 Old 04-01-2008, 01:04 PM   #1
trufanatic's Avatar
Posts: 172   (View Stats)
trufanatic has much to be proud oftrufanatic has much to be proud oftrufanatic has much to be proud oftrufanatic has much to be proud oftrufanatic has much to be proud oftrufanatic has much to be proud oftrufanatic has much to be proud oftrufanatic has much to be proud of
Default Part Request
You know, a new higher tension wastegate actuator will help us hold more boost till redline using a boost controller for us that take the reworked turbo path. And this can be sold as an upgrade for those not even taking that path. The upgraded actuator did wonders for the stock SRT turbo and it made the car PULL so much harder.
I kno for a fact, bulk cost their cheap as dirt but you'll have to get the bracket fabbed...
Good idea? huh?
trufanatic is offline   Reply With Quote
The Following User Says Thank You to trufanatic For This Useful Post:
occschemguy (04-03-2008)
 Old 04-01-2008, 07:14 PM   #2
ptperformance's Avatar
Posts: 4,123   (View Stats)
Good idea? huh?
Already working on them. Brakets are at the bend shop now, just waiting on the WGA to show up so we can get the pin hole right or needed spacers if thats required.
 Old 04-01-2008, 08:14 PM   #3
trufanatic's Avatar
you sir are the shit. when can i mail you my extra stocker to get a big wheel and port job? i'll preferably want it back with the WGA though
 Old 04-01-2008, 09:10 PM   #4
Send it out in 2 weeks. I have been told that the WGA and brackets will be done around then. The only thing to get is the pin spacer (very small pin on the stock WGA arm to flapper) so the new WGA will work with it. I have my ducks in a row now so we should be ready here in the next few weeks with lot and lots of parts for you MS3 guys.
 Old 04-02-2008, 10:55 AM   #5
RIP May 9th, 2012
sbspeed's Avatar
Posts: 111   (View Stats)
sbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to beholdsbspeed is a splendid one to behold
...and the MS6 guys too, right?
sbspeed is offline   Reply With Quote
 Old 04-02-2008, 10:59 AM   #6
BlackMS3's Avatar
Posts: 1,078   (View Stats)
BlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the world
People still have MS6's?????
BlackMS3 is offline   Reply With Quote
 Old 04-02-2008, 11:25 AM   #7
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
 Old 04-02-2008, 12:44 PM   #8
BlackMS3's Avatar
Yeah and for some reason, we always seem to be a little faster.... must be all that extra un-needed crap!
 Old 04-03-2008, 08:29 AM   #9
Yes, sorry didn't mean to forget about you guys.
The Following User Says Thank You to ptperformance For This Useful Post:
Skid (04-03-2008)
 Old 04-03-2008, 12:46 PM   #10
RIP May 9th, 2012
sbspeed's Avatar
Amen.
 Old 04-07-2008, 08:23 AM   #11
trufanatic's Avatar
i changed my mind, please hurry up with the T3 flanged manifold so i can get a 50trim with a .48ar hotside slapped on this bad boy.
listening to jeopardy music!...im waiting..............
 Old 04-08-2008, 08:50 AM   #12
If need be I can modify one of the DNP units to accomidate you? Let me know, thanks.
 Old 04-08-2008, 02:39 PM   #13
trufanatic's Avatar
will this entail reflanging the mani OR a small adapter plate? In all honesty for what most of the community is looking for power wise and what the motor can handle, we dont need more than an emanage and a 50trim.
 Old 04-12-2008, 08:25 AM   #14
Reflange and install of a external gate flange.
NGK part # for colde plugs ? mazdaspeedjay MazdaSpeed 3 - Engine, Transmission & Driveline 38 01-30-2010 07:47 PM
Page generated in 0.33118 seconds with 24 queries
