![]() Join Date: Jul 2015 Location: La Quinta.CA
Rep Power: 0 ![]() Thanks: 1
Rep Power: 3745 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| I think the code is a P0300, right? That's a random misfire. You might want to swap the coil packs from cylinder-to-cylinder and see if you can narrow down whether you've got a single bad coil-pack (that is, if the misfire starts to manifest in a single cylinder). What spark plug gap are you running? It should be between 0.024" and 0.027" per Mazda's revised service manual from 2010. What modifications do you have on the car?
| The Following User Says Thank You to Vansquish For This Useful Post: | frothy (12-20-2015) |
(Thread Starter) | Not Ranked : 0 score My car is bone stock. The plugs are gaped at .027. Does it matter which coil pack that I use on each spark plug? I marked them before I changed the spark plug to ensure I put the correct coil pack on the correct plug. |
| The wires leading to each plug cylinder must remain in the same orientation they came in. However, you can unplug and move the individual coil packs from cylinder to cylinder. Mark each one, and move them around.
| Not Ranked : 0 score It's a random misfire on all 4 cylinders so I doubt that moving the coilpacks around will help but try and see. What are exactly the spark plugs you bought (model/part number)?
| The Following 3 Users Say Thank You to Code Monkey For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score NGK Laser Iridium part #95369 from Oreilly's |
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned | |
![]() Join Date: Mar 2010 Location: San Francisco, CA
Rep Power: 295 ![]() Thanks: 14
| Not Ranked : 0 score Your P030X (X = cylinder #) keeps coming back? Please keep us updated. I had a P030X code before, cleared it and never came back. I would like to know how yours turn out, thanks! |
(Thread Starter) | Not Ranked : 0 score I made an error I put the stock # down not the part # of SILTR6A7G. I cleared the code by disconnecting the battery and I am monitoring my car to see if the check engine light comes back on. |
Groans: 143
Also, if you go here, and type in my car (2012 Mazdaspeed3), it will direct you to the SILTR6A7G. PartCat As far as I know, the only difference between the ILTR6A-8G, which are stock for the Gen1 and MS6, and the SILTR6A-7G is that the gap was decreased from 0.032" to 0.028". They are both NGK laser iridium plugs. I agree with OP's decision to buy the smaller gapped plug as it is less prone to spark blowout.
__________________ 2007 Mazdaspeed3 GT | |
| The Following User Says Thank You to MD1032 For This Useful Post: | Code Monkey (12-21-2015) |
(Thread Starter) | Not Ranked : 0 score Well at this point I am getting frustrated. I put the NGK plugs in, disconnected the battery to remove the check engine light. The check engine light came back on after 4 days. I am going to check the plugs and switch the coil packs around to see if one of the coil packs need replaced. If anyone has any ideas how to resolve please let me know. I really don't want to have to take it back to the dealer. |
Groans: 143
| Not Ranked : 0 score Did you already check to make sure all of the ground connections to the chassis are good? I have uploaded the directive for troubleshooting this code from the service manual. Normally I wouldn't post this because you're a brownie and really you should just buy VIP so you can download a copy of the service manual. Merry Christmas. Personally I would start with the basics. Log in closed loop and monitor fuel pressure, AFR, MAF voltage, intake air temp, throttle position, oxygen sensor voltage for both sensors, short term fuel trim, and long term fuel trim, grouping as needed so that torque or whatever app you're using can log with enough resolution to to see any electrical spikes or odd things. I had a misfire a couple weeks ago on my car due to a dirty fuel injector (using fuel injector cleaner in-tank resolved the problem) and it was really noticeable when the car was cold. Note any behavior like this and monitor applicable parameters closely under these conditions. Also, please post the tune you are using so we can examine your MAF curve. It always amazes me how important a good MAF curve is on this car. If you don't have a good one, it will cause all kinds of problems.
(Thread Starter) | Not Ranked : 0 score Thank you very much. At this point I will become a VIP with the issues I have been having with this car. It's funny that you mention the fuel injector cleaner. When I did use it my check engine light cleared and that is with the Autolite plugs not the NGK's. |
![]() Join Date: Oct 2011 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 601
Groans: 106
| Not Ranked : 0 score Mileage on the car? In which cylinders is the dealer seeing the misfires? |
| The Following User Says Thank You to highwayrun For This Useful Post: | MD1032 (12-27-2015) |
(Thread Starter) | Not Ranked : 0 score When I had the serviced on July 28, 2015 the invoice just states it was a P0300 code they inspected the TSBS and SM's. Found TSB 01-015/14 and they cleared it. I took it back the August 17, 2015 they inspected and found P0300 code and said plugs were carboned up. I replaced them with autolites. I took it back in December 18, 2015 and P0300 code and they said it was the spark plugs. I put in NGK's this time. I had it scanned yesterday and the P0300 code and P2006 code showed. I got it back home and took off all the coil packs and stretched the springs. I also checked all connnections. The check engine light is still on. The vehicle currently has 62,800 k on it. |
Groans: 106
| Not Ranked : 0 score It matters which cylinders. See the TSB here. Code P0300 TSB 01-015-014 |
| TPMS code U0127 and ABS code B1318 | Z32_MS3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 19 | 05-12-2015 06:34 AM |
| P300 after injector seals! Help! | my speed6 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 04-06-2015 12:36 PM |
| P0401 code just got my mazdaspeed 3 and this code popped up | Steezyms3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 12 | 04-23-2014 02:20 PM |
| CEL - Code | 79BlueSC | Mazdaspeed3/6 General Discussion | 2 | 12-20-2010 12:06 AM |
| random cylinder misfire - p0300 p300 | phillyb | MazdaSpeed 3 - Engine, Transmission & Driveline | 17 | 09-26-2008 03:50 PM |
