 Old 09-09-2008, 11:42 AM   #1
06kr's Avatar
Posts: 89   (View Stats)
06kr is infamous around these parts06kr is infamous around these parts06kr is infamous around these parts06kr is infamous around these parts
Default Power gains with just an air intake and catback.
What kind of power gains will I see with just an Air intake (short ram type) and catback exhaust. I would like to have 300/300 motor not wheels.
Is this possible without voiding the warrenty. I can go back to stock on the intake for stealership visits.
My guess is around 285 maybe 290 max with the two modds. Are there any other stealthy modds to get me closer to the 300 hp goal.
Will I even gain any power with a catback exhaust?
2008.5 MS3 GT, Black Mica.-CAI
1994 ZR1 Corvette, Torch Red-exhaust, CAI, tune.
2006 Ford F150 4x4 King Ranch, white- exhaust, CAI, tune.
06kr is offline   Reply With Quote
 Old 09-09-2008, 11:44 AM   #2
Colonel Speed's Avatar
Posts: 198   (View Stats)
Colonel Speed is just really niceColonel Speed is just really niceColonel Speed is just really niceColonel Speed is just really niceColonel Speed is just really nice
Its hard to say, theoreticaly you may have 280 with the two at the motor... Maybe
Welcome to the family Princess Leia.
Her current mods include; Exhaust depot FMIC, MM, SU Dual port.
Coming Soon; Secret Stuff.....
Colonel Speed is offline   Reply With Quote
 Old 09-09-2008, 11:48 AM   #3
prototype_x9's Avatar
Posts: 174   (View Stats)
prototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the world
the CBE wont give you any real noticeable gains.
07 GT: JBR 3.5 wide path intake, FMIC, 51R small battery, grimmspeed EBCS, Cobb DP
3Bar map sensor, Kozmic primary and secondary EGR deletes, Bilstein PS14, whiteline endlinks,
hawk brake pads, rear camber arms. Speedbakery tuning in the works
prototype_x9 is offline   Reply With Quote
The Following User Says Thank You to prototype_x9 For This Useful Post:
Colonel Speed (09-09-2008)
 Old 09-09-2008, 12:36 PM   #4
dimaxxxl's Avatar
Posts: 397   (View Stats)
dimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the world
I am in the same boat. I wanted to mod without voiding my warranty. I got a MS CAI and a MS CBE. I noticed significant gaind from the CAI but nothing from the CBE. The CBE sounds better but the butt dyno felt nothing. I think if you get the MS CAI and CBE and an ACCESSPORT that will be as close as you can get to your goal. You can always put it bacjk to stock tune before going to the dealer. It takes like 5 mins.
dimaxxxl is offline   Reply With Quote
 Old 09-09-2008, 12:38 PM   #5
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
CBE gains will be minimal. Maybe 5 at the most. Only thing i can think of is intake, RP and MBC/clamp.
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline   Reply With Quote
 Old 09-09-2008, 12:40 PM   #6
ev0nstispanka's Avatar
Posts: 358   (View Stats)
ev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud of
he's right..man fuk the warranty
ev0nstispanka is offline   Reply With Quote
 Old 09-09-2008, 01:00 PM   #7
Intake, race pipe, and don't forget the motor mount for a warranty happy car.
 Old 09-09-2008, 03:09 PM   #8
boostjunkie's Avatar
Posts: 47   (View Stats)
boostjunkie is a jewel in the roughboostjunkie is a jewel in the roughboostjunkie is a jewel in the roughboostjunkie is a jewel in the rough
i made 269 at the wheels with just sri and ap. Thats gotta be damn close to 300 motor
2008 CB ms3 : SU MM, Cobb SRI, AP, Twm bushings, cobb shifter weight, 20% tint
269whp 299wtq
boostjunkie is offline   Reply With Quote
Antec True Power Trio TP3-550 ATX12V 550W Power Supply with Three 12V Rails $49.99 at newegg Haltech Hot Deals Section 0 04-16-2008 09:40 AM
COOLER MASTER Real Power Pro 750W Power Supply $59.99AR at ZipZoomfly Haltech Hot Deals Section 0 04-14-2008 05:00 PM
Expiring: Antec True Power Trio TP3-650 ATX12V 650W Power Supply $59.99AR Free Shipping Haltech Hot Deals Section 0 04-09-2008 09:00 AM
CoolerMaster Extreme Power 650W ATX Power Supply $49.99AR Haltech Hot Deals Section 0 04-08-2008 09:50 PM
Antec Neo Power 500 ATX12V 500W Power Supply 100Vac to 240Vac $69.99 Free Shipping Haltech Hot Deals Section 0 04-01-2008 09:41 PM
Page generated in 0.30745 seconds with 27 queries
