![]() Join Date: Apr 2015 Location: Sterling Heights Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 47
Groaned at 9 Times in 7 Posts
(Thread Starter) | Not Ranked : 0 score I'm posting this thread mainly as bookkeeping for myself as a way to track what parts I'll be needing, but also so anyone can chime in with recommendations. In short, my cylinder 3 has 110 psi compression and holds 9/30 psi in a leakdown with air coming from the oil cap. It drives fine, but I know it's only a matter of time. So, my plan is to tear it down and rebuild it in May. I have some mechanical skill, but not enough for this, so I will be enlisting the help of my father who is more experienced, has the vast majority of needed tools, and possibly even a lift. Details: The car (2007 MS3 GT) has 110k miles (likely ~115k by the time May comes around since I'm still in school) and I've had it since 80k. Based on its condition when I bought it, I'm under the assumption that the previous owner did ZERO maintenance to this car. It has had a very hard life. Goals: I thought awhile about it, and there's no new car on the market that delivers exactly what I want out of a practical car to the same extent as my MS3. It's fast, gets decent fuel economy, and isn't weighed down by a comical amount of unnecessary electronic garbage (call me old fashioned, but I have no use for an "infotainment" system, I just want to drive the damn car). So, I want to treat my MS3 as my new car. I want to take the time, do it right, and have this car last me another 150k miles. In terms of mods, please see my sig. In addition to what's there, I may throw on a TP or a catted DP (if it doesn't sell) and have it tuned by Freak or Stratified. I don't really need anything over 300 whp because the MS3 is not intended to be my fun car, rather a more fun than average DD. Budget: Essentially unlimited, but I'd like to keep it below ~4k. With that, and again please comment if you have any suggestions, additions, or corrections, here is my planned list: 1. Engine Gasket set: Stage 1 MZR Motor Build Kit MS3/MS6 2006-2013 2. Rod Bearings x4: Mahle Clevite Rod Bearings H-Series Performance SINGLE Mazdaspeed 3 Mazdaspeed 6 3. Main Bearings: Mahle Clevite Main Bearing Set AL Series Standard Size Mazdaspeed 3 Mazdaspeed 6 4. Main Studs (how many do I need? It looks like 10?): Mazda OEM Main Bolt Mazdaspeed 3 2007-2013 | Mazdaspeed 6 2006-2007 - EdgeAutosport.com 5. Head Studs (how many do I need? Again, it looks like 10?): Mazda OEM Head Bolt Mazdaspeed 3 Mazdaspeed 6 6. Timing: The timing cover has been off my car before (prior to my purchase), but I cannot confirm that it has the revised kit. Should I replace the timing system? I'm honestly unsure of its life expectancy. If I do replace the timing system, I would get this kit along with the tool kit: Mazda OEM VVT Replacement Kit Mazdaspeed 3 / Mazdaspeed 6 7. Pistons: http://www.speedperf6rmanc3.com/prod...-mzr-disi.html 8. Rods: http://edgeautosport.com/manley-h-be...d-6-2006-2007/ 9. Injector Seals: https://corksport.com/mazdaspeed-3-f...tor-seals.html 10. Turbo: I hate yall for convincing me: http://www.speedperf6rmanc3.com/prod...-mzr-disi.html 11. I've been told it would be best to send the head off for machining. I don't know anything about this other than the fact the valves will desperately need cleaning. 12. Motor Mounts: I do not want excessive NVH. Again, this is a comfortable DD. My RMM according to the seller will have 60-70k miles on it, so I won't replace it for awhile. PMM: If there's not much NVH: http://edgeautosport.com/damond-moto...d-3-2007-2013/ TMM: If there's not much NVH: http://edgeautosport.com/damond-moto...d-3-2007-2013/ Now less important things 13. LCA's: My bushings are shot. Whiteline Bushings: Whiteline Control Arm Bushings Lower Inner Front Mazdaspeed 3 MS3 14. Front sway bar bushings: Again, I believe these are shot. I would go with: https://www.amazon.com/dp/B001GBN0YA...iglink21759-20 Price: 1: $537.28 2: $57.56 3. $80.79 4. $56.60 (for 10) 5. $62.50 (for 10) 6. $473.97 (for full kit + tools) 7. $609.98 8. $360.45 9. $179.84 10. $1099.00 11. ? 12. $220.00 + $255.00 13. $35.82 (for bushings) 14. $10.46 Total: $4,039.29 Thank you for your time.
__________________ Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks. Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A. Last edited by Bingo; 11-08-2017 at 02:32 PM. |
![]() Join Date: Feb 2011 Location: Chicago
Rep Power: 365 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
Groans: 74
| Not Ranked : 0 score If you are going that far might as well: 1. Take motor out 2. drop subframes/suspension 3. Strip undercarriage 4. Fix rust 5. Spray Epoxy primer 6. Replace ALL BUSHINGS. 7. Let it rip. Your car will start having visible rust in two years max. I have 05 Mazda 3 and it is a rust bucket all around. I plan on doing the same project but finding a clean shell (it could be a regular 3), stripping everything, replacing all bushings, and putting motor in with big turbo.
__________________ 2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE 2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too. |
(Thread Starter) | Not Ranked : 0 score Ya, it's definitely worth doing a coating on it. The car has minimal undercarriage rust and no body rust yet (Oklahoma car). Bushing wise, the shocks and struts are a year old along with their bearings and bushings so I should be good there.
__________________ Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks. Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A. |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
| Not Ranked : 0 score Why keeping the stock bore? With that mileage, there's a possibility that the cylinder heads have tapered and you're going to need to re-bore your block. With the cost of OEM piston rings + pistons, you could almost spend a little bit more and get Manleys or SP63 4032 pistons (Although i think 4032 is better for longevity) For your goals, you're better off using OEM bearings. These are what I'm using for my build. Yes 10 each for main and head bolts. Do you have friends that work at a Mazda dealership? A local hooked/hooking me up with all OEM parts (equivalent to Stage 3 motor build kit from Edge) for $300 cheaper than Edge.
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 |
Groans: 111
| Not Ranked : 0 score Try to source King XP bearings for both rod and main. Change the rods and pistons while you're at it. Yes, that's going to be $1k more but worth the diff. Look into getting the 4032 alloy pistons. For motor mounts, if you want a comfortable DD then then the gen2 tripode and transmission mount and add the corksport TMM insert. Leave the PMM stock and upgrade the RMM with whatever you feel worth it. If the car never overheated then you may get away without machining it. Just put a new head gasket and you're good. Don't cheap out on turbo either. Add an S3. Get OEM LCAs, do not add stiffer sway bars. Get OEM main bolts and keep the balance shaft. Throw the factory head bolts for stronger aftermarket head studs (CA 625+).
__________________ Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks. Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A. | ||
Groans: 111
For the turbo... the S3 should spool a bit sooner, maybe 3200-ish. The lag isn't that bad, after all it's a 2.3 litre engine, not an 1.4 mule, so at 2800rpm in 5th believe me you will be in boost quite soon. Also, usually when people want fast response and acceleration they're usually above 3000rpm. My GTX3071 should be even laggier (like an S4) but if I jump on the gas pedal at 2500rpm then at 3000 I'm already spinning the tires. However, I understand that you want to build just a decent commuting car and an S1 makes a lot of sense. But just because of that, since cruising will be the same with an S1, S3, S4 or a GTX3582, having a tad more available when certain situations require it (like BMWs or mustangs fucking around) then why not have it for a barely significant difference of money... So this is my logic and it may not apply to you, but thing a bit more about it maybe it actually makes sense for you as well.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
(Thread Starter) | Not Ranked : 0 score Ya, I'll see when the time comes, I'm very much on the fence about the turbo. In terms of pistons, Edge has wiseco's for $550 including rings while it looks like the SP63's are $600 without rings?
Groans: 111
SP63 4032 Series Pistons For Mazda MZR-DISI - SPEED PERF6RMANC3
(Thread Starter) | Not Ranked : 0 score Ah. I looked at that link, and it doesn't explicitly say it comes with rings (while with Wiseco's it does). Good to know it comes with them though, that makes the SP63's damn near the same price as OEM...
Groans: 74
| Not Ranked : 0 score If you need to order OEM parts tasca Mazda is not bad and zoomzoomnation.com(local dealership to me). They should have prices close to Mazda racing pricing.
(Thread Starter) | Not Ranked : 0 score Alright, the list is updates with my current thoughts. I'll upgrade the rods and pistons (Manley H-Beams and SP63's) and then I may as well spend a bit more for an S3. Now then. 1. OEM LCA's are incredibly expensive, so I'll try to get away with just replacing the bushings. 2. TMM and PMM: The OEM PMM is $255, and I couldn't even find an OEM TMM (besides through Mazda). Also, If I do go with an S3 (it would be accompanied by my current mods plus a long-catted DP and 3-port), are OEM mounts still a good idea? 3. Main and rod bearings @mituc; why the King XP bearings? I don't know anything about these (or any other ones) but they're twice the price of the Mahle's. Also does this change at all if I do end up making closer to 330 whp?
Groans: 111
You're rebuilding an engine and throwing at least $5k at it in parts and labour, $50 is like 1%, so don't cheap out at relatively inexpensive but critical parts. It's one thing to get some $1200 conn rods versus $350 ones which will still hold 600-650whp no problem, and another thing to spend $50 more on main and rod bearings.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |||
| The Following User Says Thank You to mituc For This Useful Post: | Thor Hammer (11-09-2017) |
| Planning a rebuild. Need some tips/guidelines. | paveltol | MazdaSpeed 6 - Engine, Transmission & Driveline | 21 | 09-08-2012 02:26 PM |
| REPORT: Ariel planning all-new alt-powered vehicle | Haltech | Automotive News | 0 | 05-21-2009 01:10 PM |
| UPDATE*: complete engine tear down and rebuild wrtie up | mazdaspeedjay | MazdaSpeed 3 - Engine, Transmission & Driveline | 23 | 05-02-2008 04:21 AM |
| Soon to have complete tear down and rebuild | mazdaspeedjay | MazdaSpeed 3 - Engine, Transmission & Driveline | 20 | 04-13-2008 09:22 AM |
