 Old 02-28-2014, 07:17 PM   #1
Zmcg1995's Avatar
Posts: 258   (View Stats)
Zmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond reputeZmcg1995 has a reputation beyond repute
Default P2088 caused/related to p0016
So i did some research about the p2088 and there was alot of information about how people had forgot to plug the sensor in or the wire was cut/split but i didnt find much about the actual cause of the problem. I had the famous vvt sound hitting the valve cover so i took it into the shop to get that fixed and upon arrival they checked the ecu for codes and it read, p0016 which i thought was related to the bad vvt, and also p2088... now my first thought was that maybe this code could be related to the bad vvt and it would go away after that was fixed. Is this the case? Could this code go away after i get my vvt replaced? Any information would be helpful. Thanks
Zmcg1995 is offline   Reply With Quote
P0016....awesome. Any Ideas? Motocooney MazdaSpeed 3/6 - Troubleshoot/Diagnostics 28 05-01-2014 01:13 PM
P0016 ciezczak1 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 08-23-2013 07:29 PM
P2088 code sallyspeed3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 06-11-2012 07:20 PM
timing related codes - fml - p0011, p0012, p0016 phillyb MazdaSpeed 3/6 - Troubleshoot/Diagnostics 31 11-03-2010 04:14 PM
Watch Your Fingers: Most car-related injuries caused by doors Haltech Automotive News 0 02-18-2009 07:30 AM
Page generated in 0.22051 seconds with 21 queries
