 Old 06-07-2016, 12:27 PM   #1
Speed3Pedro's Avatar
Posts: 111   (View Stats)
Speed3Pedro is a jewel in the roughSpeed3Pedro is a jewel in the roughSpeed3Pedro is a jewel in the rough
Groaned at 8 Times in 4 Posts
Default Rear spring or shock shot?
I've been getting a clunking noise in what seems to be the rear right wheel whenever i go over bumps so i changed the rear sway bar end links which helped drastically for like 2 days, but now I have a different sounding clunk and the other day I noticed the rear right side of my car was sitting lower then the left side which leads me to believe I'm gonna need some new springs and shocks in the rear which I planned on changing anyways since the PO has shitty OE Spectrums in the rear, buuuut I was planning on ordering my AP this week since I've been saving for it. Is there anything else that could be causing the clunk before I order some koni sport yellows?
Sent from my SM-G900T3 using Tapatalk
Speed3Pedro is offline   Reply With Quote
 Old 06-07-2016, 04:12 PM   #2
Bingo's Avatar
Posts: 740   (View Stats)
Groaned at 9 Times in 7 Posts
It's hard to say just based on a "clunk." A blown shock will most certainly do that, and the easiest way to tell is if the shock is covered in oil. My shock blew randomly overnight and there was a puddle of oil about a foot in diameter under my shock. I went the route of Koni FSD's, but even if the shock isn't your problem (which it sounds like it is), getting the Koni's is a good choice.
 Old 06-08-2016, 09:18 AM   #3
dinoxor's Avatar
Posts: 346   (View Stats)
dinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the worlddinoxor is the leader of the world
swaybar bracket and bushing combo from JBR helpped my rear clunk
Black Mica 2008.5
CS SRI+TIP • AT HPFP • TP
dinoxor is offline   Reply With Quote
 Old 06-08-2016, 12:28 PM   #4
furinax's Avatar
Posts: 220   (View Stats)
furinax is a glorious beacon of lightfurinax is a glorious beacon of lightfurinax is a glorious beacon of lightfurinax is a glorious beacon of lightfurinax is a glorious beacon of light
Groaned at 7 Times in 3 Posts
My rear clunk was fixed with the new koni yellow install in the rear. The stock shocks were super weak. Check your end links as well... it helps that they are tight.
2007 Mazdaspeed 3
furinax is offline   Reply With Quote
 Old 06-10-2016, 12:42 PM   #5
MSMS3's Avatar
Posts: 2,830   (View Stats)
Check the right rear actual sway bar bushing, and not merely the end link. Probably needs replacing anyway and is easy.
If that side is lower, I'm inclined to think it is probably the spring rather than a shock, but that ought to make some serious racket if a coil is actually broken.
Mazdaspeed 6 - Spring/Shock combination Indianspeed MazdaSpeed 3/6 - Suspension & Brakes 47 02-17-2014 08:05 PM
Mazdaspeed 6 Shock Spring combos speedms6 MazdaSpeed 3/6 - Suspension & Brakes 17 02-04-2013 11:12 AM
Shock/Strut & Spring combinations? WWP6 MazdaSpeed 3/6 - Suspension & Brakes 30 03-30-2011 05:13 PM
Page generated in 0.25947 seconds with 24 queries
