 Old 05-17-2015, 01:35 PM   #1
SyntheticAtmosphere's Avatar
Posts: 193   (View Stats)
SyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond repute
Default Priming engine
I would like to prime the oiling system after installing a new turbo and the car being parked since January. I was planning to spin it over with the starter in stages, giving the starter a break in between. I was going to just jump the start relay and leave the fuel pump and ignition off. Would I possibly be doing damage to the hpfp by not having fuel supply on?
fapatalk
SyntheticAtmosphere
'06 Speed6 Whitewater Pearl (COBB AP v2, CS s2 SRI/TIP, Autotech HPFP, Cp-e RMM&RDM, Fidanza/LuK, homebrew Testpipe&OCC) next...meth habit
If it feels good, do it...Even if you shouldn't!
SyntheticAtmosphere is offline   Reply With Quote
 Old 05-17-2015, 01:55 PM   #2
CFI2008's Avatar
Posts: 259   (View Stats)
CFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the world
Why not just hold the throttle to the floor while cracking?
CFI2008 is offline   Reply With Quote
The Following User Says Thank You to CFI2008 For This Useful Post:
Agent_Orange (05-17-2015)
 Old 05-17-2015, 04:04 PM   #3
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
Yeah pinning the accel pedal while cranking will turn the engine without the fuel injectors firing.
Edit: it works on the 3, don't know about the 6.
'08 CWP MS3 w/ T3 3071r
 Old 05-17-2015, 06:03 PM   #4
08mzr's Avatar
Posts: 641   (View Stats)
08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world
Holding the throttle to the floor works on every car, it puts it 'clear flood mode' which does as @802MS3; said.
2008 Metro Gray Mica Speed 3-SOLD
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
SPC rear camber arms
Hawk HPS pads front and rear
FREEKTUNE OTS+
1998 Civic - SOLD
2011 Speed3 200k+ miles Stock -Daily
08mzr is offline   Reply With Quote
 Old 05-17-2015, 09:48 PM   #5
Would the car not possibly still start? I'm attempting to get the car lubed up...when my seals went in the turbo the car drank a lot of oil. I think I was able to shut the car down at the point between starvation and catastrophe. Just wanted to get some oil passed around first.
fapatalk
SyntheticAtmosphere
 Old 05-17-2015, 09:53 PM   #6
08mzr's Avatar
It is a possibility, but you can also pull the relay for the fuel pump just for extra assurance. You could also unplug the coils, as well as hold the pedal to the floor.
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
FREEKTUNE OTS+
1998 Civic - SOLD
The Following User Says Thank You to 08mzr For This Useful Post:
SyntheticAtmosphere (05-18-2015)
 Old 05-17-2015, 09:56 PM   #7
CFI2008's Avatar
I can tell you I've recently done the accel pedal to the floor method when I installed the Bnr and the car did not start. For reference I have a pu.
engine idle and check engine light msalva2 MazdaSpeed 3 - Engine, Transmission & Driveline 35 07-25-2012 04:48 PM
Pulsar Spark Plug Replacement, Pinging Engine, Jeep Liberty Engine Stalls, Windows Are Stuck, Blower Motor Runs On Low O Haltech Automotive News 1 04-13-2012 09:13 PM
Engine Block Heater, Sticking Gas Pedal, Clunking Noise on F-150 Truck, Ford Explorer Engine Dies at Idle: Mike Allen's Haltech Automotive News 0 03-13-2009 03:30 PM
Pulsar Spark Plug Replacement, Pinging Engine, Jeep Liberty Engine Stalls, Windows Are Stuck, Blower Motor Runs On Low O Haltech Automotive News 0 07-10-2008 11:10 AM
Page generated in 0.26800 seconds with 23 queries
