 Old 03-24-2018, 11:51 AM   #1
arnold600's Avatar
Posts: 31   (View Stats)
arnold600 is on a distinguished road
Exclamation Power steering whine.
After purchasing my ms6 I noticed when its cold the power steering pump whines like hell. then after it warms up it goes away. after further diagnosis and a few weeks pass, i notice the power steering line return from the cooler to the reservoir has some leaks. I looked everywhere and couldn't find a replacement line besides a dealership part which they wanted $389.00 for. so instead I ordered some ATF compliant hose and will repair the line my way, considering the return line is low pressure. However, besides this leak. My ATF fluid is not aerated. I doubt fixing the leak will fix the whine. Most cars take brand name power steering fluid but on alldata they recommend ATF M-III, M-V, or equivalent (e.g. Dexron® II). Would putting a synthetic fluid help with my cold morning whine? It normally happens when its below 50 degrees. and no, it is not low on fluid.
arnold600 is offline   Reply With Quote
 Old 03-24-2018, 12:21 PM   #2
Orangatang's Avatar
Posts: 466   (View Stats)
Orangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the world
I generally like to use whatever the manufacture has suggested to use. If you haven't already you can try to suck out the as much fluid as possible from the reservoir and fill with fresh fluid. Run the wheel lock to lock a few times and repeat from above until all fluid looks new.
Corksport stage 2 sri/tip, Autotech Internals, RSB,
CBE, Forge bpv, Koni FSD, Mazda Sport Springs,
ITV22, JBR PMM, JBR TMM, JBR RMM, Damond SSP
JBR SSB, CX piping with TR6, DM OCC
Dizzy Tuned
" I just don't need a stage 6, 16 puck, teflon diamond plated clutch that can snap a femur downshifting." -Raider
Orangatang is offline   Reply With Quote
The Following User Says Thank You to Orangatang For This Useful Post:
arnold600 (03-26-2018)
 Old 03-26-2018, 06:03 AM   #3
GroceryGtr's Avatar
Posts: 472   (View Stats)
the whine is caused by cavitation(air being sucked into the system). The reason it is going away once warm is because the oring/joint is heating up and swelling, sealing the tiny gap from the cold temps. Fairly commong for an oring or loose fitting to start showing symptoms of failure in cold temps.
FYI: The oring between the resevoir and the pump is a very commong failure item for the 6s.
If rockauto didn't have it, you could take your line to a local hydraulic shop and they can usually custom make a replacement for fairly cheap. Otherwise I'd grab a used one.
 Old 03-26-2018, 06:24 AM   #4
shamie's Avatar
Posts: 952   (View Stats)
This is what I use in my MS3;
https://www.amazon.com/Valvoline-Mul.../dp/B00DJ4FMA2
The Following User Says Thank You to shamie For This Useful Post:
 Old 04-07-2018, 02:25 PM   #5
arnold600's Avatar
As an update. the new line doesn't leak and works well. However, if that seal was bad. wouldn't it also leak fluid out when not running? I currently have no leaks.
 Old 04-09-2018, 05:52 AM   #6
GroceryGtr's Avatar
sometimes not. Air molecules are smaller than fluid molecules. So its not uncommon to have just enough of a seal gap to allow air in, but not fluid out.
 Old 06-20-2018, 09:18 PM   #7
Marv's Avatar
Posts: 8   (View Stats)
Marv is an unknown quantity at this point
Is it still making noise after the fix?
Marv is offline   Reply With Quote
 Old 09-26-2018, 04:45 AM   #8
Aharahel32's Avatar
Posts: 2   (View Stats)
Aharahel32 has a little shameless behaviour in the past
last time i have changed my steering pump.when I opened up the hood and found the power steering pump has been leaking all over the place. First step > https://www.steeringlpsr.com/ where my friend works. They did very good job
But first think, if something was wrong with your car check it !
Aharahel32 is offline   Reply With Quote
The Following User Says NO Thank You to Aharahel32 For This Un-useful Post:
Thor Hammer (09-26-2018)
 Old 09-26-2018, 12:43 PM   #9
arnold600's Avatar
UPDATE: I fixed this issue a while ago but never posted. Turns out it was the O-Ring between the pump and reservoir. Seal kit from rockauto. 5$ fix.
 Old 09-26-2018, 09:29 PM   #10
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Last time my PS pump had wine, I gave it cheese.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
arnold600 (09-26-2018)
Steering wheel whine at low speeds dutchbuffalo MazdaSpeed 6 - Engine, Transmission & Driveline 6 02-20-2013 03:23 PM
Power steering pump whine/noise kish89 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 01-09-2013 02:52 AM
Power Steering Pump Whine PonchoKid 2010 MS3 - Troubleshoot/Diagnostics 18 08-26-2012 09:04 PM
Power Steering Whine? Bubba Ho-Tep Gen2 MS3 General Discussion 24 03-11-2012 08:34 PM
does anyone hear the power steering whine at low speeds as you turn the wheel. dimaxxxl 2010 MS3 - Engine, Transmission & Driveline 14 02-17-2010 12:11 PM
Page generated in 0.31153 seconds with 26 queries
