 Old 03-25-2008, 03:24 PM   #1
CraigHJr's Avatar
Posts: 676   (View Stats)
CraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the world
Default Price quotes please Synapse Eng and Vibrant
Hey I was wondering how much the Synapse BOV goes for set up to VTA on a speed 3 that currently has an HKS.
And I think you can get Vibrant components so the 2.5" OD aluminum induction tubing, if they have non-polished that would be preferred.
CraigHJr is offline   Reply With Quote
The Following User Says Thank You to CraigHJr For This Useful Post:
jlarson1983 (03-25-2008)
 Old 03-25-2008, 04:14 PM   #2
redrocketz's Avatar
Posts: 1,122   (View Stats)
redrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond repute
I can do $230 shipped for the Valve with the HKS adapter and VTA/Anti-stall kit.
And for the Vibrant what are you looking for just straight pipe?
Straight I can do $22 per 18" shipped to you.
redrocketz is offline   Reply With Quote
The Following 2 Users Say Thank You to redrocketz For This Useful Post:
Derek88 (03-26-2008), jlarson1983 (03-25-2008)
 Old 03-25-2008, 05:09 PM   #3
CraigHJr's Avatar
Cool I will take them both. I will call now.
 Old 03-26-2008, 09:41 AM   #4
Jesse MS3GT's Avatar
Posts: 356   (View Stats)
Jesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the world
Synapse has a kit for the speed3 now?!
There will always be someone faster than you, smarter than you, or better than you in some way. They key is to maintain a presence beside those lesser than you to appear superior
35psi, super cams, ported head, titanium valve springs, titanium rods/pistons, flux capacitor, 88mph mod, cryogenic tranny with welded differential
Jesse MS3GT is offline   Reply With Quote
The Following User Says Thank You to Jesse MS3GT For This Useful Post:
jlarson1983 (03-26-2008)
 Old 03-26-2008, 10:24 AM   #5
CraigHJr's Avatar
According to the Synapse Forum a kit was in the works, for me I had a HKS flange from CP-E so I will reuse that.
 Old 03-26-2008, 11:25 AM   #6
redrocketz's Avatar
no you have to use the HKS adapter which I can do for you for the same price I quoted Craig minus the VTA adapter if you plan to stay recirc.
Nypest just ordered one actually.
 Old 03-26-2008, 11:59 AM   #7
NYpest's Avatar
Posts: 1,889   (View Stats)
NYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the world
yup yup but i thought it was the ATP flange ? lower profile ?????
NYpest is offline   Reply With Quote
 Old 03-26-2008, 12:04 PM   #8
redrocketz's Avatar
yeah he already had a flange that's why
 Old 03-26-2008, 12:31 PM   #9
NYpest's Avatar
oh sorry i read it like you were packaging the hks flange in ........ Cant wait for this thin and my FP is here tomorrow
 Old 03-28-2008, 10:39 PM   #10
CraigHJr's Avatar
Ok the Synapse valve is installed. It was a pain it the ass.
1. You have to remove your turbo inlet to get a clear shot at the boost source for the 3rd port.
2. The HKS base is a rediclously tight fit with the CP-E HKS flange.
3. The set screws are 1.5mm not 1/16". They only give you one 2.5mm allen key for the recirc nipple. I didn't have any allen keys this small at work so I had to make one, which sucked.
4. My biggest bitch, The threads on my valves piston looked marred and there was a chink in the flat machined surface of the end (where the anti-stall kit seats). I think the anti-stall kit didn't screw in all the way. It says to go hand tight and put your finger in the valve to hold the piston which did nothing. I think this is being backed up my the fact that occasionally the valve doesn't seat well and althought I can drive without stalling I am seeing AFR's in the 17-19 range.
Was this one a return or something?
 Old 03-28-2008, 11:26 PM   #11
NYpest's Avatar
BOOOOO! It doesn't sound like something to look froward to......The Synapse forum says its almost too easy on the Mazda Speeds and when i talked to PG they gave me the same impression...
 Old 03-28-2008, 11:29 PM   #12
redrocketz's Avatar
nope it was brand new. the anti-stall is a pain in the ass to install I had to physically hold the piston with some force to keep it from moving while threading in the anti-stall it was harder then the instructions made it seem.
When are you hitting 17-19 afr's?
 Old 03-29-2008, 04:47 PM   #13
CraigHJr's Avatar
I put a rag on the aluminum and pliers and I don't thing the O-ring fully seated still. It was pretty darn tight. The lean spot happened after two 1-2 shifts and one 2-3 shift. I was snowboarding all day and going to a concert now so I will dick with it tomorrow now.
 Old 03-29-2008, 04:58 PM   #14
redrocketz's Avatar
You will always have some problems running VTA on a car designed to recirc sadly. I would say try using that and see what happens if all else fails.
 Old 03-29-2008, 09:46 PM   #15
Derek88's Avatar
Posts: 773   (View Stats)
Derek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the world
Was the Anti-stall kit the hard part to install or the bov itself?
I want to order this instead of the HKS I was planning on. Should I just put the HKS plate thing in the cart with the Synapse to make this "kit"??
-Derek
No longer in the Mazdaspeed Family
Derek88 is offline   Reply With Quote
 Old 03-30-2008, 09:36 AM   #16
CraigHJr's Avatar
Due to the size of the bov and the angle of the Turbo XS hot pipe recirc will not happen. In truth that will only mask the problem of the anti stall kit not sealing while driving because in recirc the valve will act normally.
The whole valve was a pain in the butt to install for the reasons I said in post one. If you have no BOV now you need the HKS to Mazda flange to install it yes.
 Old 03-30-2008, 09:55 AM   #17
NYpest's Avatar
where do the instructions say to tap boost only?
 Old 03-30-2008, 11:21 AM   #18
CraigHJr's Avatar
On top of the box there is a sticker. The dirrections book makes no mention of the 3rd port on the side of the valve.
 Old 03-30-2008, 03:14 PM   #19
NYpest's Avatar
hmmmmmm when i spoke to them they said you can run it to the top of the waistgate actuator...
 Old 03-30-2008, 04:21 PM   #20
CraigHJr's Avatar
Yeah the wastgate is down pretty far and low. To do a solid leak free install I choose to take stuff appart instead of blindly reaching down to a line that you can only see 2 inches of. I chose to put the bov line between the turbo and wastegate not the wastegate and electronic solenoid.
 Old 03-30-2008, 05:24 PM   #21
NYpest's Avatar
ahh now i see why you had to take the inlet out..
 Old 04-13-2008, 10:36 PM   #22
Anklh's Avatar
Posts: 166   (View Stats)
Anklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond repute
Thank you PG for getting this to me so quickly. As I posted in another forum I will post something useful after a visit to the dealer for the update.
Anklh is offline   Reply With Quote
 Old 05-12-2008, 07:10 AM   #23
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
I received mine but I am still waiting on the flange.
SgtP is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/price-quotes-please-synapse-eng-vibrant-452/
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-26-2008 10:33 AM
SYNAPSE HYBRID REVIEW. driver311 MazdaSpeed 3/6 - Turbo Induction 136 05-04-2008 09:56 PM
[B]Price Match Guarantee[/B] redrocketz Mazdaspeed3/6 General Discussion 1 03-25-2008 12:16 PM
CorkSport DP + Vibrant SLS MS3 MazdaSpeed 3 - Engine, Transmission & Driveline 9 03-24-2008 10:57 AM
Page generated in 0.41654 seconds with 27 queries
