![]() Join Date: Sep 2017 Location: Sacramento
Rep Power: 0 ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score So ive been looking at different Motors mounts and ive come to except that the vibrations are going to be rough and what not but i dont have the funds to buy both transmission and passenger mount. If you had to decide which one to get first or see the most improvement from just 1 mount which would you choose? PS. i already have the rear motor mount. Last edited by mazdafanboy3; 09-19-2017 at 08:28 PM. |
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score since you want your grundle massaged, passenger.
__________________ 94 M MS6 IS350 |
| The Following User Says Thank You to Pu Manchu For This Useful Post: | mazdafanboy3 (09-19-2017) |
![]() Join Date: Aug 2017 Location: Santa Clara, CA
Rep Power: 0 ![]() ![]() Thanks: 2
| Neutral : +1 score I can't comment on which is better performance wise but my thinking is to replace the passenger mount first since those fail a lot more often than the transmission mount. My pmm blew and puked brown hydralic fluid all over my engine bay. As for increased vibrations, search the forums for reviews. After reading I decided to go with Damond's pmm. It costs more than others but people says it has the least increase in vibrations. I haven't installed it yet so I can't comment on my experience. |
| The Following User Says Thank You to Smallville For This Useful Post: | mazdafanboy3 (09-25-2017) |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Neutral : +1 score The TMM is directly next to the shifter cables so doing that first makes shifting nicer. Also it makes the tranny more auditable. The PMM is a lot easier to install and the vibes make my mangina all wet and sticky.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
| The Following User Says Thank You to 5doorsoffury For This Useful Post: | mazdafanboy3 (09-25-2017) |
![]() Join Date: Sep 2015 Location: British Columbia, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
| Not Ranked : 0 score I have been running a JBR rear mount for the last 2 years or so, the vibe increase was very noticeable. Recently I installed a Damon PMM and the vibes increased even more. I now have pieces of foam hidden around the centre console to stop the annoying rattles. God knows what it is like running all three mounts. |
![]() Join Date: Jul 2014 Location: The Rio Grande Valley, Texas. USA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 99
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score By a used low mile PMM off of somebody/or salvage yard if you really feel the need to replace the PMM. You should only replace it with aftermarket (something not made out of rubber) if you seriously track the car or drive it really hard often. Basically, replace TMM first. After that you probably will be on the threshold of vibes and noise, especially since you already have a RMM.
__________________ [SIGPIC][/SIGPIC]It's OK to cry" - Lil B 2012 MS3 w/Tech Package Engine: CS SRI/Tip, AutoTech internals, Damond Banjo Bolt, JBR Boost Tubes, E-Focus Mount, CS Racepipe, Tuned by FREEKTUNE Trans: CS insert, CS bushings, Damond Shifter Plate Suspension: Koni Orange with OEM springs, Konig Controls 17x7 with 225/45 Conti DW's Appearance: CP-E Relocation Plate, Smoked Taillights, Bumper Guard, CS Steering wheel/Shift knob/E-brake handle,dumb stickers |
![]() Join Date: May 2017
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 550
| Not Ranked : 0 score Depends on what you plan to do with the car I guess. I too heard good things about the Damond PMM. I worry about vibes a wee bit. So, I chose the OEM used route myself. Just for now anyways. |
| Not Ranked : 0 score Go with a Damond Trans mount first and keep or purchase an OEM passenger mount to see how you like the vibes. The passenger mount will make the most difference when it comes to NVH. Thats what i plan on doing, although if i can't sell this CPE passenger mount I'm just going to put it on my car, seeing as though apparently its really not that much different than a stock mount and less harsh than the JBR and even the Damond.
![]() Join Date: Aug 2013 Location: Ft Myers, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
| Neutral : +1 score My set up is CS RMM and MD TMM and PMM. NVH is minimal. At a stop there’s minimal rattle, and the only time the mirrors shake (minimally) is on first acceleration from a stop. Is it harsher then stock? Yes. But it’s not the horror show that everyone makes it out to be. You have a sports car. Enjoy the feed back that the Damond mounts provide Sent while probably pooping
__________________ CS TIP/SRI CS RMM CS Sexy Steering Wheel CS Springs & Struts CS Shirt Throw Shifter CS Shifter Bushings CS TBE CS Boost Tubes CP-e TMIC HKS BOV in resirc DM Vented OCC DM TMM DM PMM DM SSP Autotech Internals Custom E33 Freaktune |
| Dual Product Release!! CorkSport Mazdaspeed 3 Passenger Side Motor Mount and Transmission Insert | CorkSport | CorkSport | 143 | 04-13-2016 12:00 AM |
