09:46 PM
Overboosting! Yahdy Ras MazdaSpeed 3/6 - Turbo Induction 3 08-14-2009 08:35 AM
overboosting? phantomspeed3 MazdaSpeed 3/6 - ECU Computer Tuning 24 06-07-2009 11:47 AM
Overboosting issue BoostedBlack6 MazdaSpeed 6 - Engine, Transmission & Driveline 3 10-27-2008 02:19 PM
Page generated in 0.24108 seconds with 21 queries
