![]() Join Date: Nov 2018
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Recently I’ve been getting a code at idle stating fuel system lean at idle. So I then sprayed all my vac lines with carb cleaner and found that my intake runner solenoid is the source. Just to make sure I smoke tested the solenoid and it was leaking like crazy. I now have 2 more that I bought one being brand new and the other off another Mazdaspeed. After installing the new one my LTFT was at 20.12 same as before so I took it all off again. I then smoke tested both of the the solenoids I got and To my surprise both of them leak out of the top of the solenoid. Has anyone else had this problem and any way to fix it? |
![]() Join Date: Jun 2009
Are you completely stock? In your other thread I requested you identify all mods on your engine. This helps enormously in trying to address problems as many known issues are related to changes or the design of particular modificatiins.
| Help-OEM Boost Control Solenoid | TRSpeed | MazdaSpeed 3/6 - Turbo Induction | 23 | 02-16-2016 07:09 AM |
| CEL P2004 INTAKE MANIFOLD RUNNER CONTROL STUCK OPEN | kawaxi | CX-7 > Engine, Transmission & Driveline | 0 | 02-26-2015 05:00 PM |
| How do I get the boost control solenoid off | Dboyle23 | Gen2 MS3 General Discussion | 4 | 01-01-2014 03:14 PM |
| D.O flow control solenoid | SLOWHATCH | 2010 MS3 - Fuel, Nitrous & Water Injection | 35 | 11-04-2011 10:19 AM |
