 Old 03-25-2008, 03:08 PM   #1
driver311's Avatar
Posts: 1,769   (View Stats)
Default Ported intake manifold?
Whats the status on that bad boy. The dyno is calling my name. Plus my car is beggin me to get all this oil out of the intake runners. LOL
Mazdaspeed
The Following User Says Thank You to driver311 For This Useful Post:
jlarson1983 (03-26-2008)
 Old 03-25-2008, 03:08 PM   #2
Ant, i thought you added a catch can?
 Old 03-25-2008, 04:52 PM   #3
driver311's Avatar
Ive been to lazy. Racing been taking up all my spare time. Oh and that 2year old of mine. LOL
Mazdaspeed
 Old 03-25-2008, 06:03 PM   #4
ptperformance's Avatar
Posts: 4,123   (View Stats)
Its done we are just getting the final sizes and what nots for the EGR block off plate.
I also have the AR housing for you and the turbo should be done end of this week if the new wheel doesn't cut through the stock cover (if it does we have a fix for that also).
I wanted to get all the parts out to you at once but if you are ready then I will get it shipped separate if you plan on dynoing them separate. Let me know on the dyno time and if doing 2 separate dyno's is OK with you. Thanks.
The Following User Says Thank You to ptperformance For This Useful Post:
 Old 03-25-2008, 06:04 PM   #5
I have something for him that I can put together real quick.
 Old 03-25-2008, 10:14 PM   #6
jlarson1983's Avatar
Posts: 887   (View Stats)
jlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the worldjlarson1983 is the leader of the world
those are the parts you got from me huh? i have a turbo ready to send you to get re worked when your ready to sell these things
jlarson1983 is offline   Reply With Quote
 Old 03-25-2008, 10:34 PM   #7
driver311's Avatar
dyno time is on me, and I can do seperate days. Just send them out as they are done. Ill test them within a few days of getting them.
What exactly do you mean by cut through??? LOL
Mazdaspeed
 Old 03-26-2008, 12:47 AM   #8
I get this vision of a table saw trying to cut through alumn! lol
 Old 03-26-2008, 04:57 AM   #9
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
I used a sawzall
whoosh@Realtune is offline   Reply With Quote
The Following User Says Thank You to whoosh@Realtune For This Useful Post:
 Old 03-26-2008, 07:14 AM   #10
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
psh just use some tin snips
The Following User Says Thank You to bova For This Useful Post:
 Old 03-26-2008, 08:31 AM   #11
One is and the other one came off the motor I was working on.
Let me know when you are ready, the turbos are looking really good right now. There should be lots to gain from the turbine housing work that we are doing to them.
 Old 03-26-2008, 08:34 AM   #12
The factory inlet into the stock turbo is very thin. The new wheel is very close to being to big on the inducer. So if it gets to thin we are going to add a bell mouth to the turbo to thicken the walls of the turbo inlet. This will not only give more flow from the inlet being bigger but also allows for future upgrades to bigger wheels. I will be getting the intake and EGR block off kit out to you this week. Install is not that bad if you take your time. The only real pain is the t-body.
 Old 03-26-2008, 08:34 AM   #13
Cold saws work just as good, .
 Old 03-26-2008, 08:35 AM   #14
 Old 03-26-2008, 08:51 AM   #15
Now that may be something I keep under wraps for a while. We are working on some ways to get the bigger inlet installed that will keep any and all welding away from the cover. Here is a picture of the SST version III for the SRT4N. If you notice there are no welds but the cover is obviously bigger on the inlet side.
 Old 03-26-2008, 09:42 AM   #16
Nice! I dont blame ya if you dont want to share your special herbs and spices.
 Old 03-26-2008, 09:47 AM   #17
i am ready when ever!
 Old 03-26-2008, 01:59 PM   #18
Sounds good, sending funds today.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/ported-intake-manifold-451/
PT-Performance [Archive] - Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 04-02-2008 04:11 PM
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-26-2008 08:12 AM
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-25-2008 05:08 PM
DIY Short Ram Intake billyrohm MazdaSpeed 3 - How-To's 63 05-10-2012 09:24 AM
Turbo to intake pipe, you asked I will deliver. ptperformance Mazdaspeed3/6 General Discussion 96 08-28-2008 05:44 PM
PG Manifold SLS MS3 MazdaSpeed 3/6 - Turbo Induction 39 04-19-2008 01:11 AM
Page generated in 0.36449 seconds with 26 queries
